Watford | 23/03/2021 10:40:44 |
![]() 142 forum posts 11 photos | I have a drawer full of stainless steel cutlery and a lot of it, particularly the tea spoons, have become rather (very) stained. It looks like tea may have been the culprit. Trying to remove it I have tried CocoCola but this has made no impression, even after a two day dip. Any recommendations chaps?
Mike |
Dalboy | 23/03/2021 10:53:29 |
![]() 1009 forum posts 305 photos | Buy some denture tablets and pop one in a cup of warm water then stand the spoons in that. We did this with cups as well works a treat until I brought the wife a dish washer which also removes any staining now. No only that but the tubes come in handy as small storage containers. I keep my fretsaw/scrollsaw blades in them |
Frances IoM | 23/03/2021 10:53:47 |
1395 forum posts 30 photos | limescale remover based on phosphoric acid (readily distinguishable by smell)
ETA works well on coffee stains on my now 35yrs old 'plastoc'? (looks like ceramic but isn't) sink - no tea however in my household so no experience here. Edited By Frances IoM on 23/03/2021 10:55:50 |
KWIL | 23/03/2021 10:53:49 |
3681 forum posts 70 photos | Hot citric acid, cleans cups and mugs as well. |
Trevor Drabble | 23/03/2021 11:11:15 |
![]() 339 forum posts 7 photos | Good old common Domestic bleach does it for me . |
Emgee | 23/03/2021 11:18:18 |
2610 forum posts 312 photos | Posted by Trevor Drabble on 23/03/2021 11:11:15:
Good old common Domestic bleach does it for me . Does it for me to, especially useful to get the cups and mugs as new. Emgee |
Ian Parkin | 23/03/2021 11:25:46 |
![]() 1174 forum posts 303 photos | One of the stainless birdsnest scourers works for me |
Mick B1 | 23/03/2021 11:28:53 |
2444 forum posts 139 photos | Drink coffee. Works for me. |
Howard Lewis | 23/03/2021 12:02:04 |
7227 forum posts 21 photos | Bleach (Sodium Hypochlorite ) removes the "protective" film that forms on stainless steel, and stains from tea or coffee as well. (Drinking tea without milk is the worst culprit. Black coffee is marginally better ) It is amazing just how much tannin it will remove from a really badly stained tea pot. Howard |
mechman48 | 23/03/2021 12:09:51 |
![]() 2947 forum posts 468 photos | Denture tablets work well for me; boil some water, pour into container, add spoons + one tablet, & leave until fizzing stops + 10 mins or so then wash /rinse. Works well on stained plastic too. George. |
David George 1 | 23/03/2021 12:48:57 |
![]() 2110 forum posts 565 photos | I had a similar problem with spoons but they had been cleaned with a scouring pad to remove staining. Do I had a great idea when I saw a small bench grinder in Aldy with the guards removed and a polishing mop from Cromwell tools it pleased SWMBO and they looked like new. Note the before and after. David Edited By David George 1 on 23/03/2021 13:00:31 |
Samsaranda | 23/03/2021 13:28:14 |
![]() 1688 forum posts 16 photos | Have a similar problem with stainless table spoons used for cooking, the bowls of the spoons have turned black, this is not a deposit but a colour change in the metal itself. The spoons are always washed in the dishwasher and I wonder is there anything in the chemical makeup of the dishwasher tablets that is the cause, all other stainless cutlery, knives, forks, dessert spoons and teaspoons are unaffected and remain bright as when new. Is it possible that because they are exposed to many different substances when used for cooking processes that chemicals within the washer tablets causes a chemical change to the surface of the spoons, it is only the bowl of the spoons that suffer this blackening, would appreciate any thoughts as to why there is a colour change and if there is a process that could restore them to bright as new condition. Dave W |
not done it yet | 23/03/2021 13:38:32 |
7517 forum posts 20 photos | Tea? Tannic acid and tannins? Not very soluble in acidic conditions. A caustic solution is more likely to remove these types of stain. |
Michael Gilligan | 23/03/2021 14:10:38 |
![]() 23121 forum posts 1360 photos | As no-one has specifically mentioned it yet : We use Milton sterilising fluid [blue bottle, in the ‘baby’ section of your favourite supermarket] ... It removes Tea Stains very efficiently. MichaelG. . https://www.milton-tm.com/en/consumer/products/sterilising-fluid |
duncan webster | 23/03/2021 14:14:23 |
5307 forum posts 83 photos | But will they stir your tea any better after they've been cleaned? Just learn to love them as they are |
Dr. MC Black | 23/03/2021 14:45:28 |
334 forum posts 1 photos | I have used denture cleaner powder to remove tea stains from Stainless steel teapots for years. A small pile of powder in pot, add boiling water to the rim and leave overnight. If badly stained, it may require repeated dose. MC Black |
Bill Davies 2 | 23/03/2021 15:27:06 |
357 forum posts 13 photos | Like Dave W, I have some 'stainless' items that have slowly stained (the French have it right- inoxidable). Steel spoons pressed from sheet have a dark tinge, other stainless cutlery are not affected. Different grades of SS? Also, aluminium pots that have been used for stocks/broths seem to darken. Obviously different chemistry is involved. I shall try citric acid for removing tea stains. When I worked in a factory, not cleaning cups was a mark of honour, boiling water addressed any biological hazard. So perhaps Duncan has it right. But the female householder at my location is intolerant of this viewpoint. Bill |
roy entwistle | 23/03/2021 15:49:07 |
1716 forum posts | fairly strong solution of Bicarb of Soda in hot water. soak overnight Roy |
Georgineer | 23/03/2021 16:32:45 |
652 forum posts 33 photos | To get the deposits from my stainless teapot (which I only do when they get thick enough to start flaking off) I put washing soda in water and boil it on the hot plate. (boiling washing soda is also good for removing paint from metal items, but I haven't dared do it in the teapot.) The blue-black staining on our 'stainless' cutlery didn't respond to chemical treatment, so I did like David George and used a buffing wheel. They polished up beautifully and two years later are still bright. The only problem I encountered was that the wheel was too big to get into the teaspoon bowls, so I did them by hand with Autosol polish. George B.
Bill Davies 2 | 23/03/2021 16:42:57 |
357 forum posts 13 photos | I've also observed that frequently using Cif (originally the pronouncable Jif) tends to create fine scratches, causing teaspoons to rapidly become tea stained again. It seems to contain a soft abrasive (chalk or crushed limestone?) as well as what seems to me to be a strong acid or alkali, from its irritating effects on my fingers. Acid, I suppose, as it claims to remove limestone. But then it can't contain a limestone abrasive, unless activated by additional water. Any chemists here? Bill |
