Here is a list of all the postings Trevor Drabble has made in our forums. Click on a thread name to jump to the thread.
Thread: George Adams 2 1/2" Precision |
03/08/2023 08:57:45 |
James , I believe Tee Publishing , who were the original publishers of EIM, can still supply back issues. |
Thread: Repair a small cast bell |
31/07/2023 15:58:03 |
Simon , Excellent job , well done . Regarding the finish you are wanting , suggest you may find it useful to contact Black-it . No connection with company . Trevor. |
Thread: Uncertainty of Measurement |
22/07/2023 16:10:10 |
Michael , Regarding the purity , would your local assay office be able to help ? There used to be one in Chester . |
Thread: Fretwork spade drills. |
21/07/2023 20:32:01 |
Andrew , Would the pearl drills as sold by Walsh and Son be of interest ? |
Thread: ways protector for my mini lathe |
17/07/2023 09:20:45 |
Arceurotrade concertina covers. |
Thread: Machine Enamel Paint in Small Quantities |
15/07/2023 23:54:45 |
Blackgates sell Phoenix paints and one pack etch primer in tin sizes from 50ml upwards. |
Thread: Boiler makers in 2023 |
13/07/2023 09:01:46 |
Try looking at John Rex Model Engineering web page , particularly their section on steel boilers and their accreditation. They are the ones who organised the Doncaster M.E. shows. |
Thread: Layout Square |
11/07/2023 17:09:20 |
Personally I am extremely pleased with my Axminster Professional Square/Stop , part number102379. It has done all I've ever asked of it , is cheaper , has a brass screw and will accommodate any metric/imperial 22mm-30mm steel rule . |
Thread: Looking for an Electric Jack-Hammer |
30/06/2023 12:47:33 |
Thread: Replacement Bearings - Myford ML7 Motor |
29/06/2023 11:00:53 |
Tim , Assuming you are refering to the white metal headstock bearings , have you tried Quillstar in Nottingham? Also do you know a new assembly of hardened spindle and phosphor bronze bushes are available from Myford ? |
Thread: Small Milling Machines |
28/06/2023 15:04:00 |
Grant , Axminster are presently offering £173 off a small milling machine in their clearance sale. |
28/06/2023 14:53:14 |
Michael , I have a Bauker unit from Toolstation , code no. 68789 , which comes in a fitted case with tooling , and with which I am very pleased . It has easily done everything I have asked of it including breaking up a large concrete slab. It's in the clearance sale at mo , down from £69.98 to £40. |
Thread: Regrinding Milling cutters - worth it or not? |
26/06/2023 21:06:52 |
Would also recommend Abbco in Nottingham , who were originally sited next to the old Myford factory. They are on 0115 9290700. No connection with company . |
Thread: Odd Thread Size |
25/06/2023 23:29:41 |
Chris , Maybe worth having a word with Wilkes Engineering and Machinery, also know as The Vice Works . They manufacture replacement jaws for a number of British vices , so perhaps could supply you with the correct screws. Trevor . |
Thread: Runout - a Definition |
25/06/2023 22:20:15 |
Steve , you may find it useful to raise this question with Coventry Collets Ltd . Trevor. |
Thread: Dremel type bits |
13/06/2023 20:36:36 |
When I had a similar problem ( fortunately just before the Midland Show ) I bought a load of miniature end cutting solid carbide bits from Jenny of JB Cutting tools and they worked a treat . No connection to company . |
Thread: Replying to enquiry from a classified ad |
25/05/2023 20:41:21 |
Many Thanks Jason. |
25/05/2023 16:37:14 |
Jason , Does the txt to which you refer include instructions not to delete it please ? |
Thread: Parallel Machine Files |
22/05/2023 15:34:55 |
Axminster Tools sell swiss Vallorbe parallel files , listed as hand files , depending on what sizes you are looking for . |
Thread: Replacement lathes. Recommendations? |
03/05/2023 11:50:06 |
Tristan , The 600 Group web page is showing they still supply lathes to suit your purposes , though they not quoting any prices . |
