Uses for old brake discs.
Mark P.29/04/2012 15:22:13
634 forum posts
9 photos
Hi all can anyone suggest any uses for used brake discs?
Regards Pailo.
Alan Worland29/04/2012 16:08:59
247 forum posts
21 photos
Flywheel?
Alan
Boiler Bri29/04/2012 16:11:05
856 forum posts
212 photos
Bin!
Sorry
Stub Mandrel29/04/2012 16:12:01
4318 forum posts
291 photos
Too big for bandsaw, too lazy for hacksaw.
Can anyone suggest a way of breaking them into usable chunks? Sledgehammer bounces off, 20 foot onto concrete damages concrete...
geoff29/04/2012 16:17:44
29 forum posts
how about an anglepoise lamp base for the bench nice and heavy so the lamp stays put
geoff
Gordon W29/04/2012 16:24:01
2011 forum posts
Cut a groove with angle grinder or chisel to break clean. Also make a good flywheel.
Russell Eberhardt29/04/2012 16:34:39
2785 forum posts
87 photos
Fix to a backplate to make a disposable faceplate? Possibly an adjustable one.
Russell.
Springbok29/04/2012 16:44:14
879 forum posts
34 photos
Leave them out for our itinerate friends to steal......
Mark P.30/04/2012 19:07:10
634 forum posts
9 photos
Thanks chaps,food for thought.
Pailo.
Jeff Dayman30/04/2012 19:58:25
2356 forum posts
47 photos
Brake discs make excellent bases for racks to support bent rods used in hanging painted parts to dry. The holes or studs in them can be used with all-thread and nuts or threaded couplings to make any shape of rack needed. Also excellent for weights used in welding jigs to hold small parts while tacking. I've seen a big one from a truck used as a base for a pedestal mount for a small bench grinder.
Incidentally I have broken up a few by dipping in liquid nitrogen for a few minutes and then appying a splitting maul (looks like a sledghammer, but one side of the head has a chisel wedge, which applies an enormous point load to the cold iron). However that was when the place I was working had the liq nitrogen readily available in big vats often and at very low cost.... ahem
JD
Stub Mandrel30/04/2012 20:36:17
4318 forum posts
291 photos
Posted by Jeff Dayman on 30/04/2012 19:58:25:
So you were the man on teh bus witha thermos hissing suspiciously in his knapsack...
Jeff Dayman30/04/2012 20:49:04
2356 forum posts
47 photos
No, that was just my soup...
I took the brake discs into the plant though, for breaking up, as well as any other "cryo" jobs. The guys in that group didn't mind people occasionally using their vats with proper precautions, but didn't like the cold stuff walking out. I imagine it was because if someone had a spill/frostbite type accident taking the stuff away, the managers would know right where it came from, and heads would likely roll.
JD
alan frost30/04/2012 23:07:36
137 forum posts
My plan eventually is to use an old brake disc or two to form a heavyish turntable on which to mount at least three of my grinders/linishers, indexing the turntable to bring the required grinder to the front of the bench. I prefer to have coarse, medium, fine ,green grit wheels , a polishing mop and a small linisher all available wthout changing a retruing wheels. This many grinders can devour and waste a lot of space unless mounted on an indexable turntable.
Nicholas Farr30/04/2012 23:12:06
3988 forum posts
1799 photos
Hi, here's how I've used one.
Speed Reducer
It was shown at the ME centenary exhibition in 2007 and also at the Midlands, and a brief description can be seen in the artical on the Midlands Model Engineering Exhibition 2007 by Richmond in MEW 132 pages 34-36.
Regards Nick.
Edited By Nicholas Farr on 30/04/2012 23:16:18
Jens Eirik Skogstad30/04/2012 23:13:57
400 forum posts
22 photos
I used the brake disc as material (brake disc is made of cast iron) for piston ring, piston for small model engine, some parts in steam engine where cast iron is necessary as material.
Easy to work with hack saw, file and drill, lathe and milling machine.
Tel01/05/2012 08:51:49
157 forum posts
28 photos
Extreme Frisbee!
Clive Hartland01/05/2012 08:55:19
2929 forum posts
41 photos
By the time I come to change my discs theres not much left worth salvaging!
Have often wondered what use they are as to anything useful but mostly just scrap.
Tony Jeffree01/05/2012 13:30:23
569 forum posts
20 photos
Posted by Boiler Bri on 29/04/2012 16:11:05:
Bin!
Sorry
Brian -
You couldn't make a very large bin out of one...
Tony
Ian S C01/05/2012 15:19:02
7468 forum posts
230 photos
You could stick one on the bottom of the bin to stop it falling over. Ian S C
Ray Lyons01/05/2012 15:22:33
200 forum posts
Looking for a flywheel to fit inside my mill/drill, I bought a new one to fit a Vauxhall Nova at a car boot sale for £2. It fitted nicely inside the drive pulley and together with another lump of 11/2" steel completely changed the performance of the mill. It helped having six 6mm holes through which I used 3 bolts to hold the flywheel in position.
Ray
