Non-standard use of woodworking table saw
Accidental cutting of hard screw with TCT blade
Martin Whittle29/01/2017 23:38:26
102 forum posts
12 photos
1. Don’t try this at home (else really at your risk): metal cutting.
I recently finished making a crosscut sled for my home-made woodworking table saw; the final operation was to mount the sled onto the saw in order to cut its own clearance slot for the sawblade. I accidentally found that some idiot embarrassed had assembled the sled with a woodscrew in the line of the blade: there was a sudden minor shower of sparks, remarkably little mechanical resistance, and the screw was very quickly and neatly sectioned! After digging out the remains, a part of the screw is shown in the middle of the picture below. The screw is a ‘Torx-Fast’ part from Toolstation, and is expected to be reasonably hard.
I was surprised to find no obvious damage to the (fairly expensive) sawblade. It has 80 carbide-tipped teeth, 250mm diameter, spinning at nominally 4350rpm. So approximately 5800 teeth per second at a surface speed of 205km/hr, or 128mph. The cutter speed of over 11,000 feet per minute is rather faster than I normally use for steel! Something had to give way; I am glad it was the screw.
Whilst I ‘got away with it’ this time, I would not recommend using one’s best sawblade for cutting steel, but it might be worth considering for softer metals? I think the very high cutting speed is probably critical for this use.
2. Do try this at home: plastic cutting
I tried using the table saw to cut some pieces of Perspex (acrylic plastic). I was impressed by the quality of the cut surface: remarkably smooth, with a modest level of the expected scoring from the sawblade but otherwise a partially burnished surface, with no sign of melting, or any significant chipping on break-out. It might actually help that I have some unwanted wobble on the blade: the 3.2mm blade tips cut a 4.0mm kerf. For my intended purpose, it was completely unnecessary to further clean up the surface. In future I shall probably use the table saw to cut Perspex, in preference to a hacksaw.
I understand that plastics are generally cut slowly to avoid melting. However it does appear that if you cut them with a VERY FAST sharp cutter, this also avoids melting, except probably on a microscopic scale at the surface, and gives a good finish on the cut edge.
Martin
PS I have found the crosscut sled to be a very useful accessory indeed, for the table saw.
Enough!30/01/2017 01:24:02
1719 forum posts
Posted by Martin Whittle on 29/01/2017 23:38:26:
....... it might be worth considering for softer metals?
I've cut 1/8 - 3/16" Aluminum alloy plate on my table saw (regular cross-cut carbide blade) on a number of occasions without any problems - although it's a bit noisy. Need to feed slowly (probably obvious) and normal precautions: eye protection, blade guard down etc.
The speed is probably still a bit fast even for aluminum but it's do-able. I wonder if anyone has tried it with a VFD to get some control over the speed.
Also done Acrylic with no particular problem (although the hardware/lumber stores around here in Canada have recently begun refusing to cut it - don't know their reasoning).
The thing I've never had any luck with is LDPE which is supposed to cut easily. Never does for me.
Seafax30/01/2017 02:29:40
4 forum posts
By way of a side bar I found myself short of T nuts recently and used a woodworking router table to mill some out of a piece of 1" x 3/8" aluminum flat. That worked surprisingly well too, and I also regularly cut 1/4" max steel flats up to 4" wide on my Evolution chop saw.
not done it yet30/01/2017 08:32:44
7517 forum posts
20 photos
Metal fastenings are clearly often used in carpentry/joinery. Aluminium star dowels have been used for years to stabilise joints, simply because they are easily machined, whether cutting, planing, routing, etc without damaging the cutters. In the past, and likely still a problem with some hardwoods, was machinery coming into contact with steel jacketed bullets. HSS cutters do not fare well against these unexpected items. Metal detectors were often fitted to installations to avoid such damage - and probably still are.
Frances IoM30/01/2017 08:42:56
1395 forum posts
30 photos
though I've sliced across hidden nails in reshaping 2nd hand boards - it can be expensive on carbide tipped blades - often one or two teeth are removed and the saw gives poor performance.
Like you I find cutting Perspex on these saws works well.
