Reverting to second childhood early. A foray into machining.
BadWulf | 10/11/2018 16:54:13 |
2 forum posts | John here. A Taunton based wave, anybody local do feel free to reach out. |
Chris Evans 6 | 10/11/2018 17:26:18 |
![]() 2156 forum posts | Welcome along John, ask away on here always someone with an idea. |
Brian Wood | 10/11/2018 17:55:47 |
2742 forum posts 39 photos | Hello John, You don't need to pay Myford those sort of sums for raising blocks, I made mine from 100 x 50 x 6 mm welded box section with long bolts through to the bench frame below. The benching is all in Dexion slotted angle with a top surface of 20 mm flooring grade chipboard and 3 mm hardboard for a clean surface,,, well it was clean once! If you have welding skills the level adjusting can be done with short M12 bolts through M12 nuts welded to the top surface of the rectangular box section, through which are long bolts to the lathe mounting feet. To lock the adjustment nyloc nuts were fitted under the adjusters to secure the setting once it is achieved I have a compatability difficulty with posting photos etc on the website, but can send to your email address of course Mine is wood_y(at)btinternet(dot)com Welcome to the forum by the way Regards Brian. |
Brian H | 10/11/2018 18:15:29 |
![]() 2312 forum posts 112 photos | Welcome to the kindergarten John, you are sure to find any help on here. What are you intending to make in your new workshop? Brian |
Jon Lawes | 10/11/2018 18:37:52 |
![]() 1078 forum posts | Welcome! I'm not a million miles away in North Dorset, near Shaftesbury. I've an ML7 as well, still a novice but learning fast (most of the time the hard way).
Welcome. |
BadWulf | 10/11/2018 18:44:55 |
2 forum posts | A plethora of Brians! Cheers guys. and Chris. Thanks for the welcome. John
Kevin F | 10/11/2018 19:21:47 |
96 forum posts 24 photos | Welcome John , how’s about making yourself some simple tools , like a pin punch and a center punch , both are relatively easy for a beginner to make and will be useful to have in your workshop . |
JC54 | 10/11/2018 21:21:06 |
![]() 154 forum posts 14 photos | Hello John, as Kevin suggested try making some tooling for the machines first then try something like a simple oscillator/wobbler engine. It really adds to your confidence when you have a simple running motor that you can say "I built that". Another John |
John Paton 1 | 10/11/2018 22:47:35 |
![]() 327 forum posts 20 photos |
Hi John and a warm welcome from mid Dorset, hi also to a 'fellow Dorsetshire swarfmaker' Jon I am slightly further away (near Dorchester), you are welcome to give me a shout and pop in for a cuppa if passing this way. In case you are building up your tooling I might have some bits of interest as I have collected excess of things like morse taper sleeves, end mills and tool bits over the years (plus some other more random items). Don't be embarrassed if you have no specific projects in mind as there are plenty of us that enjoy 'fiddling' and learning new skills as much as producing a particular masterpiece. Many of us have had no training and rely upon learning from others and asking what to many may seem daft questions. The question is not daft if you need to know the answer. My suggestion for a useful turning project is a tailstock die holder. Reading this thread I am wondering if you have to be called John to participate!!! (another) John
Peter G. Shaw | 11/11/2018 09:09:31 |
![]() 1531 forum posts 44 photos | Don't be embarrassed if you have no specific projects in mind as there are plenty of us that enjoy 'fiddling' and learning new skills as much as producing a particular masterpiece. Many of us have had no training and rely upon learning from others and asking what to many may seem daft questions. The question is not daft if you need to know the answer. I've spent the best part of 30 years doing just that! The interesting part comes though when you are asked to do something - and you suddenly realise that your skills have increased such than you can do it! Cheers, Peter G. Shaw |
Russell Eberhardt | 11/11/2018 09:51:08 |
![]() 2785 forum posts 87 photos | Hi John, Welcome from another (retired) martial artist, over 40 years of Aikido. Enjoy the learning and playing with the machines. Russell |
Tim Chambers | 11/11/2018 10:53:30 |
89 forum posts 33 photos | Hello John, Taunton you say, thats just ten miles from here. There is a pretty active local club if you are interested http://www.tauntonme.org.uk/index.html I'm not a member at the mo due to other commitments. Edited By Tim Chambers on 11/11/2018 10:54:10 |
clogs | 11/11/2018 14:27:57 |
630 forum posts 12 photos | I need to move my machines around some times esp spring time for a total w/shop clean out..... the heavy / akward machines (4) and metal cabinets are on a chassis type frame that u can use a pallet truck under....... U could just make em a bit taller to suit ur needs..... have some fun......
mechman48 | 13/11/2018 12:16:12 |
![]() 2947 forum posts 468 photos | … 'Yeah that £65 price wasn't even for the raising blocks, just 4 adjusting bolts!'
Michael Gilligan | 13/11/2018 14:08:01 |
![]() 23121 forum posts 1360 photos | Posted by BadWulf on 10/11/2018 16:54:13:
... I admit some things confuse me, why are four levelling screws £60+ from myford [and later] 'Yeah that £65 price wasn't even for the raising blocks, just 4 adjusting bolts!' . I am bewildered : **LINK** https://www.myford.co.uk/acatalog/LEVELLING-SCREWS-FOR-RAISING-BLOCKS-2684.html ... Was it the big yellow anti-vibration pads that you were pricing ? **LINK** https://www.myford.co.uk/acatalog/4-MACHINE-ANTI-VIBRATION-PADS-3661.html MichaelG. Edited By Michael Gilligan on 13/11/2018 14:10:39 |
Martin King 2 | 13/11/2018 17:18:15 |
![]() 1129 forum posts 1 photos | John Paton, PM sent! Martin |
Neil Wyatt | 14/11/2018 09:38:52 |
![]() 19226 forum posts 749 photos 86 articles | Hello John, welcome to the forum. Neil |
larry phelan 1 | 14/11/2018 16:12:55 |
1346 forum posts 15 photos | Hi John, Dont worry about not being sure what to make. I bought my lathe over 20 years ago and you might ask "What did you make over that time ?" Not sure,but I think I must have made something [along with many,many mistakes ] Even if you never make anything useful,it,s a great way to let of steam or pass a wet Sunday. Beware ! You are on a slippery slope and there,s no going back ! How do I know? ask me ! Enjoy your new hobby,I do ! Once you get started you will find loads of things to make/repair. It,s great fun,and there,s no one breeding down your neck,and you can clock in and out any time you feel like it. What more could you want ? |
Howard Lewis | 14/11/2018 21:55:33 |
7227 forum posts 21 photos | Welcome! VAST quantities of skill and experience on here. You may well be able to give as well as to receive. I have made raising blocks, before from box section, with studs carrying two nuts inside the box, and three outside. The bottom internal one carries the load onto the box section. The upper internal one locks against the first external one. The next one up carries the foot of the lathe, and the uppermost clamps the lathe foot onto the stud. basically, the studs do the work of raising the lathe, whilst the box section stabilises the stud to minimise bending. This arrangement raises the lathe, and allows easy adjustment for removing any twist from the bed, which will improve the chances of turning parallel over any distance. My 300Kg lathe sits on six 1/2 UNF setscrews in this way, so your ML7 should be OK on M8 studs (mine originally used 5/16 BSF bolts from memory) Now you are in for hours and hours of enjoyment. By all means start by making some tools that you will need. As your confidence grows, so will the range of work that you can do. (When I first got a ML7 never imagined that I would eventually cut gears or screw threads) You would be amazed by the work that has been done on a ML7, or even smaller lathes. Howard |
