Removing bang in self tappers
Rik Shaw27/09/2020 17:30:28
1494 forum posts
403 photos
As you might see from the picture the satin chrome on the dial is being scored by debris collecting under the primitive indicator window. I have already replaced the cross slide dial which was heavily marked but it was quite pricey and in order to avoid further expense I intend designing a "window" with a bit more clearance.
So to remove the existing windows I need to remove the two bang in self tappers that hold them in place. So what is the best way - and by the way, are these screws hard? If not maybe I could drill them out with a HSS drill?
Lathe is WARCO BH600G so either Chinese or Taiwanese.
Rik
Steviegtr27/09/2020 17:38:19
2668 forum posts
352 photos
Most of those type of fasteners are of the spiral flute design. Usually clockwise. So in theory they need to be turned anticlockwise. I have a set of damaged nut / bolt removers which would, if you could get a small enough one, do the job. Those pins are usually made from a hard material.
Steve.
Edited By Steviegtr on 27/09/2020 17:39:19
Pete Rimmer27/09/2020 17:39:10
1486 forum posts
105 photos
They are called drive screws. I usually lift them by carefully tapping old feeler gauges under the plate they are holding down. Go slowly and you can raise the drive screw enough to get side cutters under the head.
J Hancock27/09/2020 17:42:19
869 forum posts
Or try to put a ultra thin Dremel cutting disc slot across each one and use a screwdriver on them.
Guess whether a RH or LH spiral.
mechman4827/09/2020 17:57:29
2947 forum posts
468 photos
Posted by J Hancock on 27/09/2020 17:42:19:
Beat me too it as I was typing. Drill & retap for 2 / 2.5 / 3 mm socket cap screws or hex bolts
George
old mart27/09/2020 18:13:09
4655 forum posts
304 photos
Some careful tapping with a wedge with a similar profile to a wood chisel between the head and the plate, not just in one place, but at several positions. Then as the head starts to lift, a blunter wedge and finally they should be high enough to turn. I would expect them to have a right handed helix.
not done it yet27/09/2020 18:22:19
7517 forum posts
20 photos
Tried a pair of pliers? No need to mask the ‘window if you intend changing it. They usually unscrew easily, once started.
noel shelley27/09/2020 18:57:59
2308 forum posts
33 photos
Gentle tapping in all directions will normally loosen them. A very small chisel is ideal for applying the tapping and pliers to unscrew them. plan B, grind 2 flats on opposite sides and mole wrench to unscrew.
Good luck Noel
Phil P27/09/2020 19:00:56
851 forum posts
206 photos
Slotting with the Dremel works very well.
I removed the engine number plate from my Morris Minor engine with that method.
Phil
Clive Brown 127/09/2020 20:00:02
1050 forum posts
56 photos
My Warco 16B mill had nothing as sophisticated as hammer drive rivets holding the index marks. Just aluminium round head rivets seemingly banged in skew-whiff by the youngest apprentice. They were the worst feature on an otherwise well finished machine. When I decided to replace them they popped out easily with a small chisel. i drilled the holes deeper, tapped 7 BA, or M2.5 in new money, and retained the markers with small screws.
Looks much better.
Phil Whitley27/09/2020 20:28:35
1533 forum posts
147 photos
I tap a stanley blade under the head of the screw, or under the plate it is holding on, and they generally come loose quite easily!
Peter Krogh27/09/2020 21:59:17
228 forum posts
20 photos
The best tool I've found is a pair of well made toe nail clippers with edges that are truly flush and straight. The curved ones don't work as well. The edges can be gently worked under the head of the screw and will wedge the screw right out. With some care, drive screws can be removed without marking up the surface. If the flat sides of the edges are polished, and most clippers are, they won't mark.
I replace those things with screws or, on thin material like machinery cabinets, aluminum pop rivets.
Pete
Edited By Peter Krogh on 27/09/2020 22:01:08
CHAS LIPSCOMBE28/09/2020 03:38:05
50 forum posts
I hope I am not taking this topic too far from the thread but these "Drive Screws" are of interest to me because they were used by Powell & Hanmer to secure their badge on motor cycle fittings, including their horns. I make replicas of these horns and have had difficulty in knowing what to buy. I have seen adverts for size 0, 1 etc but no indication anywhere of what dimensions these sizes are. Also ones that I have acquired from autojumbles are all too short or too large in diameter. Is there any convention covering the sizes of these screws or are they whatever size the manufacturer thinks will sell? Currently I use Aluminium rivets with the head diameter reduced for appearance sake and using rivets involves a whole lot of messing around
Chas
Michael Gilligan28/09/2020 07:55:33
23121 forum posts
1360 photos
Chas
I have no idea whether this is a definitive list, but it looks a useful place to start: **LINK**
https://www.rivetsonline.com/drive-screws#1
I remember, when my dad worked for GKN in the early 1960s, there was a wide variety available.
Chris Evans 628/09/2020 08:43:46
2156 forum posts
Memory is fading but I used to buy these to secure our nameplates. I think the brand name was "Titex" With 4 to a nameplate a box of 1000 lasted a long time.
Russell Eberhardt28/09/2020 11:53:24
2785 forum posts
87 photos
I found them easy to remove from vintage cast iron car engine blocks by filing flats on the edges and gripping with a mole wrench to twist them out.
Russell
Ady128/09/2020 13:17:08
6137 forum posts
893 photos
Must admit I struggled with the title for a couple of days, didn't know they existed
Removing the bang in self tappers
...eventually twigged as...
Removing bang-in self tappers
and learnt something new
Brian Wood28/09/2020 15:27:13
2742 forum posts
39 photos
And to complete the information, they are right hand thread
Howard Lewis28/09/2020 18:07:28
7227 forum posts
21 photos
Hammer drive screws are HARD, and will fracture if the blow is sideways on
If it does not break when hammered sideways, it will enlarge the hole, reducing grip when replaced..
Being dome headed, they are difficult to grip, but with a good ole Grip, (Vise Grip etc ) they can, eventually be unscrewed. Patience and some strength is needed.
Can you manage to bend the "window" upwards a little, rather than remove?
CHAS LIPSCOMBE28/09/2020 23:23:29
50 forum posts
Michael G,
Thanks for this info, just what I needed. I stand in awe of your internet searching capabilities
Chas
