Simon Robinson 4 | 26/01/2017 00:40:05 |
102 forum posts | Hi I was very disappointed after buying a Parkside cordless Dremel like tool from lidl for £16.99. Yes I know you get what what you pay for but this was not good. I only used it on light hobby work and after not long the spindle bearings went meaning the collet and bit wobbled all over the place. I found it very clumsy and not at all precise. My neighbour had exactly the same problem with his, in that the main shaft came loose. Has anyone else bought this tool and had similar experience? My main point is what is the best make of Dremel like tool to get borsch, draper etc, there are several makes, is Dremel the best of all? I'm even prepared to get a used one as its bound to be better than the parkside on I once got. Also what common things if any can go wrong with such tools? (My main use is light grinding, carving and some polishing)
thanks |
Ady1 | 26/01/2017 00:43:21 |
![]() 6137 forum posts 893 photos | You can get your munney back but fixing the bearings might be a good option.? |
Paul Lousick | 26/01/2017 00:56:28 |
2276 forum posts 801 photos | I have had some of the cheaper ones in the past but started to vibrate, probably because it had cheap bearings (after warranty period) and now have a proper Dremel and would recommend it. Still going good after 2+ years. Keep an eye out for when they are on sale at a reduced price. |
Hopper | 26/01/2017 01:05:00 |
![]() 7881 forum posts 397 photos | Get the genuine Dremel. |
Simon Robinson 4 | 26/01/2017 01:13:39 |
102 forum posts | Posted by Ady1 on 26/01/2017 00:43:21:
You can get your munney back but fixing the bearings might be a good option.? Lidl refused to refund me or replace it as they are now a discontinued item I thought of fixing the bearings but not sure if its worth it for the sake of £16.99 especially if something else goes wrong, motors on these have been known to burn out even on light hobby use like I used it for. I only had it for less than a few months when it started playing up during a mamod restoration project which has been on freeze until I get a replacement Dremel. |
John Reese | 26/01/2017 01:59:42 |
![]() 1071 forum posts | Definitely Dremel. If you have very deep pockets DuMore. For flex shaft grinders Foredom |
Adrian Johnstone | 26/01/2017 02:06:35 |
![]() 34 forum posts | If you havea look round on the net, you'll see a lot of discussion around these rotary tools. Dremel's reputation has taken a dive in recent years even amongst our friends across the pond who like to buy American. I have a Proxxon (the mains powered one) which is a very high quality tool that is quiet, has good bearings and will run up to 20,000rpm (which is good for engraving). It is expensive though, but only around three times what you paid at Lidl (if you shop around). I wouldn't go back to using one of the cheaper tools.
Adrian Edited By Adrian Johnstone on 26/01/2017 02:07:11 |
Stephen Benson | 26/01/2017 06:32:55 |
![]() 203 forum posts 69 photos | Another vote for Proxxon I use their industrial dia grinder a brilliant piece of kit and easy to mount in a vice with the optional clamp they also do a cordless version now. |
John Coates | 26/01/2017 07:06:45 |
![]() 558 forum posts 28 photos | Posted by Simon Robinson 4 on 26/01/2017 01:13:39:
You can get your munney back but fixing the bearings might be a good option.? Lidl refused to refund me or replace it as they are now a discontinued item So what if it is discontinued? That's not your problem If it is within their warranty period and they can't replace it they can give you a refund If they disagree tell them you'll go to Trading Standards
Edited By John Coates on 26/01/2017 07:07:25 |
Phil P | 26/01/2017 07:15:00 |
851 forum posts 206 photos | I bought a genuine Dremel years ago, and it started to vibrate badly after a few months. Upon investigation the little metal cooling fan on the motor had started shedding its blades. I then bought a Proxxon and am still using it with no problems many years later. Phil |
James Alford | 26/01/2017 07:15:07 |
501 forum posts 88 photos | I have owned a Dremel for several years now and it has had a lot of heavy use. I have had trouble with it twice, mainly with the collet chuck jamming. On both occasions, Bosch, who seem to own Dremel, arranged to collect it, repair it and return it, fully repaired and all for free. The machine is long out of warranty, which I made clear when I requested the repairs. Based on the service alone, I would recommend one. My model is an older version which has a combined on switch and speed control. I find this annoying as I cannot set the speed and leave it. My Lidl Parkside version has separate controls, which I find much easier to use. However, the collet chuck, made from aluminium, has failed. I don't suppose anyone has a dead Lidl tool with a spare collet chuck? Regards, James.
