An alternative to parting-off
Andy Pugh02/11/2018 21:34:34
67 forum posts
It isn't easy to part-off material on the lathe much over 2" dia in my experience.
I think I have thought of an alternative having noticed that Aldi are selling a handheld bandsaw for £150 (identical model available on eBay for £220...)
The bandsaw comes with a vice and table as an accessory, and my lathe has a T-slot at the back for a taper-turning attachment.
A bit of cutting, welding and machining later:
Chris Evans 602/11/2018 21:50:56
2156 forum posts
That looks interesting. Now all the bracketry is made does it take long to set up ? I am happy parting off up to 2" with a rear mounted tool post after that or if the material is a bit difficult I use my cut off "Donkey" saw. Your method would eliminate the problem of holding short ends and differing diameters.
Mark Rand02/11/2018 22:23:00
1505 forum posts
56 photos
I would look into what is wrong with the lathe to be causing problems with parting off. Something's severely out of kilter if you are having problems with that lathe.
not done it yet02/11/2018 22:38:09
7517 forum posts
20 photos
Yep, it is usually the last bit of parting off large diameter parts, when the parting tool is well extended from the holder.
Cutting the last bit with a hacksaw is not a problem for the odd occasion it might arise.
I suppose that if you need a saw for other duties, using it like that might be justified...
thaiguzzi03/11/2018 04:12:53
704 forum posts
131 photos
He's joshin'. Havin' a laugh........
JasonB03/11/2018 06:58:19
Is it not easier to just take the work out the chuck and use the saw on its stand on the bench?
Ady103/11/2018 09:13:17
6137 forum posts
893 photos
Another choppy uppy thread
Neil Wyatt03/11/2018 09:28:00
19226 forum posts
749 photos
86 articles
Mark Rand03/11/2018 15:27:46
1505 forum posts
56 photos
Posted by thaiguzzi on 03/11/2018 04:12:53:
Yeah, sorry Andy! Must have had the sense of humor switched off. embarrassed
larry phelan 104/11/2018 09:33:56
1346 forum posts
15 photos
Like many others I have had "problems" when parting off,still have,but I dont think I would go for that approach !
Sometimes it works for me ,first time. Next time,no way ! The Gods are fickle [as we all know ]
If I think it,s going to be" one of those days ",I just take it out and cut it off in the band saw. I doubt if I will live long enough to to really master the art,but I keep trying !
One thing I like about this Forum,is that you never know what you,re going to see,or learn .
Keep them coming.
vintage engineer04/11/2018 09:41:17
293 forum posts
Never understood why people have problems with parting off. Now we have insert parting tools it's a doddle, as they are made for power feed parting off. I usually set the lathe speed to about 500rpm to 800rpm and a medium speed feed and let it go.
I have happily parted off 10" round bar with no problems.
Russell Eberhardt04/11/2018 11:19:45
2785 forum posts
87 photos
Posted by vintage engineer on 04/11/2018 09:41:17:
No doubt on a Super Adept lathesmiley
Russell
ega04/11/2018 11:33:27
2805 forum posts
219 photos
Where does one obtain a parting off tool with a 5" projection? And what lathe runs it?
Not everybody has power cross feed. CNC apart, how does conventional parting off account for the progressive reduction in surface speed of the cut?
Tony Pratt 104/11/2018 11:48:49
2319 forum posts
13 photos
Please supply all details for us amateurs to learn from. Parting 10" diameter of any material is a serious business & all at one speed.smiley
Tony
Kevin F04/11/2018 11:50:59
96 forum posts
24 photos
I never use feed too part off , I always feed in by hand , this way I can ‘ feel ‘ what’s going on during the parting process and if need be I can clear the swarf by winding out the tool a little .
I think the op needs to Take out the backlash before parting off and check how much play he has in the bed and cross slide , also the tool clearance and center height and spindle speed .
Edited By Kevin F on 04/11/2018 11:53:01
not done it yet04/11/2018 12:15:58
7517 forum posts
20 photos
VE could mean that although left on power feed, he has varied the motor speed (like I could on my Raglan). But I would not wish to try parting off 250mm on that! Increasing the speed as it progressed would also increase the feed rate! Also, it might well swing 250mm but certainly not over the cross slide!
Or maybe that ‘10” round bar’ was plastic? Maybe he works at a scale of 1” to the foot and is building traction engines? It would be good to read the particular details of the exercise. I would expect Abom79 could do it quite easily if he wanted to.
Oldiron04/11/2018 12:54:43
1193 forum posts
59 photos
Here is an interesting webpage for those interested.
larry phelan 104/11/2018 15:00:30
1346 forum posts
15 photos
To those who dont understand why others have trouble parting off,it,s very simple,we just dont know how !!
Perhaps we are using the wrong material to begin with. The next time I visit my supplier,I ,ll ask him if he has a few bits of 10" round kicking around that I could practice on.
Just thought of something----my chuck is only 6" ! Problems,problems,problems !!
The fact of the matter is that many,if not most people find parting off a difficult operation,and not all of them amateurs.
I suppose when you get used to it,you can have a cup of tea while you,re at it..
For the rest of us Dream on.cheekycheeky
Niels Abildgaard04/11/2018 16:34:12
470 forum posts
177 photos
Posted by Tony Pratt 1 on 04/11/2018 11:48:49:
Tony
Muzzer04/11/2018 17:04:54
2904 forum posts
448 photos
I see it's one of the Iscar TGFH parting tools. Different inserts to the "GTN" used in many (most?) other insert tools. I was provoked into getting one recently after similar reviews here, on offer from Zoro (Cromwell).
I found it worked nicely on steel and loominum. Not quite 125mm but it looked as if it would cope if the time came.
Murray
