Johan Crous | 21/01/2013 19:55:25 |
![]() 41 forum posts 1 photos |
I am now making an El Cheapo coolant system for my mini-mill Johan |
Stub Mandrel | 21/01/2013 20:12:55 |
![]() 4318 forum posts 291 photos 1 articles | Hi Johan, You seem to get on well with plumbing! I assume you plan to use suds (soluble oil & water) not neat cutting oil? Neil |
Johan Crous | 21/01/2013 20:29:43 |
![]() 41 forum posts 1 photos | Amix of 1 : 20 soluble oil and water. Greenish in colour.
Jeff Dayman | 21/01/2013 21:18:26 |
2356 forum posts 47 photos | Hi Johan, If your pump is not specifically rated for oil you may find it runs for a while then seizes, as the rubber shaft seal swells from oil exposure. However, the inexpensive "parts washer" pumps sold at discount tool places are rated for oils and solvents and in my experience will work for water also. If you have problems with your fountain pump you might try a parts washer one. Any pump you use will need a very fine screen to keep out chips and metal powder or these will become embedded in the seal (and impeller, if it is rubber) and cause trouble. Personally I like a cheap paintbrush and a tin can to hand-apply cutting oil. Soluable oil makes a heck of a mess of the machine slides and can go septic and smelly if stored too long especially in warm weather. JD |
Paul Lousick | 21/01/2013 23:03:01 |
2276 forum posts 801 photos | Hello Johan, I made my coolant sytem from a 12 volt car windscreen washer pump and a 4 litre plastic bottle. Power from a 12v battery and variable resistor for speed control. Plug pack charger to keep battery topped up. Suction for the pump is from the side of the bottle, not the bottom so any swarf is not picked up. Paul. |
Trevor Drabble | 21/01/2013 23:41:12 |
![]() 339 forum posts 7 photos | Johan, I have used exactly the same system as you describe on a Kennedy power hacksaw for a number of years without any problems whatsoever. My only 2 comments would be that firstly you need to aware that the maximum head is quite limited if you are to maintain a good flow. In my case I have limited it to 300 m/m , and secondly, in order to avoid potential problems with Legionelle contamination which may occure in water-based systems ( which yours and mine obviously are) then it is important to maintain the system properly and clean, flush and replenish the system on a regular basis. It is difficult to give precise guidance since frequency depends on usage, amount of use, ambient temeperature and concentration. In my case, I have undertaken this work on a regular 6 monthly basis. |
I.M. OUTAHERE | 21/01/2013 23:44:28 |
1468 forum posts 3 photos | Hi Johan. If you use a rectangular shaped bucket you could glue in a couple of baffles to slow the coolant flow down and this will allow the sediment to settle out , you could use some sheetmetal and glue them in with sealant just to hold them there . I find the silicone type sealer that works on wet surfaces will stick to just about anything includine me ! What about using some flyscreen mesh as a filter ? Maybe you could use some of this to form a swarf bag that could be cable tied (zip tied ) over the end of the return pipe ? You could remove it to empty it easily and re -use it . Ian.
jason udall | 22/01/2013 00:18:11 |
2032 forum posts 41 photos | Re coolant filter...I use the following on centerless grinders..(very very fine swarf)... one leg of tights or a stocking as your final filter back to coolant tank...use flour sieve as course filter on way to stocking..some where easy to empty....skip this if nothing caught on first try...
Francis Sykes | 22/01/2013 05:54:59 |
43 forum posts 5 photos | I've got a bandsaw modified by the previous owner with a small fountain pump. Works brilliantly, although the comments on maximum head are very valid. |
jason udall | 22/01/2013 10:29:19 |
Posted by jason udall on 22/01/2013 00:18:11:
... or in the light of other threads maybe a sock.... |
Russell Eberhardt | 22/01/2013 14:02:23 |
![]() 2785 forum posts 87 photos | The windscreen washer pumps work well and you can control the speed with a variable voltage power supply. Just note that there seem to be two types, one uses tufnol gears in the pump and one uses plastic. I would try to get the former I've been using (and abusing) one for eight years with no problems.. Russell. |
Michael Cox 1 | 22/01/2013 14:21:32 |
555 forum posts 27 photos | I also used a windscreen wiper motor for a coolant pump on my lathe, see When I was looking at making this mod I found some windscreen washer pumps (branded Linwood) that had rubber impellors. This washer pump was unsuitable for oily fluids. Mike
Alan .204 | 22/01/2013 16:59:00 |
304 forum posts 14 photos | All these motors and pumps make my gravity coolent systems look a bit pants, boy I have a long way to go.
