Michael Gilligan | 03/12/2019 23:01:44 |
![]() 23121 forum posts 1360 photos | With the festive season fast-approaching, I thought it time to revive an old Chestnut: Here is an example of modern work
. Seems pretty unambiguous ... but feel free to discuss. MichaelG. |
Mike Poole | 03/12/2019 23:05:53 |
![]() 3676 forum posts 82 photos | Theoretically incorrect but seems to work. Mike |
DMB | 03/12/2019 23:11:31 |
1585 forum posts 1 photos | Weird looking. Why the huge tubular spacers? |
Michael Gilligan | 03/12/2019 23:16:11 |
![]() 23121 forum posts 1360 photos | Posted by DMB on 03/12/2019 23:11:31:
Weird looking. Why the huge tubular spacers? . I think they are long nuts ... suggesting, perhaps, that they are done-up very tight. MichaelG. |
Henry Brown | 03/12/2019 23:21:24 |
![]() 618 forum posts 122 photos | I wonder if the longer hex parts are attached to the spreader plates, the hex is used to stop the spreaders turning as the nuts are tightened? |
peak4 | 03/12/2019 23:50:57 |
![]() 2207 forum posts 210 photos | I wonder if they are counter-bored, but with a "Normal" or "Heavy Nut" thread length. Hence the top one with the circular spacer, as the stud was even longer. It might allow them to be torqued up correctly whilst ensuring the shear load is on the parallel section of the stud, rather than the reduced area of the root of the thread. Bill Edited By peak4 on 03/12/2019 23:57:52 |
Mark Rand | 04/12/2019 00:11:13 |
1505 forum posts 56 photos | Seems perfectly correct to me. The lock nut is of a smaller thickness and on top of the main nut. |
Michael Gilligan | 04/12/2019 00:48:18 |
![]() 23121 forum posts 1360 photos | I should mention that the green brackets support a substantial tubular ‘bull-bar’ to protect the concrete bridge from impacts by high vehicles. Credit Google Earth MichaelG. |
Speedy Builder5 | 04/12/2019 06:40:17 |
2878 forum posts 248 photos | I wonder how far the anchor bolts went into the bridge ? Did the top bolts hit an impenetrable object that required an extra spacer under the nut? Looks like a good installation to me. Enough to take the top off a double decker bus! |
JasonB | 04/12/2019 07:03:44 |
![]() 25215 forum posts 3105 photos 1 articles | Top one being into concrete may have hit some rebar so did not get drilled so deep hence the packer., I would expect them to be resin anchors rather than sleeve or expanding type. The middle one is not placed that well being in or close to the junction between brick and concrete. As to the nuts that's simple the guy could not be bothered to shorten the threads so just popped some jointing nuts on first as he knew a model engineer would soon be along and not be impressed if he had too many turns of thread showing above the top nut |
Ian P | 04/12/2019 07:32:20 |
![]() 2747 forum posts 123 photos | If the bridge in the Google Earth picture is the same one as the one in Michael photograph then the bracket looks to have been modified or altered at some stage. In Michael's picture there are 6 fixings to the masonry but there appears to be 8 in the second image. Just curious. Ian P |
JasonB | 04/12/2019 07:38:58 |
![]() 25215 forum posts 3105 photos 1 articles | Ian, I think you are seeing 6 fixings but the top ones into the concrete have a rectangular "washer" not square like the lower 4 |
Mick B1 | 04/12/2019 07:39:35 |
2444 forum posts 139 photos | If it'd been me, I'd've found it hard to walk away leaving that bottom right square washer - if that's what it is - visibly on the skew. Edited By Mick B1 on 04/12/2019 07:40:33 |
John MC | 04/12/2019 07:44:07 |
![]() 464 forum posts 72 photos | Posted by Mike Poole on 03/12/2019 23:05:53:
Theoretically incorrect but seems to work. Mike Why? John |
Brian H | 04/12/2019 08:22:40 |
![]() 2312 forum posts 112 photos | I suspect that is because the thin nut should go on first. It looks as though the end of the thread has been hammered over to prevent removal. Brian Edited By Brian H on 04/12/2019 08:25:03 |
Hopper | 04/12/2019 08:24:33 |
![]() 7881 forum posts 397 photos | OMG but the bridge men have put the thin locknuts on second, following the practice of engineers and fitters throughout the 19th and 20th centuries on applications such as big-end bolts on large marine diesels and before that steam engines, instead of adhering to the 21st Century ISO standard ( section 5 of ISO 898-2: 2012 Mechanical Properties of Fasteners made of Carbon Steel) of putting the thin nut on first then the thick one. The science of which is outlined here **LINK** Science deniers, that's what them bridge men are. Next thing they'll be telling us climate change is a hoax to institute a one-world government. Somebody alert the authorities at once, before the bridge collapses and kills Santa Claus.
, Edited By Hopper on 04/12/2019 08:28:10 |
derek hall 1 | 04/12/2019 08:28:00 |
322 forum posts | One of my main gripes is studs that have a foot long of thread poking out the nut. You see a lot of this in modern construction, an example of this is when stuck in traffic on a motorway with nothing to do and looking at the way the overhead gantries are secured to the concrete mounting blocks. I haven't got a photo, other drivers stuck in the traffic alongside me might wonder what the hell I am I taking a photo of ! Regards Derek |
Martin King 2 | 04/12/2019 08:34:34 |
![]() 1129 forum posts 1 photos | In the spirit of Xmas, are these technically known as walnuts?........... Getting my coat..... Martin |
Martin Kyte | 04/12/2019 08:50:22 |
![]() 3445 forum posts 62 photos | Are they not on the bridge wing, so they should be wingnuts? 'nother Martin ;O) |
ega | 04/12/2019 09:07:03 |
2805 forum posts 219 photos | Does anyone know the actual result of a tall and heavy vehicle hitting the bull bar at speed? |
