Here is a list of all the postings WALLACE has made in our forums. Click on a thread name to jump to the thread.
Thread: Woodwork Router Advice |
06/03/2015 09:53:23 |
Axminster ! Hadn't thought of them !! Basically, I need to fit new doors and frames - so it's locks, hinges and probably tenon joints or biscuits for the frame transoms. Unfortunately, they're not standard sizes so it's going to have to be diy or lodsa money. I bought a big one a few years ago for a kitchen worktop but have kept it in its box ever since as it scares me ... there's something about it not being bolted down - at least on my lathe I'm not relying on just muscle power to hold the headstock in place when taking a cut - it's very firmly bolted to the bed !! Anyway - thanks all for the quick replies ! W. |
06/03/2015 07:45:31 |
Hello all. I'm sorry to blaspheme on this site - but I think I will need to shortly do some 'woodwork' ! Can anyone recommend a good book -specifically on use of a router ? There's lots of help pages and videos around but I'd like something I can flick through and doesn't require plugging in....should also add that it's for 12 inches to the foot modelling - it's for new door frames in the flat... Thanks. W. |
Thread: Washers (History) |
28/02/2015 01:18:14 |
The Titanic watch reminds me of the ashtrays that occasionally turn up 'made from metal from the airship R101' As a goodly number of the bodies recovered from the crash wreckage were burnt beyond recognition, an ashtray seems hardly appropriate. .. W. |
Thread: Using 3D prints for casting |
21/02/2015 17:30:05 |
Hello Bob. Thanks for the reply - I'm still impressed by the castings however they were done ! Presumably its easy enough to print out the pattern slightly larger to take shrinkage into account as well ? W. |
20/02/2015 22:01:23 |
Hello Bob. Wrt to the castings - they look very clean and tidy. This is probably a silly question but I can't see any signs of risers or sprues on them - any idea on how they were cast ? Thanks. W. |
Thread: Parting Off MEW225 |
20/02/2015 10:04:40 |
I've seen a commercial one years ago on a stall at the MEE at Olympia. Definitely swan necked and also odd that it used a disc of ( presumably ) HSS with a segment cut out of it - not the usual long blade. I was tempted but the thought of sourcing replacement cutters put me off... W. |
Thread: Traction Engines in WW1 |
19/02/2015 19:30:18 |
Now I know ! Thanks !! W. |
19/02/2015 19:16:32 |
Watching the clip made me wonder if traction engines have differentials ... Do they ?? W. |
16/02/2015 20:27:33 |
I haven't thought about it too much ... but... I wonder if some of the 'angst' with parting off with a Myford is due to it being a plain lathe I.e. without prismatic guides ? Would the various resultant forces on the tool post when parting off be any different with or without them ? W. |
16/02/2015 12:09:30 |
Also... a sharp tool ! I used to sharpen my blades very crudely on a bench grinder - hand held as well... Parting off become a lot less stressful when I started to grind them up properly ! W. |
Thread: Rust Treatment |
15/02/2015 17:21:57 |
If you have a compressor, I'd use a small sandblasting gun. In my experience ( Lancia - need I say more ?! ), rust killers just slifhtly prolong the time for it to bubble through again - sandblasting kills it dead. It also gives a good finish for primer to adhere to. Unfortunately, it usually uncovers a lot more rust than you were expecting - and if you're a but too enthusiastic, can blow holes in rust weakened panels... W. |
14/02/2015 05:44:45 |
....best option I've found is to just use a hacksaw.....![]() W |
Thread: oiling the cross slide |
08/01/2015 15:13:19 |
I've sometimes thought about adding oiling points onto the cross slide of my Harrison which is similarly devoid of them.
Would it be a good idea to mill a narrow channel to spread the oil evenly and act as a reservoir - and would a 'diagonal' one be best to cover as much of the sliding surface as possible (without going right to the edge ) ?
Obviously I wouldn't want it any bigger than necessary to avoid increasing the wear on the remaining metal.... W. Edited for spell check getting ideas of its own.... Edited By WALLACE on 08/01/2015 15:15:25 Edited By WALLACE on 08/01/2015 15:16:28 |
Thread: Questions on an Electronics Expert |
26/12/2014 15:55:10 |
Wrt to 2 - someone with a bit of experience would get a fairly food idea on the type - and if a power tranny - the wattage or 'VA' just just by looking at it - a 50VA transformer for example, is pretty much the same size as any other 50VA one. The primary and secondary windings I would identify and quantify by using a meter and 'Variac' - that's probably a little too dangerous if you have limited experience with messing about with potentially lethal mains voltages. W. |
26/12/2014 15:25:22 |
Don't forget there's going to be a 0.7v drop across each diode.... There's a very good freebie programme - Google 'PSU Designer'that can simulate simple power supply circuits. W. |
Thread: What did you do today? (2014) |
25/12/2014 19:44:53 |
Ate far too much ! W. |
Thread: Problem with Single Phase Hoover AC Motor |
22/12/2014 12:57:19 |
I seem to remember there was a previous post regarding a Hoover motor with perished rubber interior wiring so a rewire job may be on the cards as well to keep it safe ! W. |
Thread: Who might have made this? |
10/12/2014 10:06:31 |
I could have done with something like this a few days ago when adapting a light to take a GU10 bulb... A brief look with a rule gave the impression the bulb holder fixing screws where 12mm apart - the poor fit and a search on the net showed they should have been 12.1 ! W. |
Thread: LEDs ... The Good, The Bad, and The Ugly |
10/12/2014 09:52:23 |
I feel your pain. I had a couple of expensive professional audio recorders trashed at work due to so called 'leak proof' batteries ozing nasties everywhere Even though they self discharge in about 6 months, I use Nimh rechargeables on everything of value these days at home ! W Ps - scope pics of the led bulbs running of ac in my album ! |
29/11/2014 22:35:27 |
Hi Michael. Scope pics will be posted when I return to civilisation.... .. Briefly, both lights use MC34063 regulators. There's a lot more supply ripple on the 3 led one - but it does take more current at 500ma compared to the 60 led one at 365 ma. This was at 12v ac measured with a 'true RMS' digital meter. Probably more to the point, the 60 led bulb has 2 x 470uF smoothing capacitors, the 3 led one only a single 220uF. Not the thing you'd really be able to tell unless you pull or rather smash them open unfortunately ! W. |