Al. |
Ian S C | 23/01/2013 13:37:51 |
![]() 7468 forum posts 230 photos | My system uses a 250 ml squeeze bottle (PVA GLUE), I didat one stage have a coolant system on my 6 x4 hor/vert band saw, it consisted of a car windscreen washer pump, but it could not handle the soluble cutting oil. When it was working, about 9V was all that was needed. Ian S C |
Johan Crous | 23/01/2013 17:00:13 |
![]() 41 forum posts 1 photos | OK, here is my humble attept:
First, I have used a 17l bucket, cheaply bought from Plastics for Africa. The nearest I could get in the shape that would still allow the garage door to close.
I have added a drip tray that I have painted gray. On top of the mill you can also see the motor cooling system I have added. Now the motor runs cooler as well as the milling cutter.
The mill is mounted on spacers, that I have sealed with silicone rubber seals as well as a lot of silicone. It is not leaking at all.
The drain is from a boat shop. A smaller than usual basin drain, linked with a pipe to the container.
The return pipe I have covered with a T-shirts sleave to catch all steelal swarf. The material is freeflow for the water. The motor is lying loose. I will make a T fitting later to circulate some fluid directly back to lighter the strain on the motor. It is stronger than needed.
The pipe is coupled to a cheap plastic coolant spout set. Easily and very cheap to replace. This whole set-up is the price of one milling cutter.
Here the coolant is running at the rate I like currently. Time will learn if I should adjust. The flow is aimed on the workpiece, well away from the cutter, but the cutter get enough fluid to stay almost cold, but without the rotating cutter spattering water. (OK, OK, OK, I know the cutter is stationary but I have already switched off when I realised I forgot to take a pic of this last step.
This is a cheap set-up. Only time will learn if the motor's seals or the motor will last. Some people say it will not. Other said they have used it some years like that. So the hell with that. I am trying. If it can last at least a year, then I would have got my money back. I will have to drill a drainage hole in the tables side plate, as currently the coolant is damming up in the t-slots. The cover plate can be removed, so a hole of about 6mm will be enough. Edited By Johan Crous on 23/01/2013 17:06:31 |
Johan Crous | 24/01/2013 18:52:33 |
![]() 41 forum posts 1 photos | I have milled for about an hour today. The motor keeps moderately cool and the cutter remains cold. IT works, even for a homemade carbide insert dovetail cuter. However I have ruined the cutter that ran too hot before the coolant. Tapping fluid as a coolant did not cooled it down enough. The cutter, after sharpened will again be excellent for aluminium and brass. |
Johan Crous | 25/01/2013 16:41:18 |
![]() 41 forum posts 1 photos | There is one further need, and that is perspex sides as splash covers. The dovetail cutter makes a mess!
Carl Wilson 4 | 30/07/2013 22:15:54 |
![]() 670 forum posts 53 photos | Hello, Plastic garden spray bottle. Remove atomising spray lance and replace with proprietary magnetic base and positionable spout. Fill with your favourite soluble/non soluble lubricant. Drip tray to catch back into a bucket. Pump handle mandraulically. Coolant sprays out, empty bucket back into spray bottle when done. No electricity required. Carl. |
Robbo | 31/07/2013 09:42:40 |
1504 forum posts 142 photos | Johan, All I would add is a bit of gauze/wire wool etc actually in the drain plug hole to catch swarf before it gets into the pipework, A bit of that stainless steel pan scrubber from the supermarket kitchen aisle would be ideal, and top off an excellent job. |
mechman48 | 27/12/2015 19:37:05 |
![]() 2947 forum posts 468 photos | Have finished putting together my mist / coolant system for my WM16, have connected it from my compressor a tee piece through a surplus garden sprayer container ( suitably modified ) to a home made mixer block with aquarium variable flow valve for the liquid & adjustable air valve & it works, to a degree, I can get air jet on its own & same with coolant on its own, plus can get a mix of both. The trouble I have is with the flexible coolant spout set, it leaks at just about every other ball joint with any of the combination of the aforesaid. I have tried to rotate each ball joint to check for seating in the mating cup ( they are all stiff ) as I reckoned it might need some bedding together... just the same result ... air / water or both still leak from the joints. Looking at Johan Crous's write up & pics (earlier on in this thread ) his spout system doesn't show a drop of anything coming from any of the joints... I have considered reverting to a straight plastic pipe for the nozzle assembly... Have I missed something in the set up? ... any help would be appreciated... Not operating at the mo'... but out of the 21 ball joints at least 12 of them leak. George. |
