Here is a list of all the postings Tim Chambers has made in our forums. Click on a thread name to jump to the thread.
Thread: 2 stroke glow engine |
11/03/2023 01:12:49 |
It,s probably a generic Chinese engine if it has no makers name on it. yes it should be tight at TDC if it is a ringless piston known as ABC for aluminium (piston),brass(liner),chrome(plating of liner) although the materials may have changed these days. I would break it in with a smaller prop say a 10 x 6 glass filled nylon to keep it lightly loaded with a rich mixture to start with but let it rev. Short runs of about five minutes and let it cool down in between.After four or five runs like that it should be good to go. |
Thread: RAF to give up flying planes. |
08/09/2021 22:16:58 |
Posted by J Hancock on 08/09/2021 19:22:36:
NDIY , yes, you are right about only pilots with previous fast-jet experience go from simulator to solo. But that was my point , there are no Typhoon 'trainer' aircraft. |
Thread: Mobility scooter spares |
18/07/2021 12:05:47 |
My Dad managed to break the switch on the stairlift with his bum, when I phoned up the dealer about a new switch they quoted a price of £180. I got a replacement from RS for 18 pence.
Thread: Motor control board |
09/03/2021 14:02:14 |
I bought brushes for my 210 lathe from Amadeal for a fiver just a couple of weeks ago, turns out it was the control board had released the magic smoke. I've now gone brushless with a kit from Aliexpress. |
Thread: Brazing brass help |
04/09/2020 00:02:34 |
I was thinking that you could probably form the curve just by tightening the screws when you fit it to the door. I am an ex member of the Taunton club ( I have been looking after my mum for the last four years, but now I have a bit of time on my hands) |
03/09/2020 22:42:05 |
Having a bit more surface area would make it easier to solder, how thin is the facia panel going to be?
03/09/2020 21:41:07 |
Posted by Theo Cushion on 03/09/2020 21:07:38:
Yes, the ears are very small and fiddly to all keep aligned. How else could I design it to be easier to fabricate? Could they be made as small blocks instead? Also I would use threaded sleeves to about half the depth of the door to give plenty of latitude when tightening up the screws. |
Thread: What Did You Do Today 2019 |
17/08/2019 00:07:08 |
Just ordinary mild steel (EN1 ?) I doubt that I'll ever wear them out |
16/08/2019 22:19:29 |
I found an old can of Duckhams 20/50 in the garage. All I did was heat it up until it went dark and dunk it in the oil. |
16/08/2019 17:05:18 |
Had a go at hot oil blacking. I'm quite pleased with the result. Edited By Tim Chambers on 16/08/2019 17:09:15 |
Thread: My digital calipersseems to give varying readings |
13/08/2019 00:45:18 |
Change the battery (Ok I know I should call it a cell). |
13/08/2019 00:44:58 |
Thread: Safety Glasses |
09/08/2019 17:21:51 |
I have a pair of Uvex varifocal safety specs from Vision Express "That'll be £450 please." |
Thread: Collet Chucks out of true |
04/08/2019 20:52:45 |
At the risk of teaching granny to suck eggs, you did throughly clean the morse taper in the spindle first? Its very easy to just bop the chuck into the spindle and tighten the drawbar and forget to check if the taper has any swarf buildup. Edited By Tim Chambers on 04/08/2019 20:54:51 |
Thread: Searching for an Off-The-Shelf, Light-Duty, Rack & Pinion |
31/07/2019 21:10:35 |
Something like this perhaps? |
Thread: IC engine tractor conversion query |
31/07/2019 18:55:58 |
Posted by AdrianR on 31/07/2019 13:47:47:
If you want to be green, buy biofuel. If you really want to go green ,buy a goat. |
29/07/2019 17:19:16 |
Edited By Tim Chambers on 29/07/2019 17:20:34 Edited By Tim Chambers on 29/07/2019 17:23:44 Edited By Tim Chambers on 29/07/2019 17:26:51 Trying to embed with mobile is impossible.
Edited By Tim Chambers on 29/07/2019 17:27:56 |
29/07/2019 17:12:04 |
Plenty to see on YouTube https://youtu.be/NMWQxc9Ch2w This firm are local to me but the website doesn't seem to have changed much recently. https://www.everything-ev.com/ Edited By Tim Chambers on 29/07/2019 17:17:28 Edited By Tim Chambers on 29/07/2019 17:28:53 |
Thread: Where's my Dykem blue gone - there's no need to read this |
18/04/2019 08:06:04 |
Of course you know it will be in the last place you look!😊 |
Thread: Chinese dovetail cutter |
08/04/2019 23:55:52 |
I know it says wood but they worked very nicely in mild steel when I made some toolholders for my lathe a few weeks ago. Edited By Tim Chambers on 09/04/2019 00:02:38 |