Edited By James Alford on 26/01/2017 07:16:01 |
John Haine | 26/01/2017 08:06:09 |
5563 forum posts 322 photos | Proxxon +1 |
Russell Eberhardt | 26/01/2017 08:26:37 |
![]() 2785 forum posts 87 photos | I've had a number of Dremels and clones over the years but now have a Proxxon IBS/E and am very satisfied with it. More expensive than some others but well worth the price IMHO. Russell |
HOWARDT | 26/01/2017 08:38:49 |
1081 forum posts 39 photos | Dremel. I had my first one early eighties, motor gave up after fifteen years. Now got two, all corded thinking of getting cordless. |
Ian S C | 26/01/2017 08:48:50 |
![]() 7468 forum posts 230 photos | I bought one made by Black & Decker, within a year it died, got it replaced, within a year it died, got it replaced, about 18 months it died, I pulled it to bits and found that the main drive was a coiled spring about 10 mm long by 6 mm dia, got one from the junk box, put it together, and it lasted another 4 years till the motor died. The previous faults were the same as the one I fixed. I bought a second hand Dremel, and its been going strong for about 15 years. Ian S C |
Neil Wyatt | 26/01/2017 09:17:10 |
![]() 19226 forum posts 749 photos 86 articles | I have to say, the Dremels are exceptionally good. The small cordless has limited battery life (cutting 1.5mm diameter springs at a shallow angle, I could do about six cuts) before it started to flash amber at me. But it come into its won for delicate work which put less load on it, including polishing/cleaning up small items. The larger cordless is fantastic, comes into its own when you have a rusted exhaust fitting under the car etc. and you can charge one battery as you use the other. I have a big corded dremel and a corded wickes one. The wickes feels really agricultural in use compared to the other, I think the Dremels are generally better balanced with better bearings. I must admit my ~17 year-old woolies corded one is still going (it did need one repair, I think a wire broke), although the spindle clamp is now a bit flaky. I've had the body of it too hot to hold! Neil |
pgk pgk | 26/01/2017 10:35:47 |
2661 forum posts 294 photos | Ditto on the woolies corded.. taken heaps of abuse and still going. The first hammer drill i bought from them ble smoked on the first hole I drilled.. was replaced but didn't last manu years. Oddly I found a battery drill of there's i'd forgotten i owned (last week). It's recharged and running -- bit I doubt it'll stay charged long |
AJW | 26/01/2017 10:42:05 |
![]() 388 forum posts 137 photos | I bought a Dremel with the flexibility drive from a boot sale (?5) looks new. Never really wanted one but since I have had it it has been so useful! Dremel, highly recommended! Alan Edited By AJW on 26/01/2017 10:42:47 |
Andrew Tinsley | 26/01/2017 14:02:50 |
1817 forum posts 2 photos | Difficult to decide! I have an Aldi mains version. just under £20. I have given it a rough life and it is going strong after 5 years. Looking at the build quality I just didn't expect such good usage. I have an early mains powered Dremel and that is OK after 15 years of intermittent use. I also have a late model Dremel and it has given me a load of trouble. The new ones seem to be built down to a price. The only good thing is that spares are available. So take your pick! A Proxxon is probably better than all of the above, but I have no experience of them. Yes I have 3 dremel tools and they are in different workshops, One for model planes, one for ME use and one in the house! They can be a lifesaver and so useful! Andrew. |
Peter Tucker | 26/01/2017 17:29:29 |
185 forum posts | Hi Simon, Many yeas ago I bought a dremel, used it very little but once it was out of warranty the motor gave up and couldn't be repaired. Now I buy the cheapest rotary tool I can find and treat them as consumable items. Peter. |
