Here is a list of all the postings Mark P. has made in our forums. Click on a thread name to jump to the thread.
Thread: Fuse Rating for VFD |
16/08/2023 20:57:12 |
I don't know about fuse rating but this was my electric shower in Laos! |
Thread: Taper Roller Ring Removal |
11/08/2023 12:01:06 |
If you have access to a welder run a bead of weld round the inside of the outer race and when cool it'll drop out. Mark P. Edited By Mark P. on 11/08/2023 12:06:57 |
Thread: Injector Tanks. |
10/08/2023 16:43:49 |
Could you fit inline filters, just a thought. Mark P. |
Thread: Warco VMC spindle knocking |
05/05/2023 14:44:27 |
Stuart, are you sure it's not the drawbar vibrating, it vibrates on mine if I'm using a large face mill (50mm) Mark P. |
Thread: 20 TPI threads |
06/11/2022 16:25:09 |
Maurice Taylor, it's definitely 7/16" 20. I'm now sorted with what I need. Mark P. Edited By Mark P. on 06/11/2022 16:26:04 |
06/11/2022 15:50:20 |
Nick Hughes, I bought one of those but it's wrong for my frame I need a plain 7/16" left hand stud. Unfortunately as it's an unused frame I don't know the year as it's never been stamped. Yes Old Mart that was my thinking too, for what I need unf should be fine. Regards Mark P. |
06/11/2022 15:22:10 |
Can anyone tell me the major difference if any between 7/16" 20 unf and 7/16" 20 bcy, I know they are both 60°. I need to find a left hand bolt / stud for my BSA left hand footrest. The stud I require doesn't seem to be available. Regards Mark P. |
Thread: Broadband woes |
11/08/2022 14:59:35 |
I changed from BT to Vodafone for my broadband and home phone mainly because there was no line rental with Vodafone, my monthly phone bill is around £36 I get unlimited download too. My mobile has been PAYG with Vodafone for 25+ years. Regards Mark P.
Thread: Chinese lathe vee belt |
02/07/2022 16:10:41 |
When I did the same to my WM250 I used SPZ taperlock pulleys which gave me a good choice of belts at reasonable prices. Mark P. |
Thread: Imperial v Metric Measures |
11/04/2022 14:57:23 |
I tend to use whatever system of measurement is appropriate at the time. Mark P. |
Thread: Material for wheels |
08/04/2022 16:35:44 |
How about some large bore steel tube / pipe. Mark P. |
Thread: Paint question |
20/11/2021 14:44:42 |
Maybe you could go over it with satin lacquer if compatible? Mark P |
Thread: Chuck Guard |
03/11/2021 11:30:08 |
My WM 250 lathe and my Warco VMC both came with chuck guards, I removed them as they were in the way. I couldn't see what I was doing close to the chuck on the lathe, and the one on the VMC fouled the vice. Mark P.
Thread: Chain Protection Sleeve |
06/10/2021 12:37:12 |
How about a bit of polythene tube or a bit of hose pipe? Mark P |
Thread: Hello Chuck |
05/09/2021 14:11:50 |
I use a 1 - 10mm keyless chuck on my lathe, probably a far eastern one, not had any problems with it.
I
Thread: Cutting holes in copper |
10/05/2021 18:20:36 |
How about clamping it between two pieces of plywood and using a hole saw? Mark P.
Thread: There may be a delay in some deliveries ... |
24/03/2021 18:29:32 |
Mr Philips must have been the navigation officer. Mark P. |
Thread: WM16B Draw Bar |
03/01/2021 13:56:09 |
I used to use an Austin mini brake adjusting spanner when I had my WM16. Mark P. |
Thread: Basic Maths: A Lost Art |
21/11/2020 16:37:23 |
Spare a thought for those of us who suffer with dyscalcula, not everyone is a mathematical genius. Mark P. |
Thread: I’m struggling! |
25/10/2020 09:20:23 |
Hi John, mine is about 6 years old, I don't think that they would change the spec but a call to Warco would confirm it. Regards Mark P. |