The sled idea is generally frowned upon by H&S as the rotating saw blade can be exposed
richardandtracy30/01/2017 08:54:42
943 forum posts
10 photos
I have found the same thing happens with nails in pallets. I have a 10" mitre saw and a Screwfix brand TCT saw blade that I use for chopping up pallets for firewood (amongst other things) and staples/nails are frequently hidden in the timber. The blade is almost as sharp now as it was when I fitted it 3 years ago. The original blade had to be replaced when it was down to 10% of its tct tips left. That was a B&Q own brand blade & nowhere near as good.
Where I work we make boxes for expensive stuff (satellites being on the list in the past). Due to the fact many of the boxes go on aeroplanes, we have to make them fairly light, which mean 6082-T6 aluminium extrusions. However they also big enough to need fork lift pockets. Until we got cnc machined longitudinal extrusions for the boxes, we found the most cost effective way to cut the pocket holes was with a 1.5kW handheld woodworking router using a router blade and a timber template clamped to the extrusion. The speed of cut was phenomenal, as was the noise and velocity of the swarf as it was fired across the workshop. OK, killed the routers fairly fast but each lasted a batch of 50 containers worth. The man-hours saving compared to milling the pockets more than paid for the routers. I suspect that had we used an end mill instead of the router bit, the router would have lasted longer.
Richard.
David George 130/01/2017 09:41:18
2110 forum posts
565 photos
In the early years of my career in was involved in manufacturing parts for the launch platform for the seacat missile the main cover plates were cut using a large Watkins router and tungsten carbide cutters. This was before CNC milling and we just followed a pre cut template to profile and mill the aluminium parts. You worked out where to stand to avoid the chippings or proped the guard (piece of perspex ) to stop the chippings going down your collar etc. Not much hse in those early days but it cuts the alloy pretty quickly.
David
Edited By David George 1 on 30/01/2017 09:42:01
Clive Hartland30/01/2017 09:48:10
2929 forum posts
41 photos
When you are cutting metal on the wood saw rub a line of beeswax along the cut line, or a wax crayon. It helps the cut.
Farmboy30/01/2017 09:53:29
171 forum posts
Nobody seems to have mentioned the interesting combination of the shower of metal sparks with the heaps of very fine sawdust these saws produce . . . could save on workshop heating costs wink
richardandtracy30/01/2017 09:58:25
943 forum posts
10 photos
Don't think there's enough energy in them, but you're right, it is one thing to be aware of.
Richard.
Neil Wyatt30/01/2017 10:00:42
19226 forum posts
749 photos
86 articles
I've accidentally cut through screws/nails with a hardpoint panel saw before now!
Martin Kyte30/01/2017 10:01:56
3445 forum posts
62 photos
The thing that bothers me most is the combination of sparks and a table saw full of wood dust.
Martin
Ian S C30/01/2017 11:56:28
7468 forum posts
230 photos
Aluminium dust can be a problem if you start cutting steel.
Ian S C
Dod30/01/2017 21:12:04
114 forum posts
7 photos
Always remember to run without the Local Exhaust Ventilation when attacking steel, the dust bags dont like the sparks and draught much. I know what happens sad
Alan Waddington 230/01/2017 22:11:35
537 forum posts
88 photos
I had a dewalt 3 phase radial arm saw set up to cut a longish taper on the end of 100 x 50 x 6 aluminium channel.......it was a regular repeat job, and it scared the hell out of me every time......ear defenders, face shield, overalls, gloves, a scarf and finally a welding cap backwards, and still the hot chips always found a chink in my defences.
not done it yet30/01/2017 23:03:44
7517 forum posts
20 photos
Did you use a former to support the channel? Much less dramatic if laid under or over a suitable piece of wood, per eg!
John Reese30/01/2017 23:38:23
1071 forum posts
I have regularly used my 10" table saw for cutting aluminum up to 1" thick. It works very well with a triple chip blade made for non ferrous metal. It showers the whole shop in fine chips. I said everything went well until one of the chips fell onto the prongs of an electrical plug that was not inserted fully into the socket.
Michael Gilligan30/01/2017 23:44:01
23121 forum posts
1360 photos
Posted by John Reese on 30/01/2017 23:38:23:
... until one of the chips fell onto the prongs of an electrical plug that was not inserted fully into the socket.
Hopefully not a UK standard 13A plug with partly insulated pins surprise
.... The mind boggles.
