Member postings for Boiler Bri
Here is a list of all the postings Boiler Bri has made in our forums. Click on a thread name to jump to the thread.
Thread: Tapping head
10/06/2023 17:03:57
img_2178.jpegFinally got some springs and it’s all as good as new.
Thank you for all your help and offers.
Thread: Is a 3" Cornish coal fire possible?
31/05/2023 10:13:17
Paul,
That link was just what i was looking for.
22/05/2023 21:03:54
The springs are .25mm wire size and 3mm o/d I recon the length would have been around 8mm to 10mm ??
Looking around there are some on eBay for about £10 for the three. Does anyone know anywhere else to look?
08/05/2023 13:39:13
Finally got in in bits. There was a small circular spring clip stopping the top screwing off.
The jaws are ok it’s the springs that have collapsed.
happy days.
22/04/2023 20:28:58
703fafd9-612f-4c8e-8650-b1ba60504b23.jpegIn my tapping head one of the jaws has slipped and because of this the tap is not held straight. Has anyone taken one apart?
I can not see how to get the knurled ring off.
Thread: Moore and wright tools
23/02/2023 17:13:21
I have listed a load of measuring items.
Thread: Brass I beam
23/12/2022 19:29:09
It’s not actually for me. A friend is making a Norfolk Wherry and he needs it in the length.
If it had been shorter I could have made it up but he really needs the length.
Thank you for the replies. I will investigate them all.
Bri
23/12/2022 18:03:14
Does anyone know where to source 1.2mt long 20mm x 10mm I beam in Brass?
Bri
Thread: Coke for Brazing
16/12/2022 20:12:59
I started my working life working for my brother in law - his farther and he were blacksmiths/farriers. The forge was run on coke and his dad used to weld things together when taken from the forge. The glow of the metal was white hot and the joints were great when they were finished, all hammered together.
I am not sure where you can get hold of coke now? It was hard stuff and took some lighting, but when it burned it was like nothing else, little or no smoke or fumes.
Days long gone.
Sorry for being nostalgic.
Bri
Thread: Yet another knurling question.
11/12/2022 07:10:36
Has anyone managed to do any internal knurling. We make chucks for holding bottle caps. We usually line the bore with rubber but in time this wears off. Knurling would be great but I can not find anyone who has done this. Straight Knurling would be the best so that we do not mark the caps but have a better grip than the rubber.
Bri
Thread: britannia smokebox doors
12/11/2022 18:04:43
Smoke box door are held with the dart type of fixing.
Do you mean that
Thread: WM18 rattling.
29/10/2022 10:35:25
My mini miller started to rattle. When I took the covers off there was a loose collar. It looked like iut should have been fastened to the timing disk for the Speedo however only one tiny part of the four attempted spotweld was or had been holding it in place.
The counter sender receiver has been running as well and stopped counting.
The whole thing was covered in really heavy grease.
For now I have left the counter off and the collar as well as I can not see what it’s purpose was.
Anyone else had this problem?
Bri
2f3901e3-2865-4bd3-84b4-8417b1968038.jpeg. 583427e8-8c03-400c-a769-67e64bc6a174.jpeg
Thread: Working pressure
24/10/2022 16:02:47
I have an old drawing MAP publication drawing M24.
There are two copper boilers described on it and i am interested in the smaller one, which i am currently making.
The drawing states what size of engine they are suited to in terms of cylinder bore, how ever there is no working pressure included.
Using the formula from 'The model steam locomotive' book by the same author i can get the working pressure to 80PSI.
Has anyone made boilers to these drawings and if so what working pressure did you calculate and decide on?
Bri
Thread: Accessories for NHS Hearing Aids?
23/10/2022 18:42:06
My national health hearing aids are Bluetooth.
They will connect to my telephone -apple.
I do not have an iPad so I can not try it on there.
They will not connect to my PC or TV
Bri
Thread: Landilift
07/05/2022 16:37:27
Thank you.
07/05/2022 14:36:57
Does anyone have the number for Landilift. Chap who moves machines
TIA
Nrian
Thread: Brass casting - who to contact?
23/01/2022 20:38:56
There is a small company in Bradford that does non ferrous casting - Monkman
Bri
Thread: Ultra sonic cleaning
11/02/2021 17:58:02
Is the liquid in these ultrasonic cleaner units specific to the parts being cleaned. ?
I was offered one but know nothing about them
Bri
Thread: 2” Durham and north yorkshire
23/01/2021 21:46:22
Mine is 4”. It was easy to make individual parts and use cap heads to fix it together. They are hidden.
The bow fork is actually a bit narrow. I made it out if 6mm plate instead of 1/4”. To take up the slack i made brass buttons and pressed them into each half bow.
bri
23/01/2021 17:45:35
