Here is a list of all the postings Phil Whitley has made in our forums. Click on a thread name to jump to the thread.
Thread: Approximate cost of filament? |
03/10/2023 10:46:12 |
In the injection moulding industry PLA granule is about £120 a metric Tonne, according to a mate in the industry. when you consider £20 a kilo=£20,000 a ton, it seems to be another case of printer consumables profiteering, Luckily my urge to buy a 3D printer wore off very quickly!! |
Thread: My week this week! My workshop videos |
30/09/2023 20:17:37 |
This video was made with Clipchamp Yes folks, still clipchamp, and still a horrid piece of bloatware garbage that hides everything I want to do behind a wall of bloat that I have no interest in whatever, and apparently microshaft will NOT let you revert to video editor! watch this space! They are asking for feedback, so I am going to give them some!! So what have we this week? an incremental improvement on the pressure washer, and a realisation that it may be the limit of my water systems input that is causing lack of output!! I take on the carb on the Ryobi chain saw and change it from almost running properly to not even firing! Life brings good weeks and bad weeks, and the bad ones shorten your patience, test your temper, and sometimes make you doubt your own ability , but I must remember that, despite my autistic nature, it is not essential to be able to repair everything! Phil, in the East Yorkshire rain forest! |
Thread: Old Parvalux motor not starting properly |
29/09/2023 16:10:22 |
mark all the wires and remove them from the connection plate, remove the two screws from the top of the connection plate and the centrifugal switch may just lift out of the motor, and be able to be examined and cleaned without having to strip the motor! Phil Edited By Phil Whitley on 29/09/2023 16:11:24 |
28/09/2023 10:06:23 |
there appears to be a centrifugal switch in your pic of the connection box, you need to check the contacts are clean and the switch is operating cdorrectly, it sounds from your description that the motor is trying to start, but the contacts, which are closed when the motor is stopped, are not making contact properly and are not allowing sufficient current to flow to the start winding. , Can you see and clean the contacts (with an emory nail board) without stripping the motor? If not you need to remove the rear cover from the motor, not the shaft end. are there three screws in the centre of the rear cover, near where the shaft would be? these are bearing retainers and need to be removed before the end cap will come off! Phil |
23/09/2023 16:51:02 |
Hi All, This video was made with Clipchamp, but it won't be made with it ever again! what an execrable piece of crap it is! Microshaft have disabled video editor, and replaced it with clipchamp which is grossly overcomplex, and doesn't work. It would normally take me about 1-1/2 hours tops to turn raw footage into a video, I started at 7 and now its after 10 and I havent finished yet! Clicked the tab to arrange clips in ascending order, didn't work! neither did descending order! Tried to click in the text box to add screen text, it didn't work, but when you rewatch the video it has inserted "type text here" into the video, and by clicking on the screen I was eventually able to add the text I wanted! Trust Microshaft to take a simple and usefull piece of software that works perfectly and completely screw it up! RANT OVER!! Lots of repairs of kit I have for sale, and a recalcitrant Ryobi chainsaw which I think I got to the bottom of! Unfortunately Keiths wife, Angela is in Hospital at the moment, which means the looking after, cleaning out and feeding of 30 odd dogs has fallen on our shoulders, so I only get an hour or two in the workshop a few days a week! Normal service will be resumed as soon as possible, please bear with me! Phil, in Calm, peacefull and sunny East Yorkshire |
Thread: electrical fault puzzle |
19/09/2023 19:42:07 |
When you converted to led tubes, did you remove the chokes and control gear from the lights, or did you fit the tubes that can be run with the chokes left in? If you did that could well be the problem, and also you will save very little money if the chokes are left in circuit. I think the problem is within the lamps but we do need to know if it is tripping a 6A mcb or an RCD. Phil
16/09/2023 16:24:55 |
Hi all, A short one this week as we got involved in a very dirty and boring clean up operation which I didn't bother filming to save you the drudgery of sitting through it! I got the stairlifts repaired and working, and fixed the spark problem on the brigs and stratton on the little generator, but thats about all Next week we have more grass to cut, a tree to fell, and looking at the weather, more workshop time! Phil, in Autumnal but still warm East Yorkshire. |
09/09/2023 16:33:27 |
Hi All A very hot week in which both field work and shop work get done! Lots of grass cutting with the Fordson, and i got video to prove it! and also some workshop time working on a couple of old stairlifts that are being sold off as a project. a little generator, and I fix the yardcam as well. lots of stuff to interest the eclectic tastes of my viewers (I Hope!!) Hard to get into anything apart from an iced G&T when it's so hot! Phil, in sweltering East Yorkshire! |
02/09/2023 17:03:35 |
Hi All Which indeed? Keith and I went to look at, and bought, a mobility scooter for Angela to ride round the field on so she can get through her very demanding day a bit easier! We ttried it, I rode it, and he bought it, but when we got it home, we realised that it was fine on the flat, but even the slightest incline bogged it down! I have come to the conclusion that it has had the wrong control PCB bodged in some long time ago, not by the guy we bought it off, who sold it in good faith, as I found the screws holding the cover over the PCB were rusted solid. Looking at it from this end, it was a bad buy, we are trying to find a wiring diagram,and the spec of the board that SHOULD be in it! Got the spares for the chainsaw, and fitted them, and it starts, then stops! more attention required! Got the new handle on the pressure wash finished, so I suppose something has gone right this week, and Martyn came over Friday, fitted a couple of security cams for me, and set up the network so that I can view them remotely And I had a ride in a Teswla, and the wildlife cam too, and then he took me for a ride in his wifes Tesla, which ,although he is a complete computer nerd, he hates! Me, being a bit of a prat, forgot to video it, but the acceleration was much MORE than impressive!! Phil, Summer has been switched off in East Yorkshire! |
