Here is a list of all the postings norman royds 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: cylinder oiling drillings and Tangye mods |
24/08/2020 13:46:55 |
wanted helping to find drawings for 3 inch RANSOMES COMPOUND 6.N.H.P.TRACTION ENGINE thankyou for any help i will pay any cost incurred |
Thread: ransomes sims jefferies |
08/06/2020 22:32:59 |
Thanks you Jason I have been on internet to night and found site called steam scenes.com found a lot information on the ransomes 6 hp thank again Jason regards norm |
06/06/2020 15:42:02 |
I recently bought some traction engine casting wheels boiler for ransomes 6HP compound traction engine but no paper work and now the problem trying identify right engine the rear diameter is 17 7/8 but I having problem trying find the right drawings in the right scale and would appreciate help and information thankyou for any help yours norm |
Thread: BBC Micro Boxford TCL125 |
05/04/2020 22:06:30 |
Hi graham been trying to get information on the boxford and would appreciate any help and information my email address [email protected] regard norm |
Thread: Sealing circuit boards with silicone |
02/03/2020 11:56:38 |
I would sugest silicon for fish tank I think it is acid free norm |
Thread: Unimat SL Circular Saw Arbour |
15/02/2020 16:20:00 |
the dimensions are overall is length 55 mm diameter19 mm and there is collar the first measurment 45 &half mm & the second is 50 mm and collar dimensions 25 mm & size of peg on the front 16mm &the length 5mm the front is threaded the same as the spindle and at the front is tapped 8mm &there is a recessed washer I hope this helps regards NR |
Thread: Apologies for raising this again |
19/01/2020 15:12:41 |
I look for a picture on your forum whit no picture.i would suggest fitting boss where it fits to engine trying to keep it central better if there was hole in centre of the flywheel to work from. and grip in four jaw to centre. but remove the teeth with anglegrinder |
Thread: Heatshrink tubing |
23/12/2019 15:08:32 |
sorry for any confusion. me as old fellow my smart phone is like crystal ball I speak in to it ha presto loads useful information appears. for many years reading books I now ask my phone and up to now it seems to no the answer regard norm |
20/12/2019 22:18:19 |
if you have smart phone try wish +lot off useful stuff regard norm |
Thread: Heartbroken! |
16/08/2019 20:41:09 |
the chemical I use is hydrochric acid it dissolved carbon taps the problem is tirying to buy these days regards norm |
Thread: Removing a grub screw |
16/04/2019 12:47:01 |
method I used in the past is to find a small threaded bolt about the same size as allen key and tap into the hole not to hard and gently tune it out used to work on old motor bikes allen screws regards norm |
Thread: Inverter drives for single phase motors |
08/04/2019 22:00:43 |
I have a brook Crompton parkinson range mater inverter v220/240 input output 370 w I bought board with dc controller and a single phase inverter and single to 3phase so do not know what it was for but it looks very complex for a fan regards norm hope this helps you |
Thread: Is there a way to mask silver solder |
08/04/2019 18:59:37 |
nicrobraz I have a bottle the label is very faded all I can make out green stop off type 11 wall colmonoy ltd but had quick look on inteweb and the company is still going regard norm |
Thread: Chipmaster question |
12/01/2019 13:50:09 |
No look on Yahoo page seems to be out off use .I have tow manual but no technical information I look on ebay and the manual look the same has so back you hope you can help me regards norm |
11/01/2019 21:13:46 |
thankyou I will have a look on yahoo regard norm |
11/01/2019 18:56:50 |
I ALL having trouble with my Colchester chipmaster clutch is slipping but I don't think it is the clutch there is a lot end play in the shaft it self and the clutch housing .and there is no information in the manual that I bought from tony Griffiths or in manual that came with it .so is there anybody out with the information that can help me there must be some worn parts or bearing I thought it was the variator but I have changed the oil in variator . thanks in advanced for any information regard nome |
Thread: Colchester chipmaster rebuild |
13/09/2018 12:33:15 |
I adam good work on the Colchester I need some information were did you get oil for variator. I from .I tried to find oil off the internet but luck regard norm |
Thread: Silver soldering contradiction |
12/04/2018 12:52:59 |
on understanding gap when silver soldering is when doing boiler tubes I dill then ream till i just get movement the tube moves no visible gap but I get perfect joint the fact is no visible gap but movement because there is clearance plus the flux in all joint must give clearance regards norm |
Thread: DC motor controler ? |
20/03/2018 18:50:08 |
The one I am using is cheetah SME 2HP input 110 /220 240 ac 16 AMPS 50/60hz output ;0.90/0.180v dc 11AMPS so it give somewhere to start carl hope this some help regards norm |
Thread: Bench grinders and their dust |
26/02/2018 12:40:14 |
Good idea ouballie you have me idea how to used old speaker magnets norm |
