Dalboy | 14/06/2021 15:30:44 |
![]() 1009 forum posts 305 photos | Here we go another lathe question to bring out the "Here we go again" brigade. This is not a what lathe should I buy thread but a general question on what do "YOU" look for in a lathe if you were to buy another now ie swing, length of bed screw cutting facilities etc. |
Steviegtr | 14/06/2021 15:37:31 |
![]() 2668 forum posts 352 photos | My lathe is a Myford Super7B & i love it. However i know it is only a small lathe. If i had room of which i do not, then something like a Colchester student 2000 would be what i would like to have or a similar machine with bigger swing etc. Or a Harrison M300. Steve. |
Ady1 | 14/06/2021 15:48:03 |
![]() 6137 forum posts 893 photos | Simple reliable, man portable, decent stiffness, with backgear and easy to fix How long could I use it if I was on an island with a single 240v socket and a pile of barstock Edited By Ady1 on 14/06/2021 15:48:38 |
Zan | 14/06/2021 16:02:21 |
356 forum posts 25 photos | If there’s 5000 members of this forum, there’s 5000 different answers. Every single person has different specific needs and space |
Speedy Builder5 | 14/06/2021 16:09:34 |
2878 forum posts 248 photos | Electronic leadscrew and cross feed which could be programmable for simple taper and ball turning and auto retract for screw cutting . |
Thor 🇳🇴 | 14/06/2021 16:10:19 |
![]() 1766 forum posts 46 photos | Hi Derek, When I bought my lathe some years ago I wanted a metric lathe with 280 to 300mm swing, preferably a 1000mm between centres and 40 to 50mm hole through the spindle. Didn't quite manage to find a lathe that ticked all the boxes but the one I bought has worked well and has been good value for the money I paid. Thor |
Nick Wheeler | 14/06/2021 16:13:46 |
1227 forum posts 101 photos | I'm limited for space, so the 10x22 WM250 is as big as I can fit. Fortunately it's also just about big enough for most of my jobs. I bought my first lathe for all the adapters, bushes and tools for my hobbies of restoring/modifying cars.
Things I look for mostly in order: enough power to do jobs in sensible time, variable speed, large spindle bore, rigidity, ease of use(eg, locks actuated by captive levers/knobs rather than tools), power feeds which ties back to #1, sensible chuck changes(the three bolt fitting is easy and fast, but would be improved with a few mm more access), screwcutting gearbox with lots of range, QCTP with lots of easily made holders. The gearbox is the thing I miss most, as setting up change gear combinations sucks a lot of time. A good electronic leadscrew would be even better; any thread pitch or power feed rate you want just by entering a number on a keypad. Quieter than a gear train too. Edited By Nicholas Wheeler 1 on 14/06/2021 16:14:12 |
Mick B1 | 14/06/2021 16:23:04 |
2444 forum posts 139 photos | Screwcutting is something I only do if size or precision requires it. Most hobby lathes won't have a gearbox with a comprehensive selection of pitches attainable by moving 2 or 3 levers, and independently of machining feeds - so we usually have to accept faffing about with change gears to set up the threading, and then faffing it back again to normal afterwards when we want to use longitudinal or cross feed machining. If I can, I'll duck the issue and use a die. Bigger, ex-industrial lathes in decent condition can be excellent, but you not only need the space for them but the capability to move them into that space, and that can add vastly to the expense and complexity of the process. If it's going to be your sole machine, even for a period, you need to be able to mill on it, which means the capability to fit a z-axis slide, and power cross feed is highly desirable. Dial-controlled variable speed is also highly desirable. A good 3-jaw chuck with concentricity in the order of a thou or better will save a lot of clocking-up time for almost all turned parts needing machining from both ends. In the 70s when I started this was not believed readily attainable, but I think that today it is. Because of the wide acceptance of the Myford 7 series, many model plans and casting sets require a swing of 7" or more. This is one of the factors that in my view severely limited the usefulness of the Myford Speed 10 I used to have. Length of bed is less of an issue unless you're going to do work on rifle barrels or suchlike - and even if you are, headstock bore may be more important, still more so if you've a variety of components you might want to part-off from bar in some quantity. Nothing in this world is ever perfect - nor can it be, as perfection for one type of work is bound to make another type more difficult. You just have to settle for the balance of imperfections you can live with, and afford. Edited By Mick B1 on 14/06/2021 16:24:02 |
Andy Carruthers | 14/06/2021 16:27:27 |
![]() 317 forum posts 23 photos | I stumbled upon a WM180 and bought at the right price, doesn't get a great deal of use but got me here and into a hobby which I really enjoy. I enjoy enhancing its capability - a mate and I just fitted DRO for example and starting on ELS conversion soon At various times I have hankered for a bigger lathe and will probably treat myself when I am settled, house move has interfered recently and I have one more to go - had to move the WM240 on which would have been a sensible upgrade just not viable right now I think the answer is what do you want the lathe to do? mine is a lot more capable than I am! |
SillyOldDuffer | 14/06/2021 16:48:37 |
