Here is a list of all the postings Stub Mandrel has made in our forums. Click on a thread name to jump to the thread.
Thread: Timber and the risk of it causing corrosion |
04/04/2023 17:44:07 |
I made a 'box' for taps by milling grooves in mahogany blocks about 20+ years ago. Not rusted yet... YMMV! Neil |
Thread: 400 Bad Request code |
04/04/2023 17:42:38 |
Cripes... stuck in a huge deserted hotel with dial-up speed and reliability wifi.
I wonder if 'sometimes works if you stand by the door' fulfils what booking.com said...?
Neil |
Thread: Forum Platform Changes - PLEASE READ |
20/03/2023 18:05:30 |
Test post! S. |
Thread: UK DRIVING LICENCE [ 2022 issue ] |
29/04/2022 08:45:43 |
Just a note for anyone who still has a pre-2000 paper licence, it's only legal if all the details are still accurate. |
Thread: Myford Lever Action Tailstock Design and Build |
08/04/2022 09:43:18 |
This would have made a great article for MEW... 😁 |
Thread: Finding things |
24/03/2022 18:43:26 |
Keep everything in it's own special place for that feeling of satisfaction on the rare occasions when something is where you expect it to be.
S. |
Thread: Gear hobbing |
01/03/2022 11:33:26 |
Posted by Martin Connelly on 24/02/2022 17:36:29:
Big difference between a mandrill and a mandrel Martin C Indeed! Don't make a monkey out of me |
Thread: Hello to the forum |
04/09/2020 19:06:48 |
Welcome to the forum, Jon. Neil |
Thread: Myford ML7 1950 vintage |
04/09/2020 19:06:22 |
Welcome Stefan, My recollection is that such handwheel repairs have been covered in ME and MEW a few times over the years, cutting square threads certainly has, although it sounds like you have a strategy to address the problem. Neil
Thread: New member saying hello |
04/09/2020 18:59:59 |
Welcome aboard the forum, Jason. Neil |
Thread: Logging in to MyBT |
04/09/2020 18:59:33 |
I recently had an email from TalkTalk telling me they were going to put my monthly DD up, so they could continue to supply me with fast reliable broadband. As their broadband is neither fast nor reliable* I requested a call back several days ago. So far - zilch. Neil *To be fair, this is more down to BT Openreach than TalkTalk. |
Thread: New computer possibly required |
01/02/2020 09:16:10 |
Hi Peter, Look at HP's own website. I bought an excellent laptop for work with an SSD direct from them, cost was reasonable (£30 more than an the previous model which was being sold off cheap at Currys) and it came without the 'bloatware' you get on most computers, It had USB3 and 3.1 and is very fast. Screen is good too. Only bad thing was having to uninstall Macafee before it could ruin everything, and activate Windows Defender instead. Neil Downside is I now want a desktop that runs as fast! |
Thread: How to maximise material removal rate on a mini lathe? |
01/06/2018 19:57:09 |
I think the question was rhetorical? Rainbows seems to have demonstrated just how much you can hack off with a mini lathe. (Not often I see a lathe in more of a mess than mine) Only comments, CCMT best for that sort of abuse, the geometry is stronger and will blunt less rapidly - it also heats the steel which makes cutting easier - if the feedrate is OK. Don't forget to speed up as the diameter drops. CCGT better for finishing. With CCMT in particular you need to make sure that as much as possible, if not all, of the corner radius is in the cut. Took a 3-4mm deep cut in medium carbon steel on the SC4 for the last lathework series episode with a CCMT insert and it left a satin finish on steel that tends to look like a ploughed field. CCGT are ground to sharp edges so you can more easily get away with the light cuts and lower speeds usually used with HSS. The mechanics of a mini-lathe can easily cope with 3mm cuts in mild steel, but whether or not the electrics can depends on the types of motor, quality of control board tool, quality of tool and experience of user... Toolpost angle should be chosen to present the tool edge as well as possible while avoiding any risk of hitting those nasty whirly jaw-bits. Neil |
Thread: best machine tools for lathe |
17/03/2018 10:55:30 |
There's a good article in another place |
17/03/2018 10:50:40 |
Posted by Michael Gilligan on 16/03/2018 18:00:12:
Glad to hear it, Neil Note: I did, cautiously, use the phrase "It looks like" ... [which it still does] MichaelG. If it was my old set, you would probably have been right.. I'm not paying for a copy of DIN4980 to find out exactly what the specification is. I note that while some beautifully finished brazed tip tooling costs more than the typical set used by hobbyists, some 'professional supplies' sites sell supposedly 'precision ground' DIN4980 tools that have the entire carbide tip completely covered in paint... Neil |
Thread: Myford chuck 'oiling point' |
25/01/2018 09:21:07 |
The oil needs to be fluid enough to spread through the chuck from the oiling point. |
Thread: Article Suggestion "White Elephant & Why" |
16/11/2017 20:54:42 |
My workshop has an Ancient Psychic Tandem War Elephant*. Stub. *Google it |
Thread: Electronic water softeners. |
11/01/2016 13:17:24 |
Fit one to your waterworks and it will make your wee smell of roses Stub |
Thread: CM10 Mill Gears |
22/11/2015 09:54:07 |
If it's a flame cut blank the edges may be partially hardened, it's possible to grind off the skin. Neil |
Thread: Quick Change Toolpost and Holder systems |
20/11/2015 06:54:30 |
Thanks, sorted now - I thought I had already sorted it but must have got them muddled. NEIL |
