Member postings for Russell Eberhardt
Here is a list of all the postings Russell Eberhardt has made in our forums. Click on a thread name to jump to the thread.
Thread: I've borrowed a Anycubic Mega S 3D printer, best CAD program?
04/10/2023 09:13:20
Posted by iNf on 03/10/2023 19:00:44:
Also free to use without restrictions.
Well, there are a few. There is a paid version.
The free version restricts you making designs public on line (as read only), it also lacks FEM which is unlikely to cause you a problem. If you need FEM it is available in Freecad and used to be available in F360 but I'm not sure if it still is.
Russell
03/10/2023 18:54:23
For a beginner I would recommend Onshape as the easiest to learn. It is free and runs in a web browser so no complicated installation needed and it works under any operating system. It has just been upgraded and comes with a series of online courses called the learning centre.
Russell
Thread: Raspberry Pi 5
02/10/2023 10:16:40
Posted by sam sokolik on 30/09/2023 16:10:51:
well - for linuxcnc it depends on the realtime latency of the system. I have been running the PI4 with linuxcnc for a long time - but using a mesa ethernet card to do the heavy lifting. (step generation and such)
The maximum jitter I get is around 50us or so. This is perfectly fine for external interfaces like mesa.
Linuxcnc does have a gpio driver for the pi - but again you are limited to how fast the realtime kernel can twittle bits. I I goofed around with it a while back - and was getting about 10khz step rates. Not stellar...
My ancient system is giving a maximum jitter of 25uS and I am happy with the maximum step rate. I have no need for particularly fast movements.
Might the GPU of the Pi 5 take load off the processors and improve the latency over the model 4?
Russell
Russell
30/09/2023 13:51:08
Posted by Bazyle on 29/09/2023 18:05:50:
I thought the big problem for LinuxCNC using the printer port was the multitasking of the processor, particularly video generation, screwing up the timing for direct drive of steppers. It should be possible to avoid this by leaving one of the cores for the user to use unmolested, but is that the case?
Well, my current cnc system runs LinuxCNC on a single core 3.2 GHz processor. Yes. the parallel printer port does cause some timing issues but I found the reduced step rate needed to prevent lost steps was still fast enough for me. I would imagine the four cores at 2.4 GHz of the Pi 5 should beat my old computer.
Russell
29/09/2023 16:51:14
Posted by Dave S on 29/09/2023 12:11:32:
A quick google shows there are several parallel port HATs available for a Pi - thats probably the route I would take if I needed to.
Thanks, one of those should do the trick.
Russell
29/09/2023 10:32:59
Posted by Dave S on 28/09/2023 17:50:22:
I think this one is going to end up as the CNC controller for my CNC build.
Looks like a good candidate to replace the Dell computer I bought second hand 10 years ago for my CNC build. Can the raspberry Pi version of Linux CNC emulate a parallel printer port for my driver electronics?
Russell
Thread: Average Energy Consumption
29/09/2023 09:56:56
Posted by Martin Johnson 1 on 28/09/2023 13:00:03:
We have run ASHP for 7years now. Through a program of window replacement, upgrading lofT insulation and the heat pump, we eliminated a £1000 annual LPG bill without increasing the leccy bill. The house has never been warmer. We live near Inverness about 240m ASL.
<snip>
Martin
Yes, I had an air to air heat pump, otherwise known as reversible air conditioning, installed seven years ago. It is a dual split unit with a maximum heating output of 5.4 kW. Living considerably south of Inverness the cooling is essential in summer. COP for heating is about 5 at outside temperature above +7 C but drops to about 3 below -7 C as a result of the defrost cycle. With the prevailing wind coming off a mountain range over 2000 m elevation I expected to have to use our wood burner for supplementary heat but it hasn't been used for years.
I would expect more recent models to be yet more efficient.
Russell
27/09/2023 16:22:15
For anyone interested in sustainable energy it's worth reading the book Sustainable Energy - without the hot air .
Link is to online version free to read.
Written by the late Professor Sir David McKay of Cambridge university. It might be a little out of date now but the logic and simple maths are still very relevent.
Russell
Thread: Broken toolmakers clamp.
25/09/2023 15:00:01
Posted by Tony Pratt 1 on 24/09/2023 14:27:06:
File Handle, in my opinion the taper jaws look better and also practically they give better access to 'things' in confined spaces and offer a better view of what you are clamping.
Tony
I find this style are often more useful in confined spaces:
Russell
Thread: Will this heater idea work
23/09/2023 10:25:03
Just been doing a bit of thinking about solar panels. My weather station records incident solar radiation. Here, in the south of France during the winter solstice the maximum I recorded was 335 W/square metre at 12:49 pm on a sunny day. The average over 24 hours was about 50 W/m2. Now the conversion efficiency of solar panels is about 15 to 20 % so I would be getting, at best 10Wh of electricity. Depending on your lattitude in the UK you would be getting about half that (on a sunny day).
How big is your 300W panel?
Russell
Thread: Gib Adjusters and the English Language!
21/09/2023 16:41:17
I've always pronounced it as "jib" but perhaps I'm just talking gibberish.
I wonder if there is a north/south divide in the pronunciation? I was brought up in southern England.
Russell
Thread: Runout on a collet chuck?
04/09/2023 09:30:22
The run out you need to achieve depends entirely on what you intend to turn in the collet chuck. In general, if you are turning, say a 1mm diameter pivot on the end of a piece of 2 mm pivot steel you will need much better alignment than if you are reducing a piece of 20 mm bar to 3/4 inch.
Russell
Thread: What is this rule used for
15/08/2023 20:15:44
Posted by JasonB on 15/08/2023 18:29:09:
I suppose these days it should be safer than a compass if not as good.
smileysmiley
Thread: ER collet chuck for Super 7
15/08/2023 20:11:11
Posted by JasonB on 15/08/2023 16:19:13:
Russell, I assume your home made one had the taper turned in situ so I would expect that to run true
Yes, turned the spindle nose female for a good fit on the register after turning the screw thread a little on the loose side. Then turned the taper with it fitted to the spindle.
Russell
15/08/2023 13:34:59
Posted by JasonB on 15/08/2023 13:07:01:
The backplate ones do have the advantage of being easy to tweak should you find any runout issues which are not so easily dealt with using the direct screw on types.
But they have the disadvantage that there are more places where run out can occur sad. Never had any problems with my homemade screw-on type.
Russell
Thread: making BLACK chess pieces
13/08/2023 20:09:42
Make them from steel and then apply Abbey Blue Gel as used for gun barrels. A couple of applications should give a nice dark blue colour. Fix the colour by wiping with oil or waxing.
Russell
Thread: Oil can O ring replacement
12/08/2023 10:46:41
The o-ring cross section should be such that it is compressed slightly between the bore and the bottom of the groove. It should be slightly loose in the width of the groove. The diameter of the o-ring should be such that its ID is close to the bottom diameter of the groove.
Good luck finding the correct size.
Russell
Thread: Pendulum 'Q' value and measurement methods
08/08/2023 19:54:44
They are not magic numbers. They come from a bit of mathematics.
See for example **LINK**
Russell
08/08/2023 18:03:28
Easy way to measure pendulum Q is to set it to swing freely and count the number of periods it takes for the amplitude to fall by 21%. Double it to get the Q. Expect a value of around 10,000 for a good clock pendulum.
Russell
Edited By Russell Eberhardt on 08/08/2023 18:05:17
Thread: Microfibre cloths
25/06/2023 10:18:00
Perhaps they are impregnated with a fine abrasive of different grades?
Russell
