Member postings for Bill Mull
Here is a list of all the postings Bill Mull has made in our forums. Click on a thread name to jump to the thread.
Thread: Inkjet, Remote printing head info?
18/08/2022 21:00:08
I used inkjet machines with a remote printhead in previous jobs , printing on paper, cardboard and plastic food packaging .
The technology I used was called CIJ (continuous ink jet) , the ink and a solvent was mixed in the machine and pumped to the remote printhead ( 2-10 metres away) ,where a piezo nozzle turned the ink stream into droplets which were then electrically charged.
An electrically charged deflector plate then directed the ink droplets into text and onto the print substrate .
Any unused ink drops were deflected into a "gutter" and returned to the control unit by vaccum to be reused.
The machines were designed for continuous industrial use and even basic units were expensive to buy , €7k approx .
Linx and Videojet were the machines I used.
I have seen handheld inkjet printers used on cardboard and similar packaging and had a demo of a Reiner handheld inkjet printer which may be more suited to your application but still quite expensive.
Thread: Clutch pedal servo
29/07/2022 14:08:37
Thanks for the interesting response everyone, I had thought of changing the master cylinder diameter but the master cylinder is fitted in a pretty awful location under the dashboard on the cab bulkhead , access is terrible.
That's why the idea of a remote servo appeals to me as there is plenty space under the cab to mount the servo unit and access to the clutch slave cylinder is fairly straightforward .
I ve been reading up on this online today and it seems to be a common modification to older land rovers which appear to suffer from heavy clutch pedals , I have discovered that there are different servo " boost" ratios 1.65. 1.9 2.3 etc. , I would guess the more boost the better in this application
28/07/2022 20:56:13
Hi All,
I thought this might be a good place to ask about a query that came up in discussion with a colleague,
He has a tractor with a hydraulically operated clutch, a traditional style master cylinder to slave cylinder on the bellhousing arrangement . The issue is that the clutch pedal is very heavy and always has been, it seems to be the way with this model tractor.
This got me thinking , would a brake servo device help to reduce the pedal effort required? I remember remote brake servo kits being advertised in 1970s car magazines ,the Girling Powerstop being one unit I remember.
Does anyone have first hand experience of such devices and is there any reason why a remote add on brake servo unit wouldn't work in a hydraulic clutch application?
Thread: Axial piston air motor
06/07/2022 23:31:30
It looks pretty neat, let us know how it works, maybe try using lubricated air ? The mist of oil in the air might help it to run smoothly.
Thread: How is DC1 ?
02/04/2022 23:26:49
Hi David,
Welcome back, it's good to hear from you.
This is the second time today that a member on forums that I frequent has reappeared after an extended absence.
It must be the time of year or maybe I m spending too much time on forums!!
Looking forward to hearing more about your Myford, All the best,
Liam
Thread: Skynet is Coming
21/02/2021 00:45:11
Posted by Mike Poole on 20/02/2021 13:28:17:
Despite the denials it's difficult to believe that Alexa, Siri and Cortana are not listening in 24/7. The coincidences of discussing something completely random and then being confronted with a connected advert next time you are online are becoming too many to be chance. It’s funny how things that we see no requirement for slowly become desirable and then essential. The internet is still not present in every home and this is not just due to people who feel they are too old to learn something new, my contemporaries are in their early to mid 60s and there are some who have still not embraced smart phones and the internet, of course there are people who simply can’t afford the costs involved and some who simply prefer not to be connected. I once owned a substantial but by no means huge collection of LP’s and then CD’s I gave most of the LP’s to a vinyl junkie and ripped all my CDs to firstly a Brennan then to a NAS drive and SONOS network. My sons consume media from Spotify and Netflix and thus don’t have piles of hard media to store. I am slowly being tempted to subscribe to Spotify but I still have an affection for some music from my pub rock years that is unlikely to be online so other sources will be needed.
I thought something like this only last week, with my phone in my pocket, I was showing an apprentice how to grind a tungsten for Tig welding. The next time I looked at Google an ad for a tungsten grinding machine pops up....
Skynet is definitely coming, I remember thinking that a few years ago when watching the Terminator show at Universal studios shortly before Universal shut it down.
Despite the show being 21 years old at that stage I thought it was never more relevant
Thread: Automatons
29/01/2021 13:32:46
That's fascinating.
