Member postings for Oldiron
Here is a list of all the postings Oldiron has made in our forums. Click on a thread name to jump to the thread.
Thread: New member
04/10/2023 21:50:32
Hi welcome to the forum Alan. Plenty of people here to answer your questions. Once the new forum is up and running in a few days searching for answers may become a bit easier.
regards
Thread: boring 20 mm diameter hole in aluminium
27/09/2023 10:00:09
Posted by Mark Davison 1 on 27/09/2023 07:02:25:
25mm thick with a hole saw (carbide or hss) sounds like a recipe for disaster, it will just clog. You will have move success with a rotabroach style cutter. The chip evacuation is far better. Make your own arbor from a soft ended blank.
I agree. A rotabroach is a much better method. Plenty of lube ie wd40 or parrafin.
regards
Thread: Measuring instrument storage.
18/09/2023 19:45:35
Posted by Taf_Pembs on 18/09/2023 17:01:18:
Doesn't have to be I suppose, just though that wood would keep them a little better, less damp maybe..
I presume as you use some Bisley drawers they keep OK?
I prefer steel drawers such as the Bisley units. I have my doubts about using wood for instrument storage.
I was given a really nice set of gauge blocks that were ruined as they were in a wooden case that must have got some damp in it before I got them.
regards
Thread: Greetings from Canada
18/09/2023 19:40:45
Gary You only have a limited amount of time to edit your posts on this old forum software. When it gets changed over to the new planned forum software not sure what will happen. Please be sure to note your username, password, email adress etc as you will need them on the changeover when it happens.
regards
Thread: MEW Index updated to Issue 332 (Oct 2023)
18/09/2023 08:49:27
yes Thank you
regards
18/09/2023 08:27:18
Welcome to the forum Gary. Plenty of advice available here. There are many threads which will help solve problems. Or just ask away.
regards
Thread: Advice Wanted - On obtaining help...
14/09/2023 15:19:16
Posted by Andy_H on 14/09/2023 15:11:28:
Posted by Oldiron on 14/09/2023 11:36:00:
I presume by "mandrel" you mean what would normally be called the "Spindle"
Somewhat similar to this link. Spindle
regards
Yes I do.
In fact I have always referred to it as a spindle but having seen it referred to in several other posts as a mandrel used it here.
Your question got my curiosity working though wondering how the two terms differ which led me to this definition:
a usually tapered or cylindrical axle, spindle, or arbor inserted into a hole in a piece of work to support it during machining
So my take on this is that, although a mandrel can be a spindle, the distinction is that it's something used with a workpiece, whereas I was referring to the machine not a workpiece - so should have used the term spindle!
Andy
yes
14/09/2023 11:36:00
regards
Thread: Buying Microsoft Office
14/09/2023 11:18:22
Posted by John Haine on 14/09/2023 08:55:56:
https://www.libreoffice.org/download/download-libreoffice/
Very easy to install just like any other app.
I gree 100%. Easy peasy as does everything that I will ever need. Reads all my old spread sheets from many year ago.
regards
13/09/2023 16:41:53
Hi. A little more info would be helpful in getting the correct advise. Make & model of lathe ( a picture speaks a thousand words) A few dimensions. Your approx' location.
As much info as you have make things much easier.
regards
Thread: Hosepipe delemas-Plastic Fittings kick out
12/09/2023 09:08:42
Came back from the Sandringham game & country fair on Monday and put the caravan on the storage washbay.
By the time I had the caravan clean I was soaked. The washbay hoses & the fittings were new Hozelok and all leaked. Tried tightening them up and swapped ends around between the two hoses to no avail. It seems all Hozelok fitings are designed to leak angry. It was a hot day so it cooled me down somewhat.
regards
Thread: Pillar Drill Part
04/09/2023 13:04:55
Could be a polyurathane bump stop/ shock absorber depending on its position which is not very clear. Other than that no idea sorry
regards
Thread: Microsoft works
23/08/2023 13:44:32
Posted by DiogenesII on 23/08/2023 13:31:30:
..or Open Office. Used it for several years with no issues either opening or sending..
yes I have also used OpenOffice with no problems for many years
regards
Thread: Readers Tips for MEW
16/08/2023 14:49:38
Posted by magpie on 16/08/2023 11:42:48:
Sorry Neil, but i am now bedridden and living in a nursing home. It is frightening how things can change in just a short space of time. In the last 12 months i first lost my wife, then my home, workshop, and everything we had worked for in the last 50 years.
Sorry to hear of your troubles magpie. I hope you have good access to the internet so you can keep yourself occupied on the forum & Youtube etc.
ATB regards
Thread: Hi from the Wirral
14/08/2023 14:40:22
Hi Dave Welcome to the forum. Lots of nice people here to answer any questions you may have. You can search the forum for answers as a prelim' to asking though as you may find most common questions already have a miriad of answers.
regards
Edited By Oldiron on 14/08/2023 14:40:54
Thread: Cutting oil and ventilation
14/08/2023 14:29:06
Posted by duncan webster on 14/08/2023 13:49:37:
Keep it and use it for parting off, where it definitely helps
thumbs up
Thread: Hello!
11/08/2023 22:17:25
Welcome Eric. Just goes to show you dont have to give up in the face of adversity. Looking forward to seeing some of your projects. ATB. regards
Thread: Lathe Drive Systems and Belts
11/08/2023 12:36:48
The Boxford AUD BUD & CUD use a lever and rod system. Lever is on the end of the lathe cabinet just below the headstock to put tension on the motor plate. The rod is adjustable so as to give correct tension to the drive belt feeding the countershaft. There is no adjustment on the countershaft to spindle belt.
regards
Thread: 74 TX650 build.
11/08/2023 12:27:15
Very nice job Tony. A really nice looking restoration/rebuild. That must have given you hours of pleasure & a few headaches no doubt.
regards
Thread: What did you do today? 2023
10/08/2023 10:49:45
Posted by Bazyle on 09/08/2023 23:44:11:
Set out 116 numbered pegs in a field for tomorrow's agricultural show old vehicles section. Of late the numbers of cars entered is increasing but stationary engines decreasing. The organiser's insistence 3rd party insurance stymies the simpler entries.
Goodnight. I have to be there at 7am for the first arrivals.
Public Liability Insurance for up to £5m costs me £6 per year with the NFU. So not really prohibitive as it equates to around 60pence per show.
regards
