Here is a list of all the postings Roderick Jenkins has made in our forums. Click on a thread name to jump to the thread.
Thread: M-DRO help? |
30/09/2023 11:04:20 |
I think there's a button press missed out in the above sequence. So, in Y: Find one edge, press Yo Find other edge, press 1/2 then Y (not Yo) Move back to zero, this should be the centre. Hope this helps, Rod Edited By Roderick Jenkins on 30/09/2023 11:05:47 |
Thread: Parallel Reamers? |
25/09/2023 22:55:39 |
In summary, MACHINE reamers cut a sized hole from the tip whereas HAND reamers cut a hole that is only to size about half way along the reamer onwards. You can't cut a blind hole to size with a hand reamer. ARC sell both. Rod |
Thread: Indexable tooling confusion |
25/09/2023 22:43:54 |
In my experience ccgt can provide a very fine surface finish on most materials, including brass. However, the large positive rake means that if you try too take too deep a cut they can grab and pull themselves into the cut with unpredictable results. Rod |
Thread: Thermocouple readout manual |
23/09/2023 21:25:53 |
Posted by John Purdy on 23/09/2023 17:36:37:
Thanks for the link, it didn't show up in my internet search. Duckduckgo often finds things that Google is too busy pushing revenue earners to bother with |
23/09/2023 08:56:17 |
This may help **LINK** It gives the max temp as 950C Rod |
Thread: Gib Adjusters and the English Language! |
21/09/2023 19:35:59 |
Posted by Mark Rand on 21/09/2023 18:55:56:
I guess that if folk prefer to pronounce it 'jib', they should probably spell it that way as well... As in Jibraltar |
21/09/2023 18:05:21 |
I'm from the soft south so jib for me but my Brummigen neighbour, who was a professional mechanical engineer, was a hard G man. Rod |
Thread: Milling on a mini lathe |
19/09/2023 22:50:17 |
Posted by Nigel Graham 2 on 19/09/2023 21:44:03:
For a guide, I don't think you will find a book dedicated to "Milling InThe Lathe"... Well, actually: Milling Operations in the Lathe Rod |
Thread: Farm Boy |
18/09/2023 22:28:27 |
Nice work Rod |
Thread: Which way first |
02/09/2023 00:05:05 |
When I did the 1" bore cylinders for my Hoglet I held the cylinder block in a sc 4 jaw chuck to bore the cylinders then used tailstock support while I cut the fins with a parting tool. It all went very smoothly. I used the same method for my air cooled Farm Boy. My Matosa rotating centre is bigger than the bore but if you have a smaller centre then you can turn up a plug to fit the bore and centre on that. Rod |
Thread: Calculating valve spring sizes |
01/09/2023 13:24:20 |
If you are trying to determine the spring force that you need to keep the cam follower in contact with the cam then you need to know the weight of the valve gear being moved and the acceleration due to the cam at the maximum speed of the engine - Force = Mass x Acceleration. If the cam has a flat follower than CamCalc can help give a figure for the theoretical maximum acceleration which will act as a starting point for determining the correct spring size. Rod |
Thread: Screw type and thread for SCLCR1212H06 tool shank? |
28/08/2023 12:13:27 |
Arceurotrade have some useful information Here HTH, Rod
Thread: Ether |
24/08/2023 16:18:14 |
Lest anybody gets put off making small "diesel" engines, an internet search for "model diesel engine fuel uk" will show several model shops who will sell fuel for delivery by courier. Not cheap - Model Shop Leeds will sell you a litre for £20 plus a tenner for delivery. Not really expensive compared to the cost of materials these days. I've still got half a tin left from the the Dyno I made a few years ago but I expect all the ether content has evaporated by now. Rod |
Thread: Electric motors |
18/08/2023 09:54:51 |
The other variable to consider on 3 phase motors is: how many poles? What are the trade offs between torque and speed? Rod |
Thread: Sanderson Beam |
18/08/2023 09:46:53 |
John, I've sent you a PM. Rod |
Thread: making BLACK chess pieces |
14/08/2023 09:46:57 |
Anthony, your fastenings chess set is utterly charming Rod |
Thread: Hardenable free cutting steel for clock pinions |
13/08/2023 23:57:14 |
Thanks for the comments. My tentative plan is to make a pinion cutter from silver steel backed off with my Eureka tool. My fear is that EN24T may be a bit much for the carbon steel cutter. I note Ifoggy's comments about hardening EN8 and have referred back to a previous thread. I do have a small electric furnace and made Lammas' hardness tester so maybe some experimentation is called for . Or perhaps I'll stick to lantern pinions. The recent talk here on simple clocks has led me down a rabbit hole and piqued my interest for the next project. Rod |
13/08/2023 16:18:35 |
Does anybody have any experience of using EN8M (212M36, 1140) as an alternative to the no longer available free-cutting silver steel for making pinions (or, indeed, anything else)? Cheers, Rod |
Thread: Improve 3-jaw chuck repeatability |
08/08/2023 10:55:27 |
Guys, I think we need to be a little more rigorous with our terminology here. Most 3 jaw self centering chucks actually have good repeatability, it's the concentricity that is variable for different diameters. If you measure the run-out of a piece of round stock, take it out and replace it using the same pinion and orientated against the same jaw then the run-out will measure pretty much the same as before. You can use this property to make an accurate and repeatable split collet bored in situ. In Sonic's case, I assume that he has a 3 jaw chuck that is a trial to remove and re-attach: if so I can understand his pain. In my experience ER collet chucks are not that hard and can be turned with a carbide tipped boring bar so I would mount the hex collet block in the 3 jaw, true up the tapered collet seat using the top slide set to the correct angle using a dti. Mark one of the hex sides so that you know which side goes against which jaw and remember which pinion is used to tighten the scroll. You should now have good concentricity and repeatability. Worth a try I think. Rod |
Thread: Flexispeed Mk/Simat 101 Owners - What Motor Size Are You Using? |
01/08/2023 21:04:06 |
I used a 1/6 HP induction motor on mine. When sizing the pulleys don't forget that the manufacturer's recommended top speed is only 1000 rpm. Rod |
