Member postings for Cornish Jack
Here is a list of all the postings Cornish Jack has made in our forums. Click on a thread name to jump to the thread.
Thread: Lidl modellers jigsaw
26/07/2023 00:04:55
Dick H - Many thanks for such a swift and useful reply.- that seems to ring a memory bell too .yes
Bill
25/07/2023 21:19:14
G'day all
Long time since last visit - very little workshop activity... the usual back, knees and similar problems ! sad
A few years ago, I bought a Lidl's modellers jigsaw model PMST 100 A1. Quite a useful item for for light work. However, the blades are model specific and, from memory, unobtainable. Memory (not the most reliable talent !) suggests that one of the forum members at the time suggested a workaround to adapt other blades.
Can anyone shed any light, please ?
TIA
Bill
Thread: VW Tiguan battery charging
12/11/2022 13:59:33
Thank you Stuart - the one I have is obviously similar in intended function. My concern at the moment is whether it is working properly - i.e. should the mode/function/regime indicators on the fascia be active or just decorative ?
rgds
Bill
12/11/2022 13:07:52
Thank you, Hopper. I should have mentioned that I have 'moved on' a little - the Tiguan is sorted - new battery ! and i'm now trying to charge a Berlingo. It only does very low mileage and needs an occasional boost. The battery is the original (2014) lead-acid suitable for stop/start diesels.
The charger is as below ...
When operated, the top screen shows various values, the circle of leds sequence continuously, missing out the last one and the LiFePO4 charge mode indicator remains illuminated. None of the function selectors, (including the central 'mode' point) have any effect.
The 'destructions', in common with many nowadays, are angry useless !
rgds
Bill
12/11/2022 11:05:14
Nigel - thank you, I used my deeply ingrained technical skill to select a model from the hordes available i.e. the one with 'flashy lights' and pretty colours !! blush
It duly arrived and plugged in. The 'flashy lights' bit generated a sequence of leds illuminating in a part circle, the little screen at the top indicating voltages etc and the lower mode annunciators indicating LiFePO4 !!! In the centre of the circle of leds is a small circular area marked 'mode' Pressing this or, indeed, pressing any of the surface 'indicators' produces nothing. The accompanying 'destruction' booklet seems to indicate that these 'functions' should be selectable ... but they aren't !
I stopped the process and 'messaged' the seller suggesting that all was not well. His reply, this morning, reads
"our charger can match the charging mode intelligently, please don't worry"
My aged logic says that seeming selection indicators which select nothing, apparent function selectors which do nothing and battery type indicator indicating the wrong battery type are signs of malfunction. Seller, apparently thinks not ... any thoughts, please ?
rgds
Bill
08/11/2022 21:24:22
Thank you Nigel - I've just ordered a 10 amp unit with (apparently) selectable charge functions to deal with varying charge states - would this be a 'smart' charger, or is that something quite different ?
rgds
Bill
08/11/2022 19:04:44
John H - Thank you for that ... I noted (and complied with) the restriction but hadn't realised why it was necessary !
old mart - Good point - I vaguely looked into it a year or so back but confused myself with 'float chargers' and which was best for two low mileage, intermittent use cars ... so gave up ! Time to look again, methinks indecision
08/11/2022 15:11:21
Thank you all - and, yes, it is 'long in the tooth !!!sad
However, having, eventually, looked in the right place, I found a set of jump leads ... great joy! ... until they proved to be too short and couldn't manoeuvre close enough sad
So off to Wilko, new 6 metre jobs and Hey Presto, satisfactory noises. New battery on order (mega-pricey it seems)
Fingers crossed and thank you all again
Bill
08/11/2022 12:25:04
G;day all - Tiguan battery flat and first attempt at charging ('standard' fixed rate charger ) showed no improvement. (Direct connection to Pos and Neg terminals (NOT via power socket)) Any owners with relevant experience and/or advice, please ?
TIA
Bill
Thread: Steam kits
19/12/2021 14:16:23
Hmmm - re Beng's kits instruction sheet translation. - unless they have recently changed, the printed sheets for their ;Sophie' are quite dreadful. Sentence construction and terminology are just gobbledygook ! No problem for a proper engineer, who wouldn't need them, but left me completely stumped.sad
rgds
Bill
Thread: What Did You Do Today 2021
25/09/2021 17:18:08
Not today, but over the last 4 days, worked on the bits below, plus sweat, blood and expletives deleted !!
and more elbow grease and the silicone variety ... ended up with this
An unusual design and manufacturer. the shaped work holders rotate individually and accurately match for height - 4 total approx 1/4" thick. Very substantial (heavy) and good for mill or drill.
Anyone else come across this type ?
rgds
Bill;
Thread: RAF to give up flying planes.
