Here is a list of all the postings Ian Hewson has made in our forums. Click on a thread name to jump to the thread.
Thread: When boredom overtakes, make something, anything! |
23/08/2023 10:06:29 |
Boredom has taken over, I’m off to make something. |
Thread: Quick change tool post and ball cutting |
24/07/2023 11:00:17 |
I am happy with my Arc bought quick change tool post. First thing I bought after the Seig lathe. I previously used one on my Myford 254. Tool heights will alter when the tool is reground if not using inserts, needing reshiming. Ian Edited By Ian Hewson on 24/07/2023 11:00:49 |
Thread: Old tools restoration |
05/07/2023 18:19:33 |
King Dick adjustable spanner’s had a black finish from new, they were not shiny Ian |
Thread: Broaching |
28/06/2023 18:36:12 |
A quick update, I purchased a no1 press, the clearance is 140mm from the top of the ram to the base with the punch plate removed, so it has enough clearance. It was a cheap press on offer vat free, so I didn’t expect much and have spent a couple of afternoons squaring up the ram etc. Should be set for winter, got all the bar stock and flywheels before prices rise. Thanks for the replies, appreciated. Ian |
21/06/2023 19:15:45 |
Thanks for that, looks like the no1 will just do for what I want, collecting the pieces for a Farmboy to keep me occupied over the winter.much appreciated. Ian |
21/06/2023 17:44:00 |
Hi ndny Shims are added after the first cut according to Arc. Ian
21/06/2023 17:10:31 |
Thanks Jason, that is what I suspected, didn’t know how deep the broach went into the hole before cutting started. Ian |
21/06/2023 17:07:06 |
Hi I have not bought a press yet, which is why I am asking the question. Arc’s broach is 128 long, and the flywheel is 180 dia x 20mm thick. I used to slot with the lathe, but find a 3mm slot in a10mm hole is a bit fragile, so want to try broaching. Ian |
21/06/2023 16:20:23 |
Hi am anyone tell me if a 3 mm broach 128mm long will fit in a no1 arbor press with a 25mm flywheel please? Ian |
Thread: What did you do today? 2023 |
02/05/2023 17:33:47 |
Fitted a 100 tooth hostaform gear to the lead crew on my Seig sc3 mini lathe. Arrive this morning and fitted in less then an hour. Just needed a key way cutting and the boss removing, bore luckily was spot on, bought from the Bearing Shop with only the tooth count and module known. Don’t know why they are not shown as spares in the UK, as they seem readily available in the states. Rear cover fitted without any mods although some say they had to mod their cover when the fitted the gear. Auto feed is now much better. Edited By Ian Hewson on 02/05/2023 17:34:48 |
Thread: Worth it? |
28/04/2023 09:40:32 |
JCB diggers etc, a British multinational that has half the worlds market. Seen on building sites the world over. |
Thread: State Pensions - Notification thereof. |
27/03/2023 14:08:19 |
That’s why we don’t buy Lurpak😁 |
Thread: Time to let go and call it a day |
27/01/2023 10:02:46 |
Hi Tug I was in the same frame of mind three years ago when we moved house, sold all my machines and kept a few hand tools , mics etc. After we had settled I realised that I had not lost interest and have bought a mini lathe and mill to fit the smaller area I now have. It was a mistake to sell all my equipment as I am now having to buy new tools. If you have the space I would suggest you keep the machines for some time as you may regret selling them. Best wishes whatever you decide. Ian |
Thread: Oil Blacking |
31/12/2022 11:24:29 |
I used to save my old engine oil for my father to take to work at Singers sewing machines for oil blacking sewing machine parts they made. He was a tool room fitter at Kershaws in Leeds and worked on cameras for them, then marking out Centurion tank turrets at Rof Barnbow before sewing machines. Never encouraged me with metalworking, I was an electrician, but I guess it’s in the genes. |
Thread: Privacy Glass in cars |
13/12/2022 14:05:51 |
Whilst I do not leave items in plain view, I would break in to a car with items on display, easier pickings. Ian |
Thread: NHS Fiasco |
10/12/2022 13:22:10 |
Had my psa blood test on Wednesday at 9-00, results through and checked by doctor, on my phone by email 8-00 Thursday. Ian |
08/12/2022 15:08:08 |
Could it be an age problem? I am 78 and have non of the problems mentioned. The privacy glass I find is very useful for it’s primary function ie privacy of the rear seats and their contents. Perhaps it could be an eyesight problem seeing through it? Or are we confusing privacy glass with the illegal darkened windows beloved by boy and girl racers. |
Thread: Mini Bender |
16/11/2022 11:40:15 |
👍 never mind the naysayers, keep posting your links, interesting video with the poor practices you rightly mentioned. Ian |
Thread: Dial Test Indicator |
22/10/2022 12:50:34 |
Harold’s site worked for me a minute ago with Michael’s links, iPhone and Safari . Ian |
Thread: Making a simple part for a friend |
05/10/2022 13:06:40 |
Agree with oldiron. |
