Member postings for Mark Rand
Here is a list of all the postings Mark Rand has made in our forums. Click on a thread name to jump to the thread.
Thread: digi phase converter for 10 machines.....
04/10/2023 19:29:32
Posted by Dave Halford on 04/10/2023 16:17:58:
Posted by Mark Rand on 04/10/2023 13:26:40:
Posted by Robert Atkinson 2 on 04/10/2023 01:58:13:
So they say to use a 71/2 HP inverter for a 2 HP motor i.e. > 3 times de-rating.
Whatever. The voice of hypothesis obviously trumps the voice of experience...
And the voice of hypothesis is of course the voice of the equipment supplier who ought to know what he's selling and why he's saying it.
Sorry, but the 7.5 hp Teco that is used has a rated output of 10.1kVA. with a 50% overload capacity for one minute on top of that. If you assume a 3 times rated current starting current, then you end up with the 7.5hp unit being happy to start 6.75hp motor.
That's my last post in this thread...
04/10/2023 13:26:40
04/10/2023 01:21:00
3 times load with a 50% overload capability gives a 2 times de-rating for the drive, which is what they specified. No one using this sort of drive is going to be driving a Lumsden grinder or similar.
Edited By Mark Rand on 04/10/2023 01:24:06
Thread: *Oct 2023: FORUM MIGRATION TIMELINE*
04/10/2023 00:52:27
Posted by Andy_H on 03/10/2023 21:02:02:
Wow. This made me smile or perhaps I should say wince. If migration plans for the systems I work with involved an outage to end users of up to 7 days.... Let's just say I wouldn't still have a job! wink
Andy
Yes, but the difference is that our users (or their bosses) were paying us!
Edited By Mark Rand on 04/10/2023 00:52:56
Thread: Guy Lautard - spherical turning
04/10/2023 00:42:09
The relevant article is in Guy's (first) machinist's bedside reader.
03/10/2023 08:57:57
Posted by Robert Atkinson 2 on 03/10/2023 01:11:30:
The Drives Driect unit linked to by Mark Rand does not provide a neutral as standard. It requires an optional "neutral generator". Presumably a star transformer of some type and not just a resistor network. It also requires additional filters for some machines. Perhaps the unit you have included these. Unsurprisingly DD do not publish enough information to determine exactly what modifications they have done. Possibly none other than underrating it and setting for no or a very fast turn on frequency / voltage ramp. They certainly know how to charge for them though.
They now seem to sell only throgh ebay (odd for a "direct " company...) and currently don't list the required neutral generator or filters on ebay.
The 3-4 times underrating means that the 71/2 HP £3800 converter is not big enough for the OP task of a 4 HP load. He would need a 12 to 16 HP which may not be available. The 71/2 HP is stated as needing a 40A input supply so the larger one will presumably need a 80A feed, well above the OP's supply capacity.
Robert.
Where are you getting the 3-4 times unde-rating from??? The Teco VFDs that DD use have a 150% for 1 minute overload rating. DOL Starting a 4hp motor from a 7.5 hp rated VFD is no problem. The 'extra work' that DD do is to modify them to use a voltage doubler rather than a three phase bridge rectifier. I don't know whether they uprate the smoothing capacitors, but they might.
I do use a sine wave filter and delta/star grounded neutral generating transformer with mine, because I was already using them with a second hand Danfoss 23kVA VFD that I had used in the same role. That one was fed from a single phase step up transformer. But, in fact, very few three phase machines need the neutral, just a ground connection.
I have also re-programmed mine slightly and connected a time delay relay to the run signal contacts. This is so that it can live happily in the electronics/computer cupboard in the shed and automatically start when powered up from the switch on the wall. The VFD which gives variable speed for the dust extractor is similarly connected, but with control via a switched potentiometer.
I think that Clive and my experience of using the things trumps scare stories made from whole cloth...
Edit to add:-
I do wish that I had gone with Western Power Distribution's 2005 quote of £1.400 to replace the house's single phase supply with three phase. Trouble is that building the shed had already put me deeply in debt (it cost more than the bl***y house did!). Had I done that, I could plan for more solar panel/inverter capacity than now and for a fast charger for if we live long enough to get an EV. I did run 3ph cable from the breaker at the supply entrance to the shed, so that bit's done.
I might still do it at some time in the future, but only for the latter needs. The shed doesn't absolutely need it now.
Edited By Mark Rand on 03/10/2023 09:13:13
02/10/2023 17:43:59
With 45Amps, you aren't going to get more than about 7hp. Drives Direct are egregiously overpriced, but they do source and modify a suitable device to make it do the job in a plug and play fashion. There aren't at all many 240-415V drives about because it's a tiny market segment. They seem to have almost given up selling off their own web site and do it all via fleabay nowadays.
This is what I've got and it does the job with my workshop. Max individual load for me is 2 1/2hp, but I do end up running a couple out of the five machines 3ph at a time reasonably often.
