Stainless vs BZP
Thomas Gude | 14/02/2018 13:31:01 |
106 forum posts 26 photos | Hi All, Not really a model engineering question but... what are peoples opinion on self tapping screws for sheet metal - specifically the screw material? My experience is that SS screws are pretty much useless - make the hole too small and they will bind and rip the head or shank off, make the hole correct and it just strips the entire thread, make the hole slightly oversize and it blunts the thread and leaves the screw loose it the hole. Whereas I don't experience this as often with BZP screws. I would like to know if other people's experiences are the same and, if so, if anyone could offer a technical answer to why. (-10 points to the first person who offers the "Chinese Chocolate" trope Thanks |
Martin Kyte | 14/02/2018 13:50:27 |
![]() 3445 forum posts 62 photos | Can you not use spire nuts or some other type of cage nuts.? regards Martin |
Brian Sweeting | 14/02/2018 14:03:43 |
453 forum posts 1 photos | Have you looked at self drilling screws for sheet metal, vast array of types and sizes. Just an example here.... **LINK** |
richardandtracy | 14/02/2018 14:04:20 |
![]() 943 forum posts 10 photos | BZP screws when hardened have a strength of 1200 N/mm^2 minimum. Stainless, if A2 or A4 type has a strength of 800N/mm^2 at best, and possibly down to the 450 N/mm^2 mark depending on the amount of work hardening and temp at which it was work hardened (some are done at high temp to soften the steel, which reduces the amount of work hardening possible). Thus they are considerably weaker and more likely to strip the thread. The other problem is the wretched material has a habit of micro welding (galling) under pressure which produces a very effective weld just where & when you don't want it. Having welded itself to the substrate, something else breaks. And frequently, under sod's law, so does the strong weld that caused the 'something else' to break. So, yes I have experienced it & always try to use BZP. Then slather with paint/goo to stop rusting if outside. Regards, Richard.
MW | 14/02/2018 15:46:46 |
![]() 2052 forum posts 56 photos | The Metric/European method of grading nuts and bolts strength is rather confusing, the American system of grading 1-8 with 8 being the heaviest duty use (industrial/farming machinery typically use these), is much simpler and easier to understand. They also have little dashes around the head of the bolt to indicate which grade to the trained eye. An easy way to get a decent strength screw though is just to look for the high tensile self colour screws. Michael W Edited By Michael-w on 14/02/2018 15:52:33 |
clogs | 14/02/2018 15:52:49 |
630 forum posts 12 photos | I find if I need st/steel screws in the finished item I use a normal self tapper first, well, untill there's a good start then put the st/steel screws in to finish......if that helps ?? clogs |
Mike | 14/02/2018 15:59:35 |
![]() 713 forum posts 6 photos | Same trick with brass screws in wood - cut the thread with a steel screw first. |
David George 1 | 14/02/2018 16:04:43 |
![]() 2110 forum posts 565 photos | It always helps to lubricate self tapping screws I always use RDT tapping grease and if putting brass screws it to wood a bit of wax. David |
larry Phelan | 14/02/2018 16:27:52 |
![]() 544 forum posts 17 photos | Hi Everyone, Just looking at that supplier of self tapping screws,and I see that they also sell hand files. Has any other Member bought any of these files and what are they like,quality wise. I need to replace most of my files,something to do with "Old Age",like myself. |
Thomas Gude | 14/02/2018 17:43:30 |
106 forum posts 26 photos | Martin - no, otherwise I wouldn't be using self tappers. Brian - yes, I have used them before. I find they can be a little tricky when you go up in thickness though. Richard - thanks for the technical explanation. Just read the Wikipedia page on galling and it goes to explain why I spent an hour trying to get a aluminium boss off a shaft the other day! Everyone else - thanks for the tips. I will try some lube next time I'm lumbered with the task of using SS self tappers. |
Samsaranda | 14/02/2018 19:57:58 |
![]() 1688 forum posts 16 photos | Larry, ARCEurotrade sell files that are really good quality for the price, I am in the same boat with most of my files now being well past their use by date. Dave W
Bill Mull | 14/02/2018 20:14:47 |
33 forum posts | I regularly use a type of self tapping screws known as Tek Screws. There are several types for thin sheet to thin sheet and thin sheet to heavier steel and sheet to timber. They are a bit ugly but quick easy and fast to use. And their cheap. Stainless versions available too but not as strong as the plated version imo. |
Wout Moerman | 14/02/2018 21:30:09 |
57 forum posts 2 photos | Excuse me, but what are BZP screws? Is it a type, a make or a material and are they self tapping? Just curious. ... |
Vic | 14/02/2018 21:55:38 |
3453 forum posts 23 photos | They used self drilling screws into RSJ’s at a build where I used to work but they were using dedicated drivers for the job, not plain battery drills. |
Nick Wheeler | 14/02/2018 22:04:51 |
1227 forum posts 101 photos | Posted by Wout Moerman on 14/02/2018 21:30:09:
Excuse me, but what are BZP screws? Is it a type, a make or a material and are they self tapping? Just curious. ... BZP is Bright Zinc Plated. Just basic, cheap fasteners. |
Wout Moerman | 15/02/2018 07:08:49 |
57 forum posts 2 photos | Thanks for the explanation, Nicholas. |
Ian S C | 15/02/2018 10:58:34 |
![]() 7468 forum posts 230 photos | For self tapping screws in sheet metal that need to be removed and replaced often, aircraft inspection panels, spring steel nuts called Tinnerman Nuts are used, these come in a number of types, riveted on, clipped on or loose. My memory of self tapping screws is the number of Philips screw drivers I wore out until I found a brand the retained it's point. The screws we used back in the 60s were cadnium plated steel. Stainless(NO), it work hardens and breaks, they are not as strong as plain steel. Ian S C |