26/08/2023 16:21:42 |
Hi All Phil, in lovely late summer East Yorkshire. |
19/08/2023 16:45:14 |
Hi All This week I am back in the workshop due to the weather! it has rained on and off all week! The Lovolite rebuild continues, we get a new car for keith due to the Volvos demise, and I repair two faults on the Ryobi chainsaw We did a little field work in final preparation for a much smaller than usual Wicani Jamboree, but were so rushed in between the rain I didn't get much time for filming! Phil, in increasingly soggy East Yorkshire. |
12/08/2023 16:20:04 |
Hi All
05/08/2023 16:16:51 |
Hi All This week a mixed bag! I went to Murton park and Yorkshire Farming museum, and had a ride on the Derwent Valley Light Railway, which was fun, and in good weather too! IOn the field at Wicani Farm we get the kennel base finished, but not before the tractor gets stuck in the mud! The field is so soft it is like driving on wet sponge caker! Due to inclement weather I also get some time in the workshop to begin another lovolite rebuild! Phil, in the East Yorkshire Rainforest. |
29/07/2023 20:13:56 |
Hi All, This week I finally get to the bottom of an ongoing water pump problem on my rainwater recycling system at the workshop! I get it all running beautifully, but don't find anything that I can put hand on heart and say that it was definitely the problem, apart from the old pump being damp internally but still running as long as it was on a non rcd circuit!! I shall dry it out and keep it as a spare. We spent Monday and Tueasday(in the rain) dismantling and transporting another dog run from the next village (2 miles away) to Langtoft and start to level for the base, luckily this is a steel bolt together affair which we will complete next week, and then NO MORE KENNELS!! back onto field work, which means more time in the workshop now that the monsoon has started! The humidity turns us into slow motion workers! Phil, in the outdoor sauna in East Yorkshire! |
29/07/2023 20:03:54 |
Hi All, The Kennels are finished all bar the roof felt, and are fully occupied, so we move on to the Chicken run, then it rained, and rained! July is monsoon season in East Yorkshire! We get most of the chicken run fence completed, and I do some workshop repairs which involve.......water pumps! I manage to get quite wet in the workshop!. Never mind, we are all moving forwards! Phil, in monsoon struck East Yorkshire! |
15/07/2023 16:50:48 |
Hi All, Crazy crazy weather, June was flaming, as its legend goes, and now July is overcast, chilly and wet! We dance between the rain and get in a good week! The roof is finished, the wire is finished, but the rain comes down friday afternoon and we don't get the plastic sheets on. No matter, now we are so close to complete we can taste freedom again! Next week, plastic sheets on, gutter on, and finally felt the roof, but we have to get the felt, nails and compound first! phil, in Damp miserable East Yorkshire |
08/07/2023 16:36:29 |
Hi all! Another week of steamy tropical humidity, not easy to work in, but we had to struggle on! Days missed due to plasterboarding the ceiling at home on Monday, and forgetting my camera Tuesday! We finally move the tenants into kennel #1, and thus free up the last pair of metal bars to complete #3. Friday we finally crack and go to town to buy more fence rails which are our main constructional timber, based on the realisation that we can save much time and sweating by not having to make do and mend with our dwindling supply of 12' lengths! We get a bargain by buying up some "wonky" ones as well at half price, as the chicken run fence steps down a slope so will have to be done with six foot lengths! We may yet need more roof sheets, but we will know that next week! Phil in steamy but glorious East Yorkshire. |
01/07/2023 16:43:37 |
Hi all! A week of steamy tropical humidity, not easy to work in, and we had to struggle on! Days missed due to rain and hospital appointments, But still we persevere! This week we have the luxury of a cameraman for a day, so you get to see me and cousin Keith actually working! If we don't get this project finished by next friday we will both go insane, , some would say it is far too late for that, others would throw there hands in the air and wander off muttering under their breath, I seem to do a lot of muttering lately...... Phil, in the East Yorkshire rain forest, slowly steaming! |
24/06/2023 16:14:33 |
Another very hot week of field work on the kennels, which thank the lord are nearing completion! Now we know the construction method we can get straight on to construction without too much thinking time! Enjoy my cab ride in the engine at the Yorkshire Wolds railway! Unlike most heritage railways, this one has been rebuilt in an empty field where there used to be a railway line from Driffield to Malton, no taking over an existing line and rolling stock fror these true enthusiasts, they started with nowt and have created a railway out of it! Look them up @YWRailway and come for a look and a ride! Tell them I sent you!! Phil, in sweltering Torremalangtoft! |
17/06/2023 17:40:30 |
Hi all! It has been really hot, so if I don't make a lot of sense through the video it is the heat getting to me! 30 deg C on Friday, and we gave up trying to work!We salvaged a load more wood and cleared more mess up to get it! Kennel number 1 is complete less roof, and we are going for a finish in the cooler weather forecast for next week. We are both exhausted! Phil, in sweltering East Yorkshire. |
