Tony Martyr | 13/08/2023 10:09:42 |
![]() 226 forum posts 45 photos | My next project is an 'engineer's' set of Chess pieces using various bit of workshop materials. The 'white peices are resonably easy as they are being made mostly of brass (not white!) but Blcak is proving a bit problematic. Is Carr's blacking liquid a surface treatment, rather than a covering, and does it produce a similar shade to the similar solutions for steel. I once blacked an engine flywheel using a hot mixture of very agresive alkali that I don't think I would be able to buy nowadays. Tony |
Michael Gilligan | 13/08/2023 10:17:08 |
![]() 23121 forum posts 1360 photos | Have you considered using Carbon Fibre, as a modern material ? MichaelG. |
John Haine | 13/08/2023 10:17:32 |
5563 forum posts 322 photos | Corian. Obtainable in a wide range of colours blacks included. Kitchen fitters have offcuts. You might need to glue bits together as the standard thickness is about 12mm. You can also get pen blanks made of it. Lovely to machine. |
Emgee | 13/08/2023 10:26:50 |
2610 forum posts 312 photos | Black Delrin is another alternative. Emgee |
Craig Brown | 13/08/2023 10:29:59 |
110 forum posts 57 photos | Black Acetal was also my first thought but very light weight compared with brass if that bothers you? You could maybe add a weight into the bottom of the pieces? |
Fulmen | 13/08/2023 10:56:43 |
![]() 120 forum posts 11 photos | Are the black pieces also to be made from brass? Never used the Carr products, but it appears to be a chemical conversion treatment. The one for steel is most likely regular selenium-based cold blue which work OK but won't be nearly as wear resistant or decorative as a caustic black treatment. There are several formulations that will produce a brown to black patina on copper alloys, here are a few: https://davidmbowman.com/patinas/formulas.htm Aluminum can be anodized and dyed into almost any color. |
Paul Lousick | 13/08/2023 11:10:49 |
2276 forum posts 801 photos | Blueing can also be done with heat and oil Edited By Paul Lousick on 13/08/2023 11:13:26 |
Dave Wootton | 13/08/2023 13:09:08 |
505 forum posts 99 photos | I've used both the Carrs and Birchwood Casey brass blacking solutions and despite every care and degreasing in a variety of ways have only ever got a dissapointing deep brown, ok from a distance but wouldn't call it a proper black. The Birchwood Casey gun blacking (or blueing I think they call it) does work very well as does a steel blacking kit I bought from Frosts, careful degreasing seems to be the key to a lasting finish. I heated and oil blacked parts of my Simplex and they are still ok 40 years on, again to get an even finish careful degreasing is key. |
bernard towers | 13/08/2023 13:11:42 |
1221 forum posts 161 photos | If you used delrin/acetal you could glue the blank onto a steel mandrel then machine your piece and part off so you then have a heavier playing piece. |
Frances IoM | 13/08/2023 13:24:39 |
1395 forum posts 30 photos | why not consider stainless steel as white and brass as black - this will give the pieces some weight (corian would also be heavy but light plastic pieces always feel wrong) - the board could use brass + stainless steel foil glued on a wooden base |
duncan webster | 13/08/2023 14:23:15 |
5307 forum posts 83 photos | make from copper then oxidise the surface. How, no idea, need a chemist! According to this it can be done by heating in air to above 300C, might be worth trying on some bits of scrap. You need cupric oxide, which is black, not cuprous, which is red Edited By duncan webster on 13/08/2023 14:24:24 |
Simon Williams 3 | 13/08/2023 15:05:53 |
728 forum posts 90 photos | Hammerite Kurust Rust Converter or it's equivalent. This is a surface treatments for steel based on Tannic acid, so leaves the base metal a deep navy blue. Other maker's equivalent preparations give much the same results. Jenolite make one, also Vactan, and Aquasteel. Loctite also make one but it's expensive though a little goes a long way. I've recently used one called Neutrarust 661 which seems to work. I thought the resulting colour was more dark brown than blue or blue-black, but the part (a wheel rim) was pretty rusty! Getting an even coating is going to be about cleanliness - try caustic soda rinse first. Maybe an uneven coating can add to the character of the piece. Do do a show and tell afterwards, please! |
Gary Wooding | 13/08/2023 15:38:27 |
1074 forum posts 290 photos | Posted by Frances IoM on 13/08/2023 13:24:39:
why not consider stainless steel as white and brass as black - this will give the pieces some weight (corian would also be heavy but light plastic pieces always feel wrong) - the board could use brass + stainless steel foil glued on a wooden base The density of brass is around 8.5 and that of Corian is about 1.7, so it would feel very light compared to brass. SS is around 7.5 to 8. |
larry phelan 1 | 13/08/2023 16:03:47 |
1346 forum posts 15 photos | Black paint ? Just asking ! |
noel shelley | 13/08/2023 17:16:17 |
2308 forum posts 33 photos | Make both sets of ali and load for weight ! Then anodise in 2 colours ? Noel. |
Russell Eberhardt | 13/08/2023 20:09:42 |
![]() 2785 forum posts 87 photos | Make them from steel and then apply Abbey Blue Gel as used for gun barrels. A couple of applications should give a nice dark blue colour. Fix the colour by wiping with oil or waxing. Russell |
Mick B1 | 13/08/2023 22:11:54 |
2444 forum posts 139 photos | You could go Victorian and have red instead of black. Then make the red pieces from phosphor-bronze and the white from alli. |
David George 1 | 14/08/2023 07:20:07 |
![]() 2110 forum posts 565 photos | you can get a patina solution from jewelry suplies sales. Patina Oxidising Solution 250ml UN2922this will give a dark finnish to silver, copper and bronze.not expensive but needs handling with care. David |
Anthony Knights | 14/08/2023 08:34:45 |
681 forum posts 260 photos | I made a chess set using nuts and bolts. The black pieces were treated with brick cleaner (hydrochloric acid) to remove the bright zinc plating and then blacked by heating and dunking in oil. |
Roderick Jenkins | 14/08/2023 09:46:57 |
![]() 2376 forum posts 800 photos | Anthony, your fastenings chess set is utterly charming Rod |
