mick70 | 16/08/2018 11:18:46 |
524 forum posts 38 photos | what's best for sticking soles to shoes? daughter as managed to have front of hers come loose on her favourite shoes.
Russell Eberhardt | 16/08/2018 11:22:11 |
![]() 2785 forum posts 87 photos | Hob nails? Seriously though ordinary contact adhesive works fine for me. Russell |
Gordon W | 16/08/2018 11:24:30 |
2011 forum posts | Depends very much on the material (usually unknown). The last ones I did I used a hot glue gun, still there after a year of hard use. Also have used gorilla glue, works well on leather. Hot glue gun useful for lots of bodge jobs. |
Robbo | 16/08/2018 11:27:52 |
1504 forum posts 142 photos | Hot glue gun has worked for me for partial repairs (toes,edges etc) |
Roderick Jenkins | 16/08/2018 11:34:02 |
![]() 2376 forum posts 800 photos | Shoe Goo is very good. It will even build up worn heels if you make a dam with some insulating tape. HTH, Rod |
Richard Marks | 16/08/2018 11:40:39 |
218 forum posts 8 photos | Evo Stick Serious Glue, worked for me and the wifes shoes. |
Alan Waddington 2 | 16/08/2018 12:14:52 |
537 forum posts 88 photos | Sikaflex or car windscreen bonder......the shoes will wear out before either of those.... |
Hopper | 16/08/2018 12:26:57 |
![]() 7881 forum posts 397 photos | It helps to run the sole and the bottom of the shoe over the belt sander prior to gluing if you can. Just enough to scuff them up so the glue can "key" into the surface. |
Martin W | 16/08/2018 12:31:44 |
940 forum posts 30 photos | I have used Evo Stick and Bostik Clear Contact Adhesive for my good ladies and my shoes. Spread adhesive to both surfaces, leave for a few minutes to get tacky then clamp firmly, especially around the edges, and leave for 24hrs. Has always worked for me. Cheers Martin |
Neil Wyatt | 16/08/2018 18:49:14 |
![]() 19226 forum posts 749 photos 86 articles | I've has Serious Glue and EvoStik both fail on trainers where the two layers of sole have split apart. I imagine too much dust/crud got in the split. Why is it 'name' (Slazenger) trainers don't last any longer than cheapies? Neil |
martin perman | 16/08/2018 19:07:18 |
![]() 2095 forum posts 75 photos | I have specially made shoes for a condition I have and the manufacturers use a glue which seems allows the sole to become unstuck after a year Martin P |
Russell Eberhardt | 17/08/2018 09:55:31 |
![]() 2785 forum posts 87 photos | Posted by Neil Wyatt on 16/08/2018 18:49:14:
Why is it 'name' (Slazenger) trainers don't last any longer than cheapies? They are probably made in the same factory. It's just that one type has the name put on it. I once saw a factory in Malaysia where they were making T-shirts for Lacoste. They were also making unbranded ones on the same line which were sold for just a few pence in the local markets. The price difference isn't a matter of quality but the mark-up made by the brand owner to pay for, amongst other things, their advertising costs. Russell |
Howard Lewis | 19/08/2018 19:23:33 |
7227 forum posts 21 photos | And I thought that I was the only "careful" person on here. "Not tight y'ken, just careful" Yes, contact adhesives seem to to do the job Found that acrylics were too stiff, and soon failed. Howard |
Robin Graham | 19/08/2018 20:32:28 |
1089 forum posts 345 photos | I've not had too much luck with contact adhesives myself, but Gorilla glue (the polyurethane stuff which foams slightly as it cures) works very well provided you don't mind trimming off the excess which squidges out as it cures. Robin |
Mick B1 | 20/08/2018 13:20:27 |
2444 forum posts 139 photos | Posted by Neil Wyatt on 16/08/2018 18:49:14:
... Why is it 'name' (Slazenger) trainers don't last any longer than cheapies? Neil Same reason that Chinese lathes work as well as Myfords etc.... |
Martin Kyte | 20/08/2018 13:47:59 |
![]() 3445 forum posts 62 photos | Titebond PVA works well for clogs. ;o)
mechman48 | 20/08/2018 16:18:20 |
![]() 2947 forum posts 468 photos | Posted by Martin Kyte on 20/08/2018 13:47:59:
Titebond PVA works well for clogs. ;o) Aye; 'appen them clogs did ah 'reet on t' cobbles when I wer a lad an me granda' used t' wear 'em, solid wood, wi' hob nails in t' soles, sum 'ad what we called 'oss shoes on 'em, when walkin' 'cross 'ot sheets in t' plate mill, eeh bah gum them's wer' days them wer
Tim Stevens | 20/08/2018 17:36:13 |
![]() 1779 forum posts 1 photos | Them 'oss shoes was called Clog Irons by them in't know, sithee Tim |
Sherlock | 22/08/2018 21:54:51 |
52 forum posts 11 photos | I've tried many of the stuff listed here, for a sole of some work boots.. All did not hold up too well for a decent enough period of time, So I, Like you was searching for something better... In my research somebody (relative of an old cobbler) swears by a flexible Cyanoacrylate.... Not tried yet, but I intend to.
Gordon W | 23/08/2018 10:53:37 |
2011 forum posts | Just for those trying for the first time- Make sure you have all the clamps and packing etc. ready for use, some glues set very quickly. For best results you will need two or three clamps, packing /pressure pads on sole side, packing on the inside bottom, and packing on the shoe outside top. All depends on the shoe design and the clamps being used. check and test before using the glue. Sorry for egg sucking instructions. |
