Here is a list of all the postings KWIL has made in our forums. Click on a thread name to jump to the thread.
Thread: London Model Engineering exhibition at Alexandra Palace |
27/09/2023 17:17:10 |
Jason, Quite correct, I used to go there, underground train to 55 The Broadway (London Underground HQ in those days) Nice venue. Before that it was north of Oxford Street. K |
Thread: Acetylene bottles in the home workshop |
06/09/2023 11:26:45 |
Nick, HSE indg 327 dated 2014 states 1 hour (to allow acetone to settle). "Obviously" more than this safer but not required by HSE. Unless you can find a later advice. K
06/09/2023 09:10:43 |
If you transport acetylene cylinder laying down it MUST be stood upright for an hour before use to allow gas to settle. |
Thread: turning a large diameter |
06/09/2023 08:56:18 |
Use DRO . radius is set by X = required radius. X=0 can be anywhere you want off the end of the table. Input Xrad Set cutter diameter and cut on outside, use small incremental steps for Y. When done merely smooth rouugh edge to take off peaks. |
Thread: Nutool spares |
01/09/2023 19:48:13 |
Try Solenttools.co.uk |
Thread: Gramophone Needles, British Made Too! |
20/08/2023 18:39:12 |
When I went to work at EMI in 1954 they were still making springs for wind up gramophones The weathervane on the top of Head Office was of course Nipper |
Thread: Cleaning up internal thread on Bridgeport quill nose cap. |
16/08/2023 19:42:09 |
Posted by Andrew Johnston on 16/08/2023 19:10:59:
The screw is there to stop the collet turning when the drawbar is tightened. Get rid of it and see if that makes any difference. Neither of my R8 mills have the screw fitted. Andrew +1 Took it out of my BPT a long time ago. You should be able to remove any burr by careful use of grinder as suggested by Pete Rimmer. |
Thread: What is this rule used for |
15/08/2023 15:36:27 |
Product Features:
Thread: Brook Compton Motor reverse |
15/08/2023 08:51:22 |
NO, just read Noel Shelley's reply again. |
Thread: Bravo, Prof Carolyn Roberts !! |
09/08/2023 13:06:58 |
Well said, real "horses mouth" information rather than ill informed statements. |
09/08/2023 10:54:48 |
State owned and operated enterprises were/are not the best run either. Too much political interferance. |
Thread: Ball turners. |
09/08/2023 10:51:07 |
Thank you Moderators |
Thread: Positive Response? Aye: Report and Block! |
08/08/2023 19:39:54 |
The Electoral Commission should have been aware of the risk and better prepared. Using DarkSpace for instance, a Cambridge spin out. |
Thread: I like a nice tool but.. |
08/08/2023 10:49:10 |
Hotley, certainly to be admired but using one? It might get scratched! |
Thread: Parting tool recommendation |
05/08/2023 16:13:35 |
3.5 inch PB parted all the way |
Thread: Pack contains 4 servings |
05/08/2023 15:58:32 |
Even your humble breakfast flakes, 30g portion barely covers the bottom (well half way up then) of a normal bowl !! Just wonder how many customers actually take notice of the labels anyway!? Looking at the larger population, they do not care what is printed on the packaging. |
Thread: 1950 Myford |
05/08/2023 11:41:02 |
Posted by MichaelR on 30/07/2023 17:50:18:
I remember a new Myford ML7 for sale in our local ironmongers shop in the early 1960s, and it was grey I viewed that lathe with envy can't remember the price but it was out of my pay scale at that time. MichaelR May 1960 price, basic £63.12. 6 to this you needed to add motor and clutch if required. When I bought my ML7 in the late 50s I think I paid £57 or there abouts, still have it sitting in the corner as an unused heirloom! Good as new. Definately Myford Grey |
Thread: Mystery Gun Part? |
05/08/2023 11:27:24 |
Thank you all, that has added to my knowledge. |
03/08/2023 16:30:17 |
I use the insert type almost to the total exclusion of the plain type, works every time for me, even when used for quiye large diameters. If set correctly they are fine, but being an insert you have to make them work hard. Edited By KWIL on 03/08/2023 16:30:46 |
Thread: Use of coal, oil and fossil fuels |
03/08/2023 14:14:56 |
15K + 35K or more +1K4 Today I saw an article which said that if I went down the heat pump route I could "save" £150+ on my annual bill, well that is a non starter with the interest on the cost rather more than that £150 |
