Martin King 2 | 08/02/2018 12:20:52 |
![]() 1129 forum posts 1 photos | Hi all, This weeks oddity from a tool lot: Seem very well made and has been hardened and ground. Perhaps not a tool but a part of something? Any thoughts please? Cheers, Martin |
mechman48 | 08/02/2018 13:01:53 |
![]() 2947 forum posts 468 photos | looks like item off something... ratchet, release mechanism, foot operated lever off a brake press of some type, over speed trip mechanism from a turbine... to guess a few ? |
Marischal Ellis | 08/02/2018 14:01:03 |
77 forum posts 27 photos | Hammer head for several applications in certain order. Oops |
not done it yet | 08/02/2018 14:08:28 |
7517 forum posts 20 photos | Foot operated process switch of some sort. |
Mick B1 | 08/02/2018 14:42:26 |
2444 forum posts 139 photos | Trip lever out of a machine tool or artillery piece. |
Roderick Jenkins | 08/02/2018 16:06:19 |
![]() 2376 forum posts 800 photos | The long arm is reminiscent of an iron for holding down a (wood) plane blade, possibly pivoted around the hole and tensioned by a jacking screw under the short arm. Nothing like it in Salaman though. Rod |
Rik Shaw | 08/02/2018 16:07:27 |
![]() 1494 forum posts 403 photos | "Ratchet" stop with handle for engaging / disengaging from toothed gear. Very large clock?? Rik (Martin - you will need all your marketing talents to aim this in the right direction - "paperweight" is my best |
Martin King 2 | 08/02/2018 16:52:42 |
![]() 1129 forum posts 1 photos | Hi All, I think I get the general gist here Clearly I have not found a hitherto unknown masterpiece of English planemaking by NORRIS. I have to ask as sometimes the unkown to me is blindingly obvious to someone on here and the item now destined for the scrap box may have been of use to someone and thus possibly of some value. This may be a good time to ask if it really is OK for me to post like this or do people feel that I am wasting time and bandwidth. I fully own up to the fact that I buy and sell items and am therefore guilty using this forums knowledge resource to further my own interests at times. If it is felt generally that this is not on please let me know. I do read the build threads on here voraciously and glean all I can to improve my own machining skills which I enjoy immensley. Cheers all, Martin |
Journeyman | 08/02/2018 17:07:36 |
![]() 1257 forum posts 264 photos | Posted by Martin King 2 on 08/02/2018 16:52:42:
This may be a good time to ask if it really is OK for me to post like this or do people feel that I am wasting time and bandwidth. I fully own up to the fact that I buy and sell items and am therefore guilty using this forums knowledge resource to further my own interests at times. Cheers all, Martin I for one think it is quite interesting to see some of your finds. Amazing what people throw out in boxes! As to the item above I would go for a machine part, some kind of trip mechanism where a cam runs on the end of the longer arm. Almost like a bit of a Corliss engine valve gear. John |
Michael Gilligan | 08/02/2018 17:14:17 |
![]() 23121 forum posts 1360 photos | Posted by Martin King 2 on 08/02/2018 16:52:42:
This may be a good time to ask if it really is OK for me to post like this or do people feel that I am wasting time and bandwidth. I fully own up to the fact that I buy and sell items and am therefore guilty using this forums knowledge resource to further my own interests at times. . Keep it up, Martin You are open about what you're doing, and the puzzles are often interesting. MichaelG. |
Rik Shaw | 08/02/2018 18:48:00 |
![]() 1494 forum posts 403 photos | "If it is felt generally that this is not on please let me know." Keep going Martin - 'tis nice to hear from darkest Dorset! Rik |
I.M. OUTAHERE | 08/02/2018 19:05:15 |
1468 forum posts 3 photos | Sure beats the "What lathe / mill/ drill or any other common workshop tool should i buy " threads that pop up on a mothly basis ! |
Martin King 2 | 08/02/2018 21:11:21 |
![]() 1129 forum posts 1 photos | Thanks guys, will keep digging around then! Martin |
Clive Hartland | 08/02/2018 22:15:31 |
![]() 2929 forum posts 41 photos | The item is reminiscent of a sear or part of an interupptor mechanism. most likely from a machine gun? Clive |
Jon Cameron | 08/02/2018 22:45:47 |
368 forum posts 122 photos | Maybe it's a fancy scraper To me it looks almost like a foot pedal though it's too small the large flat been a stop under floor level. The opposite flat acting the master cylinder. The fancy shaped bit at the top to hold the rubber pedal. |
Ian S C | 09/02/2018 10:42:40 |
![]() 7468 forum posts 230 photos | My guess, the ratchet pawl for a shaper auto feed. Ian S C |
David Standing 1 | 09/02/2018 12:11:41 |
1297 forum posts 50 photos | I like the brain teasers too. It often comes down to digging deeper and quicker in Google than MichaelG
Tim Stevens | 09/02/2018 12:40:35 |
![]() 1779 forum posts 1 photos | Might it be part of a 'hit and miss' governor mechanism, as found on stationary engines (etc)? Cheers, Tim |
norman royds 2 | 09/02/2018 13:03:08 |
48 forum posts | I it think it some thing part of printing machine norm |
Michael Gilligan | 09/02/2018 14:53:06 |
![]() 23121 forum posts 1360 photos | Posted by David Standing 1 on 09/02/2018 12:11:41:
I like the brain teasers too. It often comes down to digging deeper and quicker in Google than MichaelG . That sort of 'back-handed compliment' gets rather tedious, David. I'll be grateful if you would desist. MichaelG. |
