TDA2030A Audio Amp
Martin Shaw 113/02/2018 21:04:18
185 forum posts
59 photos
Back in the day when I worked for BBC Engineering the almost universal loudspeaker amplifier was a Quad 405, usually in bi-amp configuration. It was the amp of choice because, in the late Peter Walker's maxim the ideal amp was a piece of wire with gain, and it was solidly built and wholly reliable, day after day after day. Very little else originally designed for the consumer market has come anywhere near, my own example some 25 years old still outperforms most things on the market. Valve amps are just a pain, certainly in the wallet as revalving on a regular basis is essential, but unless you've got a high efficiency speaker design, horn loaded for preference, then they invariably have insufficient welly. Of course if your seduced by the hi-fi gurus, may you enjoy the dubious statements of betterment at your own considerable expense.
Martin
Edited By Martin Shaw 1 on 13/02/2018 21:05:43
Mark Rand13/02/2018 22:49:46
1505 forum posts
56 photos
What I would really like is a house that was big enough to house a pair of Quad ELS's cheeky
peak414/02/2018 01:06:03
2207 forum posts
210 photos
Posted by Mark Rand on 13/02/2018 22:49:46:
The most realistic sound I ever heard was in a hi-fi shop in Southport, probably in the early '70s, when my ears were young enough to appreciate it.
I can't remember the signal source, but the speakers were stacked Quad electrostatics (the original ones), two per channel, one above the other, driven by Quad valve amps. Crystal clear orchestral music that was quite mesmerising, even though I didn't appreciate "Classical" music then.
Ed Dinning 114/02/2018 08:00:11
39 forum posts
Hi Gents, split bobbin transformers tick all the boxes for the H&S brigade in terms of leakage pri/sec etc BUT, they have much worse regulation and higher losses, which could, with a poorly designed power supply increase distortion.
A correctly designed "sec over pri" transformer (earth screen and correct creepage and clearances) will give much better performance, use less total power and still be safe.
Note that the split bobbin design is virtually never used for the "holy grail" ~ output transformers.
Ed
Russell Eberhardt14/02/2018 08:07:37
2785 forum posts
87 photos
Posted by Neil Wyatt on 13/02/2018 20:51:27:The 6" speakers in my old Mondeo's doors had more guts than any of those awful Tandy ones!
Probably did. I agree that Tandy speakers were rubbish but don't you think that the size of enclosure you were in had something to do with it? Add in the ambient noise from a Mondeo engine and I doubt you could hear the distortion!
Quad electrostatics were excellent. They had diaphragms with a large area and very small excursion but needed a big room as they had to be sited well away from a wall for best results.
I like your KEFs. I seem to remember that Rogers used KEF drivers in their speakers.
Russell
John Haine14/02/2018 08:47:42
5563 forum posts
322 photos
I had a couple of ESLs, the original version, one made in 1957 the other in 1963. Probably spent over £2000 having them serviced, once by Quad the second by "onething audio", but last year the treble panels went again, so popped them on eBay and sold to an enthusiast who reconditions them himself. Now got a pair of Quad 21s which to my ageing ears sound excellent, though the ESLs when they were working properly were fantastic.
Neil Wyatt14/02/2018 09:53:51
19226 forum posts
749 photos
86 articles
Posted by Ed Dinning 1 on 14/02/2018 08:00:11:
Ed
Bear in mind (1) I'd never wound a transformer before (or since) (2) it was the only type of kit Radiospares sold...
Fully regulated supply rails and caps the size of beer bottles (well not quite)
Edited By Neil Wyatt on 14/02/2018 09:55:20
Neil Wyatt14/02/2018 09:57:30
19226 forum posts
749 photos
86 articles
Haven't seen electrostatics for >30 years. I saw one speaker that had a small electrostatic tweeter run off the valve O/P line before the impedance matching transformer.
Gordon W14/02/2018 10:49:25
2011 forum posts
Reminded of a man I was talking to a few weeks ago-- He asked me if I knew where to get lead shot. He needed it for some sound system he was building, had to pour the shot into the speaker stacks to get balance. he then went into his set -up at great length, most of which I didn't understand, his amp etc. etc. Turns out he lived in a 12ft caravan.
pa4c pa4c14/02/2018 11:03:59
16 forum posts
Posted by Russell Eberhardt on 14/02/2018 08:07:37:
My Quad ESL57's still are, excellent that is. They knock most everything else into a cocked hat. Just don't overdrive them playing Heavy Rock, there is no real need anyway as they are the only speaker I have found that the word "immersive" really applies to. You just need to be selective as to which amp you use to drive them.
The most asinine comment I ever read on any forum anywhere with regard to "Hi-Fi" was a moderator claiming he could tell the difference in the positioning of the fuse in the supply cable to an amplifier by ear alone. It pretty much did for me with Hi-Fi and the bullshit surrounding some of the "accessories". I remember reading about one of Peter Walker's demonstrations (he of QUAD fame) when he discovered he had forgotten the mains lead and went over to a power tool manufacturer's outlet and bought a length of Electric Lawnmower cable to connect the Amps up with. Works for me.
