Here is a list of all the postings geoff has made in our forums. Click on a thread name to jump to the thread.
Thread: Cracker Steam Engine |
21/12/2014 20:53:09 |
hi the gears are available from www.hobby.uk.com |
Thread: Need assistance in changing the chuck on a battery drill |
07/12/2014 18:42:53 |
re removing the left handed screw usually found inside the chuck if it wont come out like this one then spray down the chuck with wd 40 and leave it chuck upright for a while to allow the wd 40 to soak in or immerse the chuck in to a tin containing enough paraffin to cover the chuck and leave this for a while I have had some chuck screws that would not come out and have had to cut the chuck off carefully with a disc cutter until it could be removed hope this will be of help but please no smart comments |
06/12/2014 07:28:36 |
the correct way to remove the chuck is to remove the screw that retains the chuck then put the largest allen key you can fit in the chuck small end of allen key first then holding the drill with one hand knock the allen key and the chuck should come loose |
Thread: Myford service |
21/11/2014 16:30:42 |
yes Darren is still servicing as far as I know I was in contact with him only a few weeks ago |
Thread: Another attempted scam |
26/09/2014 14:27:09 |
hi mick I had a similar email from Belarus offering me a mill I had advertised for months ago but I realised straight away it was a scam and deleted it geoff |
Thread: Notes to self |
03/06/2014 08:59:42 |
do all the tribes attend tribunals whilst wearing the appropriate ppe equipment <edit> No ads within posts, please. Edited By Neil Wyatt on 03/06/2014 09:28:30 |
Thread: hi all |
09/03/2014 14:26:17 |
yes good point the loft is more secure than a garden building but access is more awkward than just popping outside in to the workshop also there is no natural light at all in the loft |
09/03/2014 12:32:35 |
find an alternative to the loft to many possible problems |
Thread: Wiring an MEM starter for 240v Lathe |
07/02/2014 16:17:54 |
Presumably it has a 240v coil and not a 415v type |
Thread: turning tapers |
09/12/2013 13:31:28 |
I would like to turn a taper using the topslide on my lathe the taper is to fit my jto taper chuck could some one tell me how to work out the set over angle please Regards geoff |
Thread: Myford Super7 |
08/10/2013 12:26:02 |
I was always told that the link type belts awear the pulley more due to the metal content of the belt is this true or not as they are as alresdy discussed a lot easier to fit than a standard v beltGeoffre |
Thread: ER32 Myford Collet Chuck |
15/06/2013 20:30:45 |
Hi all thanks for your comments and I have not tried your method norman but I did previously read about it although I cannot see the chuck fitting as it is so tight on the spinle nose thread at the start of the thread Geoff |
15/06/2013 15:36:22 |
Hi all I have now tried three 32mm collet chucks but none of them have fit my myford spindle at all Geoff
Thread: Lo-cost Workshop Storage. Take-away containers, Good/Bad or? |
02/04/2013 17:39:29 |
A great storage was the oxo tins from the 1950s but now all cardboard and plastic Geoff |
Thread: Anecdotes 2 |
28/01/2013 17:28:36 |
i heard one about a guy being interviewed for a job in engineering and was asked are you familiar with mike and vernier and his reply was i can get on with anybody i can |
Thread: Myford S7 Spindle Nose / Chuck fitting. |
27/12/2012 08:41:16 |
re bogstandards post august 2011 on myford spindle threads i have recently purchased an er collet chuck which is rather tight fit on the lathKke spindle thread i would like to know where i could borrow or buy the tap to try to rectify this sidetrack
Thread: MEW 200th issue |
24/10/2012 17:10:53 |
i am all for cnc or most appropriate at the moment workshop heaters so why not do an online pol of the readers to see what would be most appropriate for the majority geoff |
Thread: motor wiring |
12/09/2012 16:59:13 |
hi all regarding motor and control gear wiring i think there should be a separate forum on here specifically for motors and control gear ie direct on line starters and invertors after all it is vital that they are wired up correctly the invertor manuals are far too complex in their content for what is required by the model engineer for his workshop equipment be it a milling machine lathe etc regards geoff |
Thread: workshop lighting |
30/07/2012 16:38:44 |
i do agree that good lighting is essential but have any of you considered if possible using daylight by fitting a roof window or something along these lines i fitted one and replaced the corruged sheeting with equivalent type as used on conservatories excetera and it improved the daylight in the work area no end geoff |
Thread: mini mills - which is the best? |
12/06/2012 21:29:39 |
re small milling machines has anyone successfully fitted dro.s to peatol mill uusing the ready availiable horizontal and vertical dro.s geoff |