Thread: Oil proof brush?
25/12/2020 21:04:24
Posted by Ian B. on 18/12/2020 11:17:47:
Agree SOD. Even PTFE will leach some particularly nasty stuff in the right circumstances. We had to change all the massive insulators in reactive ion etch machines to cross linked polyester (1" thick plate stuff) because of this. And I am very wary of using VITON 0 -rings for anything these days. They are extremely heat sensitive. they leach hydrofluric acid at fairly low temperatures and yeah I got burned. Problem is they were the only polymers that did not out gas at the pressures we were pumping down to. Add heat and BINGO.
Ian, that is interesting regarding the viton o rings. I remember hearing about potential dangers of working on equipment containing viton which had been exposed to high temperatures or fire.
Thread: Self tapping sheet metal screws
14/02/2018 20:14:47
I regularly use a type of self tapping screws known as Tek Screws. There are several types for thin sheet to thin sheet and thin sheet to heavier steel and sheet to timber. They are a bit ugly but quick easy and fast to use. And their cheap.
Stainless versions available too but not as strong as the plated version imo.
Thread: Recommend T handle metric key set
31/01/2018 22:28:50
Facom or Garant make very good T handle sets
Thread: Pickling Stainless Steel
20/12/2017 12:57:22
I stopped using pickling paste a while back and moved to using an electrolytic weld cleaning system called Weldbrush. It works great leaves a nice shiny finish on stainless steel.
Thread: How long does it take you to make stuff?
12/11/2017 22:25:13
Joe,
I d love to know more about that Large Droplet Spray coolant Applicator you made.
I have an application for something similar at the moment.
Liam
Thread: The death of Diesel?
01/11/2017 12:39:42
An old one but still fairly relevant,
https://youtu.be/pzFiRsJQvqc
Thread: John Stevenson
21/10/2017 00:04:23
Get well soon John, there's lots more bodging to be done
Thread: Clean coolant system for indoors?
10/09/2017 13:57:03
Last company I worked for used Castrol Alusol exclusively, It was a great performer but I found the chemical type smell from it gave me headaches. Current employer uses Castrol Cooledge which doesn't smell as strongly. As an aside, when I visited John Deere s vast transmission plant in Germany a few years ago they used no coolant on most of the CNC machines. When I asked the engineer tour guide, she replied that coolant was too much of a mess and they didn't bother with it !!
Thread: Harrison L5's
27/08/2017 22:48:07
Hi all,
Now I ve got space for a workshop I ve been keeping an eye on the classifieds for a lathe.
I' be seen several Harrison L5s for sale for reasonable prices, usually much cheaper than Colchesters or other brands.
I know the L5 is an old lathe at this stage but are they a decent home workshop machine?
From research online I notice some versions have limited spindle speeds and an unusual chuck fitting.
Anyway your opinion is welcome.
Thread: Chinese Electric Cars
20/08/2017 22:39:18
The gas turbine trucks mentioned may have been a Leyland product.
They had a few in experimental fleet use in 1968/70.
On Electric vehicles, it may be of interest to know that battery commuter trains operated in Dublin from 1931 to 1949 approx.
They had a range of 136 miles and operated at 55 mph. They were recharged at night using surplus hydro generated electricity .
Drumm Battery trains. https://youtu.be/p9jFA3fKG6c p class="SmallText">Edited By Liam Mulcahy on 20/08/2017 22:39:46
Edited By Liam Mulcahy on 20/08/2017 22:40:25
Edited By Liam Mulcahy on 20/08/2017 22:43:42
Thread: Echoes from the oil country
04/07/2017 13:19:20
Thanks Guys.
Brian ,I ve found volume 1 on eBay via bookfinder.
Thanks again
04/07/2017 08:43:48
That book is about Clessie Cummins ?
I remember reading extracts from it on Google books.
Another interesting one on diesel technology is " A Square deal all round". History of Perkins engines of Peterborough.
03/07/2017 22:32:56
I ve heard about a book or series of books called " echoes from the oil country" telling of life as a jobbing machinist in the Pennsylvania oil fields.
Is it worth a read? I ve had a look about but the only copies I can see are available from the US , the book is reasonably priced but the postage is crazy.
Anyone know of copies from the UK ?