Cornish Jack14/02/2018 11:43:51
1228 forum posts
172 photos
Had supper with the 'big cheese' of a Bangkok import/export company back in the 60s. His hifi was a Ferrograph deck into a Quad pre-amp, Quad amp and a pair of Quad electro-statics. Had never heard of the latter previously but was much impressed -. He then put on a Florence Foster Jenkins recording and asked what we thought of it!! Never previously heard of her either!! Get out of that without embarrassment, thenindecision
Became quite interested in the quest for 'super-sound' (reinforced concrete window seat speakers etc.!!) until one of the more cynical critics pointed out that the ONLY way to get REPEATABLE sound quality of ANY sort was via headphones, as any other output would inevitably be affected by position, room contents, curtains etc. That observation has saved me a considerable amount of cash over the yearssmiley
rgds
Bill
KWIL14/02/2018 12:19:02
3681 forum posts
70 photos
Mark,
I have a pair of ELS and the lounge is just the "right length" for good results!!!smiley
Muzzer14/02/2018 13:33:46
2904 forum posts
448 photos
About 10 years ago when I was doing a lot of hybrid vehicle work in Korea for Mobis (electrical compt division of Hyundai), I had a tour of their brand new R&D centre just outside Seoul where our customer team was based. This place was simply staggering, with whole vehicle EMC chambers and audio anechoic chambers ("vehicle" as in HGV). Amongst other things, they developed car audio systems there and demonstrated their audio refenece system to us visitors.
The autitorium was the size of a typical cinema with controllable wall coverings etc and the multiple speaker stacks would have been big enough to climb inside. There was also a large screen for video and they played some Eagles live tracks for us. The sound was simply stunning and I've never come close to experiencing anything since. The recordings weren't simple CDs apparently but even so, they were doing something very special, not least in terms of the financial investment involved. Nothing to do with gold plated knobs or directional cable woo science, simply technical excellence on a vast scale. And of course, not a valve in sight (sound?).
Personally, I simply make do with a miniature run of the mill Class D amp from banggood (CSR8630 chipset - single chip Bluetooth audio ROM platform and TI TPA3116 Class D output) and run 320k MP3 files from my NAS - pretty crappy I suppose but years of self abuse have taken care of any need for further improvement.
Murray
Roderick Jenkins14/02/2018 14:18:49
2376 forum posts
800 photos
One of my old colleagues makes his own electro static speakers and headphones - I used to worry about the amount of kV he had across his head. I've had some niceish kit in my time but have come to the conclusion that any manufacturer that won't subject their kit to blind testing is selling snake oil. Rod
Edited By Roderick Jenkins on 14/02/2018 14:25:23
NIALL HORN14/02/2018 14:54:16
49 forum posts
18 photos
You might like to browse the results from Bellmans Winchester (uk) sale on December 12th 2017 - lots 539 plus
http://bellmans.co.uk/sales/winchester-sales/wdec2017/?page=21#sale-lots
and see what you missed. Don't look at the early lots from this sale unless you have a taste for the seriously politically incorrect!
Niall
Frances IoM14/02/2018 15:40:26
1395 forum posts
30 photos
Still use my Quad Electostatics bought in early 70s (my mother was convinced I bought rather expensive central heating radiators!) - the Quad Amp developed too much hum (suspect all power caps need replacing and has been sitting on a shelf for last 7 years) speakers now driven from a Arcam amp which has advantage of remote control (still have a Revox tape deck + linear vinyl deck but not used for years as CDs have taken over.
HughE14/02/2018 16:44:45
122 forum posts
It's a bit spooky that this topic came when I was clearing out the loft (orders from er indoors). I found WWs from 69 to 81 and reread all the Hi Fi articles and pro and cons of the Semi vs Valves and does current dumping really make a difference! Lots of good articles from Linsey-Hood et al.
Found a car radio I made from an RTV kit and the Dolby Noise Reducer (unfinished). I will see if the radio is still working.
Next task is to get a KEF B139 to repair my Cambridge audio R40s.
I have just refoamed my AR7 speakers and very pleased with the results. I got them from speaker-repairs.co.uk
Hugh
Jez14/02/2018 19:10:25
58 forum posts
1 photos
Posted by pa4c pa4c on 14/02/2018 11:03:59:
The BS got too much for me when I read in two articles in the same issue of one of the mags that:
(1) If you remove the 'power on' LED from the Linn power supply which powers the motor of your Linn turntable that you can hear the difference, and
(2) That the colour of the insulation on your interconnect wires makes a difference to the sound.
I stopped buying the magazines at that point.
Jez.
(Grey is best, in case you were wondering...)
Johnboy2514/02/2018 19:48:06
260 forum posts
3 photos
I agree Jez... I frequently rolled about laughing when these audiophiles started talking about the good effect of ‘oxygen free copper’ speaker cable! I had a practical approach to HiFi making my own Lindsey Hood class A amplifier and home brew preamp and ‘tone contol’. Happy days!
Mike Poole14/02/2018 20:05:13
3676 forum posts
82 photos
The CD had to make compromises in sample rate and bits to get a normal album to fit on a CD. Although they sound good to me and to get away from vinyl and all the baggage that goes with it was a relief. A medium that only provides part of the story is going to struggle to deserve to be called hifi. The fact that formats like SACD didn't catch on and the extremely compromised MP3 is huge must mean that most people aren't too bothered about hifi. I feel that the media available will always be a limiting factor whatever system you put it through. Although many people have a love of vinyl I don't believe that it can record all the information that is produced by a live performance especially as a tape or digital recording usually sits in the middle as well as microphones. Although we may fool our ears that they are hearing a live performance Logic will tell us that it cannot be true. If you want hifi go to a concert or gig.
Edited By Mike Poole on 14/02/2018 20:05:47
