Here is a list of all the postings Ady1 has made in our forums. Click on a thread name to jump to the thread.
Thread: I've borrowed a Anycubic Mega S 3D printer, best CAD program? |
04/10/2023 19:55:01 |
You still got your action man stuff? My brothers inherited mine, many fun hours spent with action man |
Thread: Downtime Reading |
04/10/2023 19:33:51 |
I use wiki a lot, reading about anything from Rome (hooligans) to British Battleship development Interesting snippet the other day Bismarck sank the Hood and the Prince of Wales disengaged, eventually returning home where they found an unexploded 15 inch shell in her hull which no-one knew about |
Thread: Wera hand-tools |
04/10/2023 14:10:55 |
One of the interesting things with this tactic is that when everyone else is sold out and you really need a tool or widget there's only one place left to go... and it sits there, taunting you... |
04/10/2023 13:03:39 |
Facom Britool tend to be decent Halfords advanced can be surprisingly durable Had a goose neck 8mm ratchet for 5-6 years which does all my hexes (lots of conversions as well as originals, tool post stuff etc) and never misses a beat |
Thread: *Oct 2023: FORUM MIGRATION TIMELINE* |
04/10/2023 09:45:46 |
I'll see you all on the other side Now all hold hands, close your eyes, and concentrate very hard... |
Thread: Further Adventures with the Sieg KX3 & KX1 |
03/10/2023 19:44:43 |
aha! I was just staring at it thinking omg But 4 hours wasn't so bad, I thought more like 8 Edited By Ady1 on 03/10/2023 19:45:30 |
03/10/2023 19:17:16 |
How long did that take to do Jason? |
Thread: What defines BILLET … |
03/10/2023 09:31:05 |
"Billet" sounds better than "lump" for sales purposes |
Thread: RIP record no 24 |
02/10/2023 18:27:42 |
Must have been a wee bit dodgy anyway, it's usually the leadscrew nut that fails in these high pressure scenarios |
02/10/2023 12:53:09 |
...cue JAWS music... Edited By Ady1 on 02/10/2023 12:56:41 |
Thread: Dedicated Search Engine |
02/10/2023 10:54:39 |
The new 2024 forum will do everything we ever dreamed about, so not needed |
Thread: Britan repetition lathe operation |
01/10/2023 19:38:47 |
You lucky dog, there can't be many nice examples about now. As with most lathes the "extra bits" are important for doing stuff so make sure you've got every little part possible from your mate |
Thread: Help wanted |
01/10/2023 19:32:06 |
The amateurs lathe and various online PDFs and articles will help keep you going |
Thread: Upgrading from a Clarke CL300M, where to go? |
01/10/2023 11:50:28 |
That AMABL210D is only 65KG but has a 38mm spindle bore, 40cm between centres Looks pretty ideal for someone with limited space |
30/09/2023 10:22:42 |
If I was ever to upgrade I would lean towards a big spindle bore Some of the bigger hobby machines can do 38mm which is seriously useful |
Thread: lidl tools 28/09/23 |
29/09/2023 23:53:19 |
They had a load of gear in today, all sorts of stuff There was even a black box plasma cutter/compressor there for £150 with a 5 year warranty |
Thread: Another mess |
29/09/2023 00:19:40 |
I've only done locos in CAD but I wouldn't mess with the geometrics Change one dimension and it's usually a nightmare domino effect If you can MIG then put a small piece into the error zone and tack weld it in 15 or 16 volts 35 Amps In and out, don't hang about, about one to two seconds per tack weld A bit of practice on some scrap first, you can hold the workpiece with a gloved finger The weld will be quite hard compared to the mild steel so tack sparingly, don't lump them in Good Luck |
Thread: boring 20 mm diameter hole in aluminium |
28/09/2023 18:04:56 |
Once you get close with aluminium you can do a high speed single tooth whirry job for finishing, I've done up to 45mm in steel Thing is a hobby lathe is much better for boring bigger holes, a hobby mill will struggle unless you get it just right |
Thread: Colchester Chipmaster |
27/09/2023 19:31:07 |
If you say what the issue is and expand with a picture or two the guys in here are pretty good Edited By Ady1 on 27/09/2023 20:05:46 |
Thread: Wrapping a swept profile around a cylinder in Alibre Atom |
27/09/2023 10:22:49 |
I wouldn't use it for Concorde turbine blades but could be used for writing lettering or any less critical apps The CAD user would need to decide |