Edited By Mark Rand on 02/10/2023 17:46:12
Thread: lidl tools 28/09/23
30/09/2023 09:56:14
Posted by Benedict White on 29/09/2023 11:51:32:
Mark, you appear to be confusing the digital callipers which are £9.99 (mine takes a 2032 rather than the little cell ones which are useless so is a good buy) with the metric micrometer/compass/spring balance which are all £6.99
See here.
Bangs head against wall crying
Yes, I was misreading the original post.
Bangs head against wall again for good measure...
Thread: TCMT VS CCMT
29/09/2023 11:58:05
Posted by petro1head on 29/09/2023 11:25:11:
Did not know that, got a linkbto one please
Examples would be these:-
Thread: Raspberry Pi 5
29/09/2023 11:49:55
Posted by Russell Eberhardt on 29/09/2023 10:32:59:
Looks like a good candidate to replace the Dell computer I bought second hand 10 years ago for my CNC build. Can the raspberry Pi version of Linux CNC emulate a parallel printer port for my driver electronics?
Russell
Should be a fairly simple bit of coding. The Centronics interface is/was pretty simple minded. Enough so that I emulated it woth oneof our HP computers in the early '90s in order to drive a printer that had been bought in mistake by the department.
29/09/2023 11:44:59
Posted by Ian Parkin on 29/09/2023 10:10:14:
Mark.....wheres "here"
Rugby, Warwickshire. Also a tenner on the lidl.co.uk site. Where is your one?
Edited By Mark Rand on 29/09/2023 11:45:41
Thread: Average Energy Consumption
28/09/2023 19:47:47
The condensing driers normally recirculate the internal air. They do have the disadvantage that they don't work at all well at low ambient temperatures, such as an external garage or utility room. But they are a bloody sight more efficient than any other varieties which don't rely on string, wind and sunshine
Edited By Mark Rand on 28/09/2023 19:48:51
28/09/2023 17:09:28
Thy're a tenner here. Still picked up another one, they don't get treated with quite as much repect as the 'real' metrology gear in the shed. laugh
Thread: London Model Engineering exhibition at Alexandra Palace
28/09/2023 09:41:29
Posted by Nealeb on 28/09/2023 07:27:42:The library in Newton Abbot is also holding a railway-themed exhibition in December, associated with its specialist railway collection, and my own club in Newton Abbot will be exhibiting there.
Is the library still the Passmore Edwards one? Went to Newton Abbot Grammar (Knowles Hill now) from 1969 to 1976 and was a/the junior member of the defunct Torbay MES from it's founding until I left in '76.
27/09/2023 22:55:43
To be fair, the distance from Southend or Brighton to the Midland exhibition is about the same as the distance from me in Rugby (12 miles away from the Midland one) to Harrogate or The Bristol one and I visited those regularly.
27/09/2023 20:18:56
Posted by Mike Poole on 27/09/2023 18:26:17:
The first one I ever went to was at the Seymour Hall in the early 1970s, just a lad in those days.
Likewise. late '60s onwards. Spoke to Prof Chaddock about his wonderful gas turbine there. Lovely chap smiley.
Thread: Pear projectile proof pitched parapets
27/09/2023 20:10:09
Posted by Rainbows on 27/09/2023 18:16:29:
To avoid inter neighboural disputes ending in my tragic loss to a drive by shooting, pruning can only go so far as about the boundary line. Which will leave a very lopsided tree and a brief respite before the branches start encroaching again.
Wait a minute. Is this the neighbour's tree?
If so, talk to them (after getting better advice than you are likely to get from a public forum). They are liable for damage to your property caused by the tree...
27/09/2023 20:00:16
The irritating thing is that an 11kW air source heat pump costs £2,400 retail and can be installed with two 22mm pipes and two cables. If I didn't bother to tell the council, it would cost me less than £3,000 complete with changes to valve gear and control systems. One theoretically needs to be F-gas certified to install it, but it's a sealed, pre-gassed unit!!!
I personally don't need larger radiators. I replaced all the radiators with larger, louvred ones so they could run at lower temperatures than the previous owner's ones in order not to burn adults and children in the house.
Thread: Bolt or screw?
26/09/2023 20:48:40
Posted by noel shelley on 26/09/2023 19:31:41:
Bolts or setscrews ! You know the rest ! Noel.
Note that many colonials incorrectly refer to grub screws as set screws...
But yes, it it's got a (parallel) shank that's the same or larger size than the thread, for shear loading and location, it's a bolt. Including woodspoiling coach bolts.
Edited By Mark Rand on 26/09/2023 20:51:46
Thread: bizarre behaviour from spray can
25/09/2023 19:39:00
Just a thought :- the etch primers tend to have a surprisingly short shelf life. Is it possible that some of the primer has plated out on the bottom of the tin and is blocking the pickup tube when vertical? I recently had to throw ut some 2K etch primer in a tin because of this issue
