Here is a list of all the postings Martin Kyte has made in our forums. Click on a thread name to jump to the thread.
Thread: Brass plate or flywheel casting |
30/09/2023 13:33:12 |
I would say that the disc from an old hard drive would be ideal as a flywheel. regards Martin |
Thread: New workshop, advice required! |
27/09/2023 21:08:21 |
One thing I would consider is splitting it into 2 with a partition to provide a small store room. Depends a little on the shape. My workshop started out as a bigger than double garage but smaller than a treble but with an up and over door on the short side. My store separates the short end door from the main space. The main advantage is you generate more wall space for cupboards shelves and racks etc and with the partition you get to use both sides. The lathe sits on steel bushes extending through the flooring and bolted into the concrete base, everything else just sits on the floor. regards Martin |
Thread: Pear projectile proof pitched parapets |
27/09/2023 20:13:05 |
At the very least you should chuck the pears back. ;O) |
Thread: myford super 7 |
26/09/2023 21:42:16 |
It’s a spindle lock to be used once you have broken the back gear cluster. regards Martin |
Thread: Making aPolishing Mop "Tail" |
26/09/2023 20:19:28 |
Turn the taper. Disconnect the cross slide lead screw so you can push the tool into the job by hand. Set up for screw cutting and make a number of passes from the headstock towards the tailstock. This works for cutting the grooves on Fusees for clocks. You are only mating with a mop after all. regards Martin |
Thread: Will this heater idea work |
25/09/2023 13:53:24 |
Posted by John Haine on 25/09/2023 11:36:41:
Phase change heat storage is the way to go though probably beyond the scope of home construction. https://sunamp.com/plentigrade/
Not sure about the beyond scope comment, there are various companies experimenting with encapsulating waxes for mixing with plaster etc to construct rooms that ‘hang’ at a certain temperature. The idea is that during the day when the solar gain from windows is high the room temperature rises to the point where the encapsulated wax changes phase from solid to liquid. So the room absorbs energy but doesn’t get any hotter. In the evening when the outside temperature drops the reverse happens and the beads give out heat as they solidify and hold the room at a comfortable temperature. The result is less burden on the air con or the heating system and it’s totally passive to boot. regards Martin |
Thread: Project ideas |
23/09/2023 20:21:44 |
You could do far worse than select something from Hemmingway Kits the drawings are clear and they come with full build instructions as well as including all materials and fixings you need. I sometimes ‘do a Hemmingway’ just for being able to machine and not think or order stuff. regards Martin
Edited By Martin Kyte on 23/09/2023 20:22:08 |
Thread: Myford |
23/09/2023 20:17:29 |
They are indeed regards Martin
Thread: Broken toolmakers clamp. |
22/09/2023 19:55:54 |
There are a lot of ‘modern’ hobby targeted toolmakers clamps around of various levels of quality. Generally they all have course threads on the adjustment screws. This nearly always requires the application of a Tommy bar to achieve a reasonable level of grip which tends to lead to over tightening as anything to hand gets used as the bar. The old style clamps have fine threads which as well as leaving more meat on the clamp jaws allow a decent grip by finger tightening. In addition over tightening using a bar tends to strip the thread on the screw rather than breaking the clamp. Making a new screw is straight forward and I would guess that spares would have at one time been available. regards Martin PS I too have broken a cheap machinist clamp but never a second hand old school version.
Thread: Thumb screw |
22/09/2023 08:53:38 |
Make the screw, straight knurl the outside and create the hex socket with a rotary broach. But then I have already made my rotary broach. regards Martin |
Thread: Following from grammar in the MEW 332 thread..... |
21/09/2023 13:23:06 |
If it wasn’t for the ambiguity of language lawyers would have no function and certainly would not be able to bill at the rates they do. 🥴 |
Thread: DROs etc |
21/09/2023 13:17:11 |
I have a DRO on my vertical mill but it’s not really there for accuracy. It allows me to:- 1 Switch between metric and imperial units 3 Drill holes on a pitch circle for flange mounts and for chain drilling 4 Drill holes space along a line at an given angle 5 Add and subtract 6 And finally eliminate the requirement to approach all positions from the same direction to take up lead screw backlash. I would not be without it. regards Martin PS It’s value is huge as a mistake eliminator. Edited By Martin Kyte on 21/09/2023 13:19:12 |
Thread: Gib Adjusters and the English Language! |
21/09/2023 13:04:40 |
Or what’s more to the point when we’re they invented and by whom. regards Martin |
Thread: A Well-Tempered Hybrid Pendulum Clock Project |
21/09/2023 07:45:16 |
Ah you are proving software, my mistake. 👍 |
20/09/2023 22:38:42 |
Posted by S K on 20/09/2023 21:44:15:
OK, I used two channels on my function generator, one at 5MHz for the high-speed clock, and one at 0.1 Hz for the period, and the output is quite stable to 1 LSB (200 ns), which is the minimum error I'd expect to be possible. Awesome! 🙂 Sounds suspiciously like your function generator synthesises the two channels from the same master clock in which case it’s not surprising they stay in synch. Sorry to rain on the party. regards Martin |
20/09/2023 18:29:03 |
Fair do’s SK I was just describing the general principle. How you implement it is a matter of choosing the right hardware. Several microcontrollers allow tuning of oscillator frequencies nothing to stop you setting up something like a Pi Pico for instance to run alongside your main processor to just manage the oscillator frequency. regards Martin |
Thread: Measuring instrument storage. |
20/09/2023 13:17:08 |
Almost certainly temperature swings Gray. Doesn’t have to be moisture in the workshop, wood ‘breathes out ‘ moisture as it warms up. |
20/09/2023 13:13:16 |
I’m sure someone was already doing it.😊 |
20/09/2023 08:04:53 |
Not really what I was suggesting. If you set up two counters to run concurrently clocked by the ceramic oscillator of your processor the first of a period defined by your pendulum opto sensing and the second by the GPS time interval you end up with two numbers. The first is the uncorrected period of the pendulum and the second is a number from which you can determine the rate of the processor clock (count over accurate) time period. The second value can then be used to correct the result of the first to give a high resolution high precision pendulum period. It relays on the processor clock having drift but being stable over periods of 10s of seconds. regards Martin |
19/09/2023 22:55:58 |
If you have a fast clock that drifts slowly and a slow clock that is accurate counting the oscillations of the fast clock using the slow accurate clock gives you a correction factor for when you use the fast clock to measure pendulum period. For example if you had a very accurate 1 sec marker and counted the transitions of a nominal 1 MHz clock and got say 1000007 then your measurement of your pendulum period using the nominal 1 MHz would require a correction of 1000000/1000007. Doing this for every measurement corrects for drift in the fast clock. Would this not be a way of achieving high resolution and accuracy. Just thinking out loud really. Depends really on the way the fast clock varies. regards Martin Edited By Martin Kyte on 19/09/2023 22:57:44 |
