littlerick | 11/10/2013 21:38:43 |
36 forum posts | Im new to the engineering hobby and to be honest have no idea what i'm doing, but i'm having a great time doing it. I havn't got a huge arsenal of tools or equipment... I have my lathe/mill combo, a few turning tools and some measuring items... all given by a friend. A fixed and live centre and a tailsock chuck. Being unemployed its gonna take a while for me to get a lot of anything. However one tool that i dont have, and i need it almost every 20 seconds is the simple center drill. Only a couple of £ but no matter what i do it always pops up! I'm gonna get at least one! What is your most used and most useful tool? |
Nobby | 11/10/2013 22:45:46 |
![]() 587 forum posts 113 photos | A No 3 chuck key for the drill and a odd leg calliper for marking out small items. Nobby |
Stovepipe | 11/10/2013 22:49:37 |
196 forum posts | Not engineering I know, but my most indispensable tool is a spokeshave, an absolute pleasure to use.
Dennis |
GaryM | 11/10/2013 23:04:46 |
![]() 314 forum posts 44 photos | Beginner, like you Rick. I'd say my 6" flexible steel rule. One of the first things I bought and still use it all the time. Gary |
Ady1 | 12/10/2013 01:19:19 |
![]() 6137 forum posts 893 photos | You can use a dead centre as a spot drill, handy because you know it's always spot on I made one from a centre with a carbide tip, ground away half of the tip so it was a bit like a half centre and it spot marks/drills anything you want in seconds, then follow up with a normal drill |
I.M. OUTAHERE | 12/10/2013 07:31:34 |
1468 forum posts 3 photos | A 14LB sledge hammer because when something really annoys me it soon knows about it ! Other than that I would also say my 6inch flexible rule or 12 inch hook rule - both very handy . Another couple of things are a good centre or prick punch as I have seen a few people go to the trouble of accurately marking out a job then use a blunt punch and another favourite is my carbide tipped scriber .
Ian. |
Speedy Builder5 | 12/10/2013 09:10:36 |
2878 forum posts 248 photos | For me, a good solid workbench with 2" thick oak worktop. I use it for metalwork, wood work, repairs etc etc. I also have a piece of hardboard the same size to protect the surface sometimes and a piece of thick cardboard I use when stripping an engine down. Yep, a good workbench that is free of odd jobs, bits and pieces and general rubbish. |
Russell Eberhardt | 12/10/2013 09:51:48 |
![]() 2785 forum posts 87 photos | Posted by Speedy Builder5 on 12/10/2013 09:10:36:
Yep, a good workbench that is free of odd jobs, bits and pieces and general rubbish. Does such a thing ever exist after the first week? Russell |
OH CHUFF! | 12/10/2013 10:36:46 |
![]() 15 forum posts 2 photos | |
Andrew Johnston | 12/10/2013 11:52:13 |
![]() 7061 forum posts 719 photos | Best tool I ever bought was a proper machine vice, closely followed by a DRO for the vertical mill. Andrew |
Thor 🇳🇴 | 12/10/2013 11:57:04 |
![]() 1766 forum posts 46 photos | My most used tool is probably my digital caliper. Thor |
FMES | 12/10/2013 12:02:47 |
608 forum posts 2 photos | Laser edge finder, especially when setting up the mill DRO |
Stub Mandrel | 12/10/2013 13:32:52 |
![]() 4318 forum posts 291 photos 1 articles |
Neil |
jason udall | 12/10/2013 16:31:21 |
2032 forum posts 41 photos | The next one |
Pete | 15/10/2013 04:41:58 |
128 forum posts | Books and the abilty to read and understand what there trying to teach me. |
Gordon Wass | 15/10/2013 10:01:29 |
57 forum posts | Not really model eng. but my indespensible is a sack barrow, bought at auction for £8 about 20 years ago and used every day, will easily move a 8" x 20" lathe. |
Danny M2Z | 15/10/2013 10:22:58 |
![]() 963 forum posts 2 photos | G'day . # 1 workshop equipment is a bar fridge to keep your superglue in and for shrink-fitting components. It also has other uses. Regards from the land of the kangaroo * Danny M * |
mechman48 | 15/10/2013 21:57:24 |
![]() 2947 forum posts 468 photos | 6" rule, 4" digital calliper, & a 0 -15mm outside mic' that I bought from a special deal ad in the MEW (can't remember where from)... ideal for those small items, don't have to fumble trying to get calliper / digi mic in close to chuck. George |
Ian Welford | 27/10/2013 21:40:23 |
300 forum posts | a 6" vernier callper with a clockface for the readings( metric and imperial)- got cheap from Proops many years ago as the clock face had a slight crack in it. Lives by the work bench. Use it more than any other one I;ve got,for both wood turning and metal work. If I want it more accurate I use a Mitutoyo which lives by the Boxford. Also a 150mm flexible rule .
Plus of course the collected wisdom of Peter Wright and G Thomas!
Regards Ian |
WALLACE | 27/10/2013 23:07:57 |
304 forum posts 17 photos | Lathe.
Can make things perfectly (within reason...) round or flat. What else do you need ?!
Being a bit more realistic to the OP, Jenny calipers. Very quck to find the centre line of flat bar etc for drilling holes. W. Edited By WALLACE on 27/10/2013 23:13:01 |