07/09/2021 16:26:31
Posted by Jon Lawes on 07/09/2021 13:38:45:
For once I feel qualified to comment; I'm a flight simulator engineer on the Merlin aircraft.
The training they get in the simulators is invaluable; every nuance of flight characteristics and engine modelling (for example) is designed to replicate the real thing to the finest detail. Obviously there is a limit to what I can share but our sims are detailed in this article:
Link to MoD Website
Admirable enthusiasm for what will, undoubtedly be nice bits of kit, but maybe a little bit 'over-egged' ?
... from the website - (my emphasis)
Air Vice-Marshal Julian Young, Director Helicopters at the MOD’s Defence Equipment and Support organisation, said:
Simulation is a solution that, when blended with live flying events, provides the optimum individual and team-level training.
Although it can never replace live training fully, being able to create a wide variety of training scenarios and operating settings can provide a more challenging, safer and controllable environment to help our forces practice in a way that is essential to effective mission preparation.
The report, from the First Officer on a United Airlines twin which suffered engine failure on take-off, said that the noise and, particularly the vibration (which made the flight instruments unreadable) , was a total surprise and which nothing in the sim had prepared him for.
'Real life' is still real life.
rgds
Bill
07/09/2021 11:42:27
The Royal Air Force (British version) has never flown 'planes' ... those have always been the province of the woodworking trade group.
Aircraft, or aeroplanes have developed over the years to the extent that the control function inputs are very much on a par with computer control. Indeed, the trend has become for management to encourage the minimum input from the 'pilot' and leave it to the autopilot and FMC ... the downside to this is explored in " the Children of the Magenta" - the upside (from the beancounters) is a reduction in costs.
Personally, having worked with a selection ranging from the original Link trainer, through a variety of VC10, BAC 111, Boeing 37, 47, 77 and Airbus 340, while the response can imitate the 'real thing', they are training devices - not replicas.
I offer my best wishes to anyone attempting to 'make a case' to the beancounters against their intentions.
rgds
Bill
Thread: Sort of ... ???
09/08/2021 21:08:10
Bazyle - thank you for the response.
Not sure that all link suggestions should carry a synopsis to avoid wasting member's valuable time - personally, I assess these sorts if things quite quickly and go elsewhere if interest fails ... different folks, different strokes, I suppose.
rgds
Bill
09/08/2021 12:18:50
Just come across this Youtube clip. If you can ignore the presenter, the content is worth watching.
rgds
Bill
Thread: Cowells Lathes
05/08/2021 14:03:17
I have both (lathe and mill) and a 'job lot' of accesories. They are decreasingly used, so could be available. The problem, if such it is, is that they are 'cash on collection' ONLY! The lathe is the 14mm x 1.5 version. To avoid any misunderstanding, I have not yet made up my mind to put them up for sale, and, if photos are requested, they will be limited in scope.
rgds
Bill
Thread: Broken window key
31/07/2021 10:22:41
Recently saw (on Youtube) a clip explaining that these locks can be easily by-passed, since they don't lock the mechanism, just interpose a 'stopper' on the handle. It is possible to insert a thin strip to depress the 'tongue'.Apologies for rubbish explanation, but a Google search for 'window locks' or similar should unearth the clip.
rgds
Bill
Thread: Parkside pneumatics
18/07/2021 23:24:03
Many thanks, Howard and Clive.
Looks like it's going to be a 'home-brew' adaptor - 10-12.
Clive, you are so right about the removal - I don't know what adhesive they use, but, my word, it's very effective !frown
rgds
Bill
18/07/2021 18:55:59
I have a few bits of Parkside pneumatic tools and a compressor with a flexible tubular outlet. The outlet male thread fits some of the items but not the particular vone I want to use. I need a male-to-male threaded metal fitting to use as an adaptor, but I don't know what the threads are. Can anybody advise please -a nd, if possible where to obtainn same.
TIA
rgds
Bill
Thread: Lower back issues
18/07/2021 10:32:06
Been a 'member' of this club for many years. Ady's mention of the support belt is a good move - usuallty listed as 'nailer's belts'. Just gone back to wearing mine full-time.
Unfortunately Nature and a local 'sandscaping scheme' have left us with a need to move constant inundations of drifting sand - heavy, wet, particularly and dry. I can load a bucket using a long handle 'snow shovel, but lifting the bucket to wall height to dump it, is beyond me. So ...
and
... not completely finished, but, it does work and has been proof-tested to 28kgs, which is enough for my needs.
'Proper', competent engineers would undoubtedly make a much better job of it, but I have to work within my limited 'skill' set. The principle has been around a long time - Google "lifting sack barrow" for several variations and power sources. The 'Barrow' was a 'cheapie' £25 job and seems to be standard.
rgds
Bill
