Eddy Curr | 05/11/2017 05:07:29 |
39 forum posts | Whether or not your region experienced a Daylight Savings time change this past weekend, consider servicing the smoke & carbon monoxide detection sensors you have on site, along with the extinguishing equipment located around the premises. Take a moment to use a voltmeter to check smoke detector batteries. Also to upend fire extinguishers to rap them on the bottom several times with a rubber mallet or something similar to shake loose settled retardent as well as to review when the extinguishers are next due for service/inspection/replacement.
clivel | 05/11/2017 07:24:11 |
344 forum posts 17 photos | Excellent advice Eddy, thank you. As for our change over to winter time (or should that be standard time) in a few hours, that is not something I am looking forward to, especially as there is no way of getting the dog to understand that her stomach has got the time wrong so she will need to wait an extra hour for breakfast. Clive
Edited By clivel on 05/11/2017 07:24:56 |
KWIL | 05/11/2017 10:02:19 |
3681 forum posts 70 photos | The further South you are, the less relevant. but go North a little and it is important. |
Neil Wyatt | 05/11/2017 10:09:15 |
![]() 19226 forum posts 749 photos 86 articles | Why do we use altered time in the summer, when daylight is abundant, and not the winter when it is in short supply? |
Bazyle | 05/11/2017 17:21:12 |
![]() 6956 forum posts 229 photos | How about a design in MEW for a tool to save it in the summer for use in the winter? |
peak4 | 05/11/2017 18:38:38 |
![]() 2207 forum posts 210 photos | If you're on dry powder extinguishers, the best way to check for compacted powder is to upend it and place your ear against the cylinder. You will hear the powder falling; just make sure you don't knock the safety pin out when you're testing, as it gets messy very quickly.
Bill |
Samsaranda | 05/11/2017 18:49:24 |
![]() 1688 forum posts 16 photos | I am all for keeping the time here to GMT, we have 5 cats and when the time changes they can be very persistent in their efforts to wake you up in the mornings as they are convinced we have overslept. Takes them a while to adjust to the new times but then six months later we do it again just to confuse them. Dave |
Ian Hewson | 05/11/2017 18:58:16 |
354 forum posts 33 photos | Best advice is to change the batteries every year, not just check the voltage. Try living further north than Watford and then you will see why the clocks are changed, I remember them trying it in the 80s, didn’t get light till well past 9,00 on a good day. |
Nige | 05/11/2017 19:58:24 |
![]() 370 forum posts 65 photos | The amount of daylight available each day , the time between sunrise and sunset, is known well in advance. With the technology available to have clocks in your home controlled by radio signals why not have clocks and watches changed every night such that mid day always falls in the centre of the time between sunrise and sunset ?
Michael Gilligan | 05/11/2017 20:27:33 |
![]() 23121 forum posts 1360 photos | .Posted by Nige on 05/11/2017 19:58:24:
The amount of daylight available each day , the time between sunrise and sunset, is known well in advance. With the technology available to have clocks in your home controlled by radio signals why not have clocks and watches changed every night such that mid day always falls in the centre of the time between sunrise and sunset ? . For the same reason that they 'standardised' time in the first place. e.g. The natural time in Bristol differs by about four minutes from that in London. ... Railway Timetables only became a realistic proposition with the adoption of Time Zones. MichaelG. . Oops ... my memory must be failing me ... this reckons about ten minutes https://www.flickr.com/photos/brizzlebornandbred/2080844004 Edited By Michael Gilligan on 05/11/2017 20:43:22 |
Mark Rand | 05/11/2017 22:29:36 |
1505 forum posts 56 photos | Just bloody well get up earlier in the mornings when it's light. it works very well, ask any farmer. |
Michael Gilligan | 05/11/2017 22:50:41 |
![]() 23121 forum posts 1360 photos | Posted by Mark Rand on 05/11/2017 22:29:36:
Just bloody well get up earlier in the mornings when it's light. it works very well, ask any farmer. . Well said, Mark I never could see how playing with the clocks gave any 'Daylight Saving' ... It's just a con, played on the gullible. MichaelG. |
NJH | 05/11/2017 23:11:39 |
![]() 2314 forum posts 139 photos | Well I'm all for GMT / BST changes - adds a little variety and excitement into an otherwise dull schedule........... Norman |
Russ B | 06/11/2017 00:24:52 |
635 forum posts 34 photos | This reminds me....... my main powder extinguisher's lost pressure. Where (assuming you do) do you take these extinguishers to get checked and filled. It's a modern, good quality extinguisher with refill port etc, not a cheap jobbie |
Sam Longley 1 | 06/11/2017 07:55:06 |
965 forum posts 34 photos | Posted by Michael Gilligan on 05/11/2017 22:50:41:
I seem to recall that some time ago we had a year when we did not make the adjustment as a national experiment. There was a nationwide complaint & one objection was on the grounds of safety concerning children traveling to school in the dark. By putting the clocks back they could travel in better light which was considered safer.
The following year it returned to daylight saving as it was considered a general consensus, even though it was not put to a vote. So perhaps your comment may be considered without foundation Sam Longley Edited By Sam Longley 1 on 06/11/2017 08:00:24 |
Michael Gilligan | 06/11/2017 08:27:16 |
![]() 23121 forum posts 1360 photos | Posted by Sam Longley 1 on 06/11/2017 07:55:06:
The following year it returned to daylight saving as it was considered a general consensus, even though it was not put to a vote. So perhaps your comment may be considered without foundation Sam Longley . Sam, I tried [by specifically referencing 'Daylight Saving'] to be clear ... but evidently I failed. All that is required to let children travel in daylight is for them to travel at an appropriate time of day. The indication on the clock is totally irrelevant; and the gullibility I commented upon refers to the very nonsense that you have just mentioned. ... How can people believe that changing the indicated time makes any real difference ? MichaelG. . P.S. The Military, and Aviation worldwide, seem to manage perfectly well without changing the clock: https://greenwichmeantime.com/info/zulu/ Edited By Michael Gilligan on 06/11/2017 08:47:08 |
Mick Henshall | 06/11/2017 08:55:56 |
![]() 562 forum posts 34 photos | As a qualified fire equipment service engineer in a previous life my personal preference is for Co2 and AFFF ( acquiesant film forming foam) they will cover any fire you are likely to have in the home or workshop, never liked powder myself,if let off accidently or on a small fire it reduces visibilty, is not good for the lungs and will get into and ruin computers etc, this is my own opinion Regards Mick |
Mike Poole | 06/11/2017 11:08:18 |
![]() 3676 forum posts 82 photos | When I worked 12 hour shifts from 6am-6pm in a large factory, if I didn't go outside in the day I wouldn't see daylight for 4 days no matter what the clock said. Mike |
Mick Henshall | 06/11/2017 12:00:47 |
![]() 562 forum posts 34 photos | If you only go out at nights and have no reflection there could be a problem 😎 Mick |
Gordon W | 06/11/2017 12:11:06 |
2011 forum posts | I hate the clock changes, no need at all for it. And if you think you have problems feeding cats at the wrong hour try feeding pigs, they go mad 10 mins out of time. |
