Member postings for bernard towers
Here is a list of all the postings bernard towers has made in our forums. Click on a thread name to jump to the thread.
Thread: Orrery
04/10/2023 18:38:22
try the zeaman one
Thread: Winter Storage Of Locomotives
03/10/2023 18:26:24
Surely running on worship compressor air would introduce more moisture?
Thread: Epicyclic Attempt
03/10/2023 18:20:58
They will be at lemington spa
03/10/2023 10:53:58
Sorry david what are we looking at?
Thread: Cutting Small Internal Keyways
03/10/2023 10:51:08
As per usual photos in wrong order and text moved all over the place and when you go into edit the text is in a completely different place, roll on the new edition
03/10/2023 10:47:43
adfff631-155e-4104-9f65-c22411808d38.jpeg60ac2925-6c76-4c32-a78d-6f70672d7878.jpegI was curious if it would work and it too exactly an hour for what seems to be one way of doing it.99fe1df4-42de-4cd7-866a-9de66e525c60.jpeg
Edited By bernard towers on 03/10/2023 10:49:18
03/10/2023 09:23:09
Chris how about two pieces of tube, one is 1/2 od x 3/8 I’d and one 5/8 od x 1/2 I’d. Slot both with an 1/8 cutter, slide one inside the other and silver carefully together. Before you silver them you can also set the spacing of the slots/ key ways.
Thread: simple loop alarm for exhibits
02/10/2023 18:51:56
Sorry J D but I don’t know where you’ve been hiding but this sort of pilfering has been going on for years hence the fact that most mME clubs who exhibit at exhibitions have their own loop alarms as even the most eagle eyed stewards cannot watch everything all the time. Pretty sure I have seen a club stand with cctv at one of the big shows. I had a friend exhibiting homemade aero engines at forncett and these were wired with Bowden cable but odd cranks rods pistons and rings laid on the stand, these are the sort of things that go.
Thread: Paint Baking in oven
01/10/2023 19:28:46
When I used to do my m/cycle paint I used Joseph Mason E100 enamel and left it to dry for about 6 hrs then put the bits in the oven at less than 100degc for a short period of time. Not sure if it really made any difference but it was very hard to chip or scratch.
01/10/2023 19:08:04
Pull the pin is ok but what if the wire is cut?
Thread: What is EN58 used for?
01/10/2023 19:04:42
Is the "M" for machinable grade?
Thread: Model Engineers' Day at the Forncett Steam Museum
01/10/2023 18:59:03
why is it postings move photos around and put text all over the [place?
01/10/2023 18:57:57
s11a6978.jpegs11a6968.jpegs11a6970.jpegBrilliant day at forncett lots to see and perfect day for the road steam boys of which there were plenty
Edited By JasonB on 01/10/2023 19:07:27
30/09/2023 20:20:47
Dont forget Forncett Model engineers day tomorrow!!
30/09/2023 20:17:50
deleted
Edited By bernard towers on 30/09/2023 20:18:21
30/09/2023 20:17:49
Thanks Duncan will wait to hear from you, the idea from Michael is a good one too
30/09/2023 13:09:39
Yes Dalboy this would be fine excepting my abilities in electronics and buying small quantities of components as I dont have an electronic scrap box, I had thought that a kit might be available as in the days of Maplins.
30/09/2023 12:01:53
Cheers Duncan that coud be very helpful
30/09/2023 11:24:40
is there any kits or circuits available for a simple system, I just need to protect some items at an exhibition.
Thread: Brass plate or flywheel casting
29/09/2023 20:49:14
Sorry Ron there are small engineering companies everywhere you just have to find them.