10668 forum posts 2415 photos | Biggest lathe and milling machine that can fit in my workshop please! Actually an oversimplification, because tools ought to match the size of work being tackled: clock-makers don't want a massive lathe, and Sherlines are too small for motor-bikes. Myford 7s are a very suitable general-purpose small workshop size, though a little small for me, doing work where a bigger swing, wider spindle bore, and longer bed all come in handy. Most of the time a basic metric screw-cutting lathe would be fine in my workshop, but there are plenty of features I have or would like to have. In rough order of value to me:
There's other factors that may be important. Hobby machines are made down to a price, and although mine are 'good enough' for what I do, they aren't as smooth to operate, or as positive in action, or as robust as ex-industrial machines in good condition. In short, lathes made to support fast production work that cost a fortune new are easier and less tiring to operate than most hobby machines. The latter do much the same job, but demand a shade more of the operator. (Also true of clapped out industrial lathes: skilled operators can compensate for many shortcomings. It just takes longer.) It helps if lathe and milling machine tooling are compatible. (Having an MT lathe might be a good reason for not buying an R8 mill.) For some, the look is important. A collector might value authentic paint work. signage and gleaming chrome without needing machines to work at all. Others only want tools that work and don't care what they look like. Enjoying a hobby, it's important to be comfortable with the machine, and if that means polish, paint and putty rather than performance, then go for it. And features may not be as important as first thought - I do far less screw-cutting than I expected because most small threads are better cut with taps and dies. I could almost manage with a plain lathe because my machine is mostly only used to cut big or unusual threads.
JA | 14/06/2021 17:52:29 |
![]() 1605 forum posts 83 photos | Musts:
Nice to have
Not interested
I could go on. JA
Edited By JA on 14/06/2021 17:55:54 |
not done it yet | 14/06/2021 18:39:08 |
7517 forum posts 20 photos | I’m sufficiently pragmatic to realise that I am unlikely to find a better lathe. About the only things I might prefer would be a larger spindle bore and a gap bed, but accept that it is unlikely unless I were to buy something rather lager, most likely much more expensive and possibly it having had a hard life. I am quite happy with what I have, after my original chinese purchase. I have over 260mm swing, reasonable swing over the cross slide, full power over the whole variable speed range (I can also vary the speed with the VFD to venture well outside the original speed range), a wide range of metric and imperial threading (with only a single gear change from one to the other) both axes power feed with auto trip on the long travel, easy feed/threading by selection with just two levers, programmable functions on the VFD, a separate feed shaft. Also movable with a small hoist (or by two persons after removing the motor, carriage, tail stock and chuck). Edited By not done it yet on 14/06/2021 18:40:17 |
Dave Halford | 14/06/2021 19:16:59 |
2536 forum posts 24 photos | A less knackered than mine one of these, bench model, 54 threads in the gearbox and no change wheels required + spindle speed change by twirling a hand wheel all with no electronics to blow. Bliss. |
Dalboy | 14/06/2021 19:56:03 |
![]() 1009 forum posts 305 photos | Thank you all for your thoughts. Some interesting ideas of how people see what they want from a lathe |
Nigel McBurney 1 | 14/06/2021 19:59:16 |
![]() 1101 forum posts 3 photos | Cannot beat a Colchester Master 2500 long bed, ( Imperial) reversing clutch to make metric threading easy,1 .630 inch spindle bore ,carriage handwheel to the right hand end ,to avoid hot swarf on your hands,full threading /screwcutting g/box, g/box includes DP worm cutting. Easy to use. d1-4 spindle, though I do miss the 2 inch spindle bore of the now departed Colchester Triumph. I dont worry about weight you can move anything on rollers and a crowbar. |
mechman48 | 14/06/2021 20:21:42 |
![]() 2947 forum posts 468 photos | Would second JS's listing for my likes, otherwise a nice Harrison M250/300 will do nicely. George. |
JA | 14/06/2021 22:55:23 |
![]() 1605 forum posts 83 photos | Looking at my requirements it appears that I want a Hardinge HLV-H lathe. Where on Earth am I going to find one of those? Could I afford one? JA |
Emgee | 14/06/2021 23:18:39 |
2610 forum posts 312 photos | Posted by Speedy Builder5 on 14/06/2021 16:09:34:
Electronic leadscrew and cross feed which could be programmable for simple taper and ball turning and auto retract for screw cutting . Sounds like you need a cnc lathe, does all you call for. Emgee |
Calum Galleitch | 15/06/2021 00:05:07 |
![]() 195 forum posts 65 photos | One point easily overlooked, I think, is cost and availability, or ease of manufacture, of accessories and tooling. If you buy a common lathe which is or was sold by the hundred, finding a chuck or a milling slide or a design for a taper attachment is straightforward. Something a bit rarer may be the ideal price and size and so forth as a lathe, but you may find yourself taken aback when you discover how much more expensive and rare D1-5 chucks are compared to their D1-4 cousins, say. All you can really do though, is work through what you want to do, identify what will be necessary, and then get something a bit bigger if you realistically can.
