How to clean Cartridge Brass
Speedy Builder5 | 01/10/2018 18:20:52 |
2878 forum posts 248 photos | I have a pair of very dirty WW1 German (fired) 150mm mortar cartridges. If I use sulphuric acid pickle which has been used for pickling copper boilers, it will leave a pink deposit behind. Should I use another type of pickle which would not leave the copper deposit. |
John Rudd | 01/10/2018 18:26:00 |
1479 forum posts 1 photos | Fresh acid would be my choice... Sulphuric or citric..whatever comes your way.. |
fizzy | 01/10/2018 18:31:34 |
![]() 1860 forum posts 121 photos | Even new sulphuric acid does this, it removes the zinc leaving the copper in place and is a real pain to get back to brass. I never put brass in any pickle. Some say use citric acid but it has ecactly the same effect, just takes longer. Wipe them down with a solvent then clean them up with a fillament abraisive wheel, then a scotchbrite wheel then polishing mop and paste - i use this method several times a week so I know it works.
Mick B1 | 01/10/2018 18:43:55 |
2444 forum posts 139 photos | I've used vinegar to remove oxide coating from phosphor bronze, and I think it'd work for brass. It hadn't occcurred to me that it'd preferentially react with one component of the alloy, but I think the effect would be minor unless you left it in for days. I'd think it depends on the depth of the corrosion and how much metal's going to be sacrificed. It's usually important to preserve manufacturing and inspection stampings - abrasive polishes can be very destructive to those. |
John Smith 13 | 01/10/2018 18:48:35 |
5 forum posts | I've used Coca-Cola to clean very dirty brass items very quickly with no apparent damage. Try putting a dirty penny in a little Coke and it'll be clean in 10 minutes.
John |
Dick H | 01/10/2018 20:17:53 |
141 forum posts 1 photos | Have you considered clock cleaning solution recipes? Ammonia, oleic acid (liquid soap) and a pinch of acetone diluted down with water. But don´t leave it in too long.
larry phelan 1 | 01/10/2018 20:24:54 |
1346 forum posts 15 photos | Hate to think what Coca-Cola does to your insides !! I have known it to make short work of a 6" nail. ! |
Mike E. | 01/10/2018 21:44:29 |
![]() 217 forum posts 24 photos | Not sure how it would work on copper, but Apple Cider Vinegar will dissolve the worst corrosion imaginable on brass and leave it looking like new. |
Phil H1 | 02/10/2018 09:34:34 |
467 forum posts 60 photos | I have a locomotive tender body that has a fair amount of oxide. It has brass beading soft soldered to it round the edges. Apart from elbow grease and emery/ wire wool - anything that might work? Phil H |
Ian S C | 02/10/2018 10:20:13 |
![]() 7468 forum posts 230 photos | Apple Cider, Coca Cola, or any fruit drink will work, but citric acid is probably the best and safest method. The fruit drinks may leave the item a bit sticky, but that will wash off with hot water. Ian S C |
Phil H1 | 02/10/2018 10:22:19 |
467 forum posts 60 photos | Ian, Are you also answering my concern regarding the lead solder i.e., will citric work for the tender with soft soldered beading? Phil H |
Martin Kyte | 02/10/2018 10:42:10 |
![]() 3445 forum posts 62 photos | If you don't want to atack the brass use an alkali. As has already been mooted Horolene is designed to clean old and dirty brass clocks without damage so why not use the right product for the job. regards Martin |
Alan Johnson 7 | 02/10/2018 11:26:55 |
127 forum posts 19 photos | De-zincification is common in old cartridge cases. Worse if they have been on the ocean. I have some Imperial Japanese Navy case, and a few British and Australian from WWI onwards. De-zincification comes from exposure to the atmospheric oxygen - I guess. Not so good either if the case has been buried. You can re-introduce the zinc again by electrolysis - think. Western Australian Maritime Museum (in Fremantle) have had success in stabilising bronze cannons from Dutch wrecks recovered from shallow water on the coast. These ships ran aground in the 1600's. The Museum used a process of a controlled atmosphere rich in fuming zinc (so it was hot) and under pressure to force the zinc back into the metal structure. About 30 years ago I attended a lecture by one of the Museum's curators. The lecture was about such things. They, the Museum, as world leaders in the process were also stabilsing a canon jetisoned (jetsum) from the First Fleet ship HMS Syrius after it ran aground on Norfolk Island - just after the First Fleet had landed at Botany Bay, N.S.W. Not much help for your problem, but you may have to be satisfied with a "copper" finish - as they are very old.
Richard S2 | 02/10/2018 12:57:47 |
![]() 237 forum posts 135 photos | Not knowing how much they have oxidised or the condition, I had good results from using combinations of mixtures of washing liquid, clean pea shingle, stainless steel cream cleaner and white wine vinegar to remove the inside corrosion/staining of my Avon Jet engine starter cartridges- More to do though. The exterior, I used the old formula T cut and elbow grease- These need more internal cleaning for when I'm ready to convert their use as fuel tanks, but the worst is sorted. |
the artfull-codger | 02/10/2018 14:37:56 |
![]() 304 forum posts 28 photos | I use phosphoric acid on brass, it's also good as a flux when soft soldering stainless steel,the annual "yarm fair" is in soon & I usually repair stainless water carriers for some showman friends. |
Neil Wyatt | 02/10/2018 17:46:36 |
![]() 19226 forum posts 749 photos 86 articles | There's another option. You could clean it, then put a thin layer off brass plate on top. Zinc and copper have the unusual property of being able to be plated simultaneously. Take a look at this kit: www.gaterosplating.co.uk/index.php?route=product/product&product_id=203 Neil |
Speedy Builder5 | 11/10/2018 14:59:56 |
OK, so its some time since you all gave me your recommendations. I went with 1/2 cup of vinegar, teaspoon of salt and flour to stiffen into a paste. I have to admit, my wife was both sceptical and wondered as to where all this was leading. Anyway, a couple of coats of the paste, leaving each on for about 1/2 an hour and taking off with a fine ScotchBrite. A final polish with some Duraglit (other brands are available) and a final buffing up. The picture tells the story. (150mm german WW1 Howitzer 'cartridge).
Mick B1 | 11/10/2018 17:31:28 |
2444 forum posts 139 photos | Has the process damaged the headstamps? I know Duraglit can, and I'd expect Scotchbrite could too - though it might be possible to minimise both. |
Speedy Builder5 | 11/10/2018 22:08:05 |
2878 forum posts 248 photos | No, they look good, even see the turning marks on the end of the cartridge. |
Mick B1 | 11/10/2018 22:30:05 |
2444 forum posts 139 photos | Looks like Polte of Magdeburg from Feb 1917. I have a 10,5 cm case by them from May 1916 - currently full of Swiss files.😁 |
