Here is a list of all the postings Fulmen has made in our forums. Click on a thread name to jump to the thread.
Thread: Multifix A clamp screws |
24/09/2023 18:53:29 |
Don't forget to turn it down a bit on the end. The screw tip tend to deform when over-tightening, this is probably what causes them to bind and strip in the end. |
24/09/2023 18:27:51 |
My knockoffs are M7x1 as well. I believe it's a "2nd choice" thread, you won't find anything other than 1st choice in normal supply. Mine are fairly soft, I suspect it's done to prevent people from stripping the threads on the holder. I've worn out several, but they're easy enough to make. |
Thread: moving a 1250kg bridgeport clone |
19/09/2023 17:59:26 |
Good luck Carl. I'm confident you'll get it done without injury to man or machine. |
16/09/2023 19:58:39 |
Won't argue with that, never seen a heavy load slip on a pallet unless something was seriously wonky. With these weights and materials friction is pretty reliable. But there's also Murphys law. I like to add a couple of sensible wedges, straps or screws just for piece of mind. |
16/09/2023 18:51:01 |
Posted by Carl Farrington on 16/09/2023 17:36:23:
Which way round did you do it? I really can't remember. But if you reverse the jack while pulling on the machine you should be safe. |
16/09/2023 17:23:04 |
I've moved an A&S Bridgeport a couple of times. Placed on a pallet, used a pallet jack and a winch to pull it onto a twin axle trailer. Not fun but doable back when my back wasn't completely fubar. |
Thread: Brazing & corrosion |
29/08/2023 19:22:51 |
Moisture and plant juice isn't the same as seawater. If brazing caused significant corrosion outside of marine applications it would never have become so prevalent. |
Thread: making BLACK chess pieces |
14/08/2023 16:22:50 |
I love it |
13/08/2023 10:56:43 |
Are the black pieces also to be made from brass? Never used the Carr products, but it appears to be a chemical conversion treatment. The one for steel is most likely regular selenium-based cold blue which work OK but won't be nearly as wear resistant or decorative as a caustic black treatment. There are several formulations that will produce a brown to black patina on copper alloys, here are a few: https://davidmbowman.com/patinas/formulas.htm Aluminum can be anodized and dyed into almost any color. |
Thread: Why has my mild steel bent |
03/08/2023 20:34:50 |
Posted by DC31k on 03/08/2023 18:46:21:
Would wrapping in stainless steel foil and including a bit of paper that would burn off the oxygen work? For small stuff, could you coat in borax paste as if you were silver soldering and then dissolve off once cooled? Yes and maybe. I haven't tried foil myself, but it's a well known trick among knifesmiths and toolmakers. And while borax chould work, I've only used boric acid. It has a much lower melting point (170C) meaning you can apply it by sprinkling it over a hot part or rolling/dipping the part in dry powder. Once molten it dehydrates into a viscous glass-like coating that will dissolve in water. PS: You can make boric acid by acidifying a borax solution with muriatic (hydrochloric). |
Thread: I like a nice tool but.. |
02/08/2023 00:59:02 |
My guess: It's simply better. High rigidity and low weight will make it more precise and easier to work with. And written off over a few decades it's not really a big investment. |
Thread: Damaged Screws & QCTP help!!! |
29/07/2023 16:12:05 |
Posted by Bo'sun on 29/07/2023 15:39:38:
the 5.69mm diameter is worrying. Cheap will be cheap. 9 times out of 10 you can eyeball metric vs imperial, both UN and Witworth use a coarser pitch for a given diameter. Edited By Fulmen on 29/07/2023 16:14:33 |
29/07/2023 15:25:50 |
If it's not made in the UK or US, it's metric (99% sure). |
Thread: Indexing arms on dividing head are spinning freely |
27/07/2023 20:41:39 |
I made my replacement from a spare brake hose clip I found in a drawer: https://www.amazon.com/Empi-98-6685-B-Stainless-Steel-Bug-Bus-Ghia-Squareback/dp/B076DLRNWL |
27/07/2023 16:41:59 |
I'm guessing you have the same head as me: https://eur.vevor.com/dividing-head-c_10129/dividing-plate-dividing-head-4-100mm-for-rotary-tables-in-model-hv-3-4-5-6-p_010947578525
Thread: Chester face mill inserts |
25/07/2023 21:18:55 |
I assume you have this mill and are looking for replacements? This guide should help: https://littlemachineshop.com/info/insert_charts.php 1. First letter is shape (S for square)
Thread: Circular connector identification (A&S Bridgeport) |
25/07/2023 20:34:13 |
That's it! Thank you so much Andrew. It's definitively the X4S, and from what I can tell it's completely proprietary and obsolete. Guess I'll have to swap out that plug with something more current. It's a bit of a hassle but it would be nice to have a spot light wired to the control box. |
25/07/2023 18:50:53 |
Thanks. I checked the website but it doesn't look like they stock any. And if it's special order it's really not worth it. I just need to order some parts for an electronics project, so I'm looking for additional parts to fill the order. Sadly I don't have any documentation for the mill, and no search on "bridgeport connector" or similar has ever yielded any definitive results. Some have suggested Niphan, but I have only found those in banjo or screw, not push fit. |
25/07/2023 18:13:04 |
I need a connector for my Adcock&Shipley Bridgeport, but I don't have the foggirst idea what to search for. Can anyone ID the type for me?
Thread: Identifying mystery steels |
23/07/2023 20:16:42 |
A rockwell tester is handy for sorting metal. Most of the time you don't really care what it is, as long as it is strong enough for the job. And combined with a furnace you can even harden and temper a test piece. |
