Here is a list of all the postings icon has made in our forums. Click on a thread name to jump to the thread.
Thread: Anyone know their vices? |
29/05/2013 21:25:14 |
Ah thanks all. Rod; mine has similar markings, except it says 'IR3' and 'OR3'. They must have got fed up with that design sometime between 1960 and recent times. I'll bet someone has a cabinet full of odd-shaped nuts for these, somewhere. I was hoping to just buy one because I don't have a 1/2" BSW tap. This is a model engineering forum, after all! I might have to wander down to the local narrow gauge railway and see if I can have the borrow of one. Cheers John |
29/05/2013 16:49:07 |
Posted by roy entwistle on 29/05/2013 15:42:41:
Try googling record vice spares Roy Well, yes, good advice. I did that before I posted here, which is how I know that current Record swivel bases look like this:
Where the swivelling bit is different to mine. Also, although I've seen spares for the vice itself, I haven't seen spares for the base. So if you have a specific link, that would be welcome.
Regards John |
29/05/2013 12:51:11 |
Hi I have a Record No. 3 vice with a swivel base. Trouble is, the swivel base has a nut that's split. The base looks like this:
And the nut looks like this:
[IMG]
(Edit - whoah, aspect ratio is all wrong, but hopefully you can make it out) The othe nut just split it two. I thought I would be able to buy one as a spare, but the images of swivel bases I've seen are completely different to this one. Could this be an 'early' Record, or a different manufacturer that just happens to fit? Any leads gratefully received. Regards John Edited By icon on 29/05/2013 12:53:55 Edited By icon on 29/05/2013 12:55:04 |
Thread: Source of small quantities of spring steel |
25/12/2012 08:25:56 |
What a resourceful lot you all are! Some great ideas here. Why I didn't at least think of clock spring, I don't know. Bleedin' obvious, really. Merry Yuletide to all John |
24/12/2012 14:01:13 |
Hi I need a tiny amount of 0.020" spring steel for the number punch holder of Thomas/Hemingway's universal pillar tool - 0.2" x a couple of inches. I don't really want to buy several lifetimes worth. There must be some common household or workshop object I can rob something suitable from? My imagination has failed me and I can't think of any. Cheers John |
Thread: Myford ML7R tailstock - how to disassemble? |
12/12/2012 13:03:27 |
Thanks David - that's what I needed to see. Stone me! It was on pretty damn tight, but I rummaged out a C spanner and a 2' tube that fit over the handle. That shifted it. Cheers John |
12/12/2012 10:27:00 |
Hi I'm trying to dismantle the tailstock from my ML7R. There's a turned steel component fixed into the back (right hand end) of the main casting - it has an oil nipple and a 1/4" hole in it. Myford call it a 'cap' in their diagram. It must be secured somehow, because it takes the thrust loads, but I'm being dense and I can't see what's holding it in place. There's a photo of it in GH Thomas' MEWM (photo 97) which seem to show two grooves. Can anyone give me a clue? Cheers John |
