Member postings for donkey
Here is a list of all the postings donkey has made in our forums. Click on a thread name to jump to the thread.
Thread: boring 20 mm diameter hole in aluminium
28/09/2023 10:56:19
why not clamp down on a thick piece of ply then the drill will keep the saw true
bri
Thread: A photo for anyone who ever claimed a Myford wasn't a "Proper Industrial Lathe"
03/03/2023 11:00:44
We had a shaper like that in British leyland.
we had competitions as to who could send the chips the furthest.
Thread: Powering a Suds pump?
10/06/2022 10:18:16
thank you Larry
I have a cold saw that needs a pump and had not thought about an old washing machine.
cheers Bri
Thread: Repairing a Myford 4 jaw chuck.
31/03/2022 07:55:57
make four new screws from hex head allen grub screws and then make a new key from a cut off allen key. I have done the same on a myford four jaw.
Thread: Why aren't carbide chop saws used?
31/03/2022 07:50:02
try the clarke CPMCS1 from machine mart.
a cold cutting slow speed circular saw. I have one and it works fine.
brian
Thread: Spark Erosion Machine
09/03/2022 15:07:59
I think the the spark eroder transformer was the RS number 504-329 it was a 50 volt..
Thread: Engineering Industrial Training Board EITB
01/02/2022 22:12:34
I have lathe 1, lathe 2, milling 1 and machining for toolmaking and experimental work.
they can be yours for ten pound plus postage. cannot post until next week as I am away for four days.
Thread: Oxy propane welding kit
19/10/2021 13:40:24
DAVE
I have rented from BOC as a private individual for 40 years.
brian
Thread: Hermes in action - Lost parcel ?
04/09/2021 10:33:29
I had a parcel delivered last week and although I was stood on the doorstep talking to a neighbour at the time he walked up to us and threw it on the floor. I said please dont throw my parcel and the chap said I didn't throw it. just cannot get the staff anymore.
brian
Thread: Paypal payment delay
01/08/2021 17:05:35
damn you Clive foster for suggesting an easy to deal with book shop. now I have more ways to spend money.
Thread: Broken window key
31/07/2021 12:49:06
try melting the end of a glue gun stick and put that on the lock. then you can pull it off and hopefully pulls the key with it.
Bri
Thread: Brazing silver steel: any caveats/recommendations?
06/03/2021 23:14:14
when I was an apprentice in 1976 I made extension allen keys about 18 inches long, small allen keys were inserted into holes drilled into the silver steel and all was well however the 8 mm allen key was arc welded to a silver steel rod with an electrode for joining dissimilar metals it was a 680s rod which may now be known by a different name or number. I never thought that the allen key would hold up to the abuse and over tightening that I put it through but it is still in one piece today. no heat treatment was used afterwards so maybe butt weld using a stainless to steel rod of some type.
Thread: clarke cl500 improvements
04/07/2020 15:06:36
Hi John can I ask what size and make is the quick change tool holder. thanks
Bri
Thread: Whatever happened to...
23/04/2020 10:18:26
Ha. I ate that very same pud yesterday. It was a little out of date, like 8 years but delicious.
brian
Thread: E clip tool
12/04/2020 12:06:44
why can't you use the same tool to remove them by pushing at 180 degrees to the installation direction
brian
Thread: Rip-Off? Don't judge by web domains.
16/09/2019 18:59:13
thanks for the link Michael that is exactly what I have been looking for, never thought to build from a kit.
cheers Brian
Thread: What Did You Do Today 2019
28/07/2019 11:30:33
Ian T
try plasticene instead of grease or playdough.
always worked for me when I was a machine tool fitter for good old British Leyland.
Thread: Source of plastic rod
03/07/2019 18:21:45
I think it was in home bargains or B and M bargains I have bought small rolling pins in plastic for about 1 or 2 pounds.they are about 220mm long and 30 mm diameter or 10 inches by 1 and 1/8 diameter for oldies. they have turned rounded ends and can also be used for rolling pastry.
donkey
Thread: Metal Cutting Power Saw
06/03/2019 08:58:28
machine mart item cpmcs1 it is a cold saw slow revving will deep cut through solid steel. box section etc. it has stops for repeatability angle cuts are easy. and I use one all the time.
I also have a few other power saws but that one is very portable, quiet and accurate.
no links to machine mart via this crazy site are possible. but go to machine mart site search for saw and they are on the second page.
I have seen and used other cold saws but they seem no longer available or way too expensive for hobbyists.
i have no connection with machine mart but find with minor improvements their stuff is ok and I usually wait until vat free day for major puchases.
brian
Thread: Stepper Motor Controls
19/02/2019 16:43:38
thanks all.I now have to assemble everything and give it a go..
brian
