Where can I 'repurpose' it from?
icon | 24/12/2012 14:01:13 |
7 forum posts | Hi I need a tiny amount of 0.020" spring steel for the number punch holder of Thomas/Hemingway's universal pillar tool - 0.2" x a couple of inches. I don't really want to buy several lifetimes worth. There must be some common household or workshop object I can rob something suitable from? My imagination has failed me and I can't think of any. Cheers John |
Roderick Jenkins | 24/12/2012 14:06:36 |
![]() 2376 forum posts 800 photos | John, I used hammered brass for mine. I bashed a piece of brass rod flat - the consequent work hardening makes it quite springy enough for this job. Happy Christmas Rod
NJH | 24/12/2012 14:10:04 |
![]() 2314 forum posts 139 photos | Old clock spring from jumble sale / flea market ? Norman |
Michael Cox 1 | 24/12/2012 14:19:10 |
555 forum posts 27 photos | I used a different approach and employed a magnet to retain the punch in the holder, see Mike |
Jeff Dayman | 24/12/2012 14:20:22 |
2356 forum posts 47 photos | Th recoil starter on any mower or weed trimmer engine has several feet of top quality spring steel strip. You can probably get a used one with a broken end free from a mower or small engine shop. There will likely be hundreds of scrap engines at a metal scrap yard, you can get one there for very little money. JD |
Michael Gilligan | 24/12/2012 14:24:23 |
![]() 23121 forum posts 1360 photos | Retracting Tape Measure MichaelG.
Chris Shelton | 24/12/2012 14:56:27 |
![]() 92 forum posts 46 photos | Could use feeler gauge. |
Billy Mills | 24/12/2012 15:11:32 |
377 forum posts | "Piano wire" from model shop bent into a thin U shape, could go through hole to press onto stamp. Lenth of vac form plastic from the margins of packaging ( full thickness) or plasticard. Old relay contact or switch contact. Mike Cox's method is very neat too! Billy. |
JasonB | 24/12/2012 15:49:41 |
![]() 25215 forum posts 3105 photos 1 articles | Reeves and several of the other suppliers sell it in 12 or 24" strips
Les Jones 1 | 24/12/2012 16:20:59 |
2292 forum posts 159 photos |
Hi John, Les. |
Terryd | 24/12/2012 16:27:01 |
![]() 1946 forum posts 179 photos |
Posted by NJH on 24/12/2012 14:10:04:
Old clock spring from jumble sale / flea market ? Norman or a charity shop where I managed to get several old alarm clocks for around 50p each. Seasons greetings, Terry |
KWIL | 24/12/2012 16:33:03 |
3681 forum posts 70 photos | Look at M-Machine catalogue, you can get about 12" for a £1!! |
Berty | 25/12/2012 02:35:58 |
15 forum posts | John, Look inside an old VHS type video cassette. Turn cassette over on bench, remove five crosshead screws, separate top and bottom halves of cassette. Flat spring is in top half of cassette, carefully prise off. It is there to hold the tape reels down so that they don't ride up and lift off of the turntables below. Might be useful. regards Derek |
icon | 25/12/2012 08:25:56 |
7 forum posts | What a resourceful lot you all are! Some great ideas here. Why I didn't at least think of clock spring, I don't know. Bleedin' obvious, really. Merry Yuletide to all John |
Terryd | 25/12/2012 09:36:34 |
![]() 1946 forum posts 179 photos | Hi KWIL, But they charge a minimum of £4.50p for postage which makes it less of a bargain, Seasons greetings, Terry |
JohnF | 25/12/2012 10:47:49 |
![]() 1243 forum posts 202 photos | John [icon] Seaspns greetings, message me and I will send you some, have plenty of suitable material in my "stores" Cheers John |
KWIL | 25/12/2012 10:52:25 |
3681 forum posts 70 photos | Terry, Season's Greetings to you of course. I know they charge postage but there is always something else you want, I must give them an order to collect when I go to Harrogate in May. K |
V8Eng | 25/12/2012 12:10:02 |
1826 forum posts 1 photos | I don't know where you live but it might be worth seeing if there are any local clock repairers, pop round and ask politely,you never know your luck! Happy Christmas. |
Stub Mandrel | 27/12/2012 13:11:42 |
![]() 4318 forum posts 291 photos 1 articles | Thanks Jeff, I've had a coil of blue spring steel ona spool in my workshop for years. You've just made me remmebr where I got it from - recoil starter off an old genny! Neil |
D.A.Godley | 27/12/2012 18:33:49 |
143 forum posts 41 photos |
Posted by Stub Mandrel on 27/12/2012 13:11:42:
Your post did it for me Stub, brought memories of an old Jenny flooding back, Ah the delights of Nairobi 1969. Now that was Model engineering!!!
