Speedy Builder5 | 06/07/2018 17:31:55 |
2878 forum posts 248 photos | I have made a wind vane from some galvanised steel sheet and mild steel rods and tubes etc. I guess that I should use an etch primer, but would an acid etch with sulphuric or phosphoric acid be just as good or better. Not too fussed about the final paint finish, but once installed, don't want to go onto the roof to re-paint it often. I believe you can mix Jenolite into oil paints to make your own etch primer.
Samsaranda | 06/07/2018 17:43:36 |
![]() 1688 forum posts 16 photos | Most good paint suppliers will supply a ready made etch that works on galvanised, I know our local painting suppliers do, doubt whether you will get anything that’s any good in the DIY supermarkets, need a specialist paint supplier. Dave W |
donkey | 06/07/2018 18:57:06 |
![]() 85 forum posts 5 photos | Cold galvanising paint like " galvafroid". Made for the job |
KWIL | 06/07/2018 19:16:02 |
3681 forum posts 70 photos | Apart from paint-on hi zinc paints as abocve, you can also get hi-zinc spray on that works very well. I have use this paint on galvanised gate hardware with good long term protection, even where the striker hits the latch. |
Maurice | 06/07/2018 20:18:04 |
469 forum posts 50 photos | Galvanised steel should be treated with mordant solution. This will turn it black and allow the paint to adhere. Duluth paints make it, as well as other suppliers. Maurice
Speedy Builder5 | 06/07/2018 20:52:09 |
2878 forum posts 248 photos | Interesting replies, I have used galvafroid, but it doesn't stick to galvanised steel. Now what is Mordant solution ? 10% Phosphoric acid, a touch of copper carbonate and a flammable "paint" mixed in it. Now I need to find out where and what they call it in France. |
richardandtracy | 06/07/2018 22:27:38 |
![]() 943 forum posts 10 photos | On the farm we let galvanised metal weather bare for 6 months, then the oxidised surface held the paint quite well. Regards Richard.
V8Eng | 06/07/2018 23:28:46 |
1826 forum posts 1 photos | We always used Galvafroid on galvanised conduit, over twenty five years since I had any involvement with that work though. Edited By V8Eng on 06/07/2018 23:31:39 Edited By V8Eng on 06/07/2018 23:32:59 Edited By V8Eng on 06/07/2018 23:37:16 |
Monoman | 07/07/2018 08:33:49 |
51 forum posts 7 photos | When proper functional coatings were available calcium plumbate was the 'go to' product. Please note 'plumbate' indicates llead containing thus classified as Toxic. Regards Jerry |
Chris Evans 6 | 07/07/2018 09:11:23 |
![]() 2156 forum posts | Mordant solution is sometimes called Mordant "T" wash. Depends on where in the country you are. I have painted galvanised Land Rover chassis after using the wash. Sold the last Land Rover now but all the time I kept it the paint stayed on. |
Ian S C | 07/07/2018 10:32:49 |
![]() 7468 forum posts 230 photos | To prepare the iron for painting if it's new, wash it with detergent in hot water to get rid of the oil. Ian S C |
Speedy Builder5 | 07/07/2018 10:40:27 |
2878 forum posts 248 photos | Thanks all - I have found a tin of RUSTOL OWATROL on the shelf. It says its a rust preventative which can be used on zinc. I have used it in the past on rusty iron / steel with excellent results, so hope I don't have to shin up onto the roof to re-paint the weather vane too often. |
Russell Eberhardt | 07/07/2018 11:13:46 |
![]() 2785 forum posts 87 photos | Suitable primer available at branches of Castorama: **LINK** Russell |
Speedy Builder5 | 07/07/2018 11:33:04 |
2878 forum posts 248 photos | Well Russell - That seems to fit the bill nicely. Thanks Bob |
Monoman | 07/07/2018 16:09:50 |
51 forum posts 7 photos | But note the safety warning - Dangereux – Respecter les précautions d’emploi. Dangereux = Dangerous, the highest danger classsification under REACH. |
Meunier | 07/07/2018 16:35:02 |
448 forum posts 8 photos | "Can cause sleepiness and vertigo" so be especially careful if you paint it up on the roof ! |
peak4 | 07/07/2018 20:39:39 |
![]() 2207 forum posts 210 photos | I've tried Galvafroid on various Landrover parts in the past, but not found it very long lasting. Rustoleum Cold Galv paint seems to work quite well.
Bill |
mechman48 | 09/07/2018 10:51:38 |
![]() 2947 forum posts 468 photos | 'Hammerite' .... ? |
Speedy Builder5 | 09/07/2018 11:55:41 |
2878 forum posts 248 photos | Hammerite does not 'stick' to galvanising George |
pgk pgk | 09/07/2018 12:00:27 |
2661 forum posts 294 photos | Posted by Speedy Builder5 on 09/07/2018 11:55:41:
Hammerite does not 'stick' to galvanising George I had a look and they do a special metals primer which includes galvanised and also a hammerite direct to galvanised paint **LINK**
pgk |
