Workshop condensation
corbrae | 30/01/2011 11:24:02 |
3 forum posts | Hi There
I have condensation problems in my concrete sectional Garage used as my Workshop, I run a Dehumidifier all day and that helps a lot. I wonder if others have suffered the same problem and how they managed to cure it.
Thanks
Bob Short |
Steve Garnett | 30/01/2011 11:39:26 |
837 forum posts 27 photos | It's been quite extensively discussed before - here are a couple of threads to look at: |
Keith Long | 30/01/2011 11:40:16 |
883 forum posts 11 photos | Hi Bob Have a look at the thread "Workshop heating", there was quite a lot in there about how folks keep the workshops habitable and dry. Keith |
Mike | 30/01/2011 11:40:58 |
![]() 713 forum posts 6 photos | Over the last month I have been trying Superdry dessicant packs in my damp workshop - the big packs suspended from the ceiling near lathe and mill, and small packs in tool containers. A bit early to give you a definitive verdict, but all seems well at the moment. With your dehumidifier, probably just a few packs in with your tools and any stocks of steel you keep would be sufficient. Full details of the products at www.airandwatercentre.com.
Hope this is helpful. |
Terryd | 30/01/2011 12:35:14 |
![]() 1946 forum posts 179 photos | Hi Corbrae, this is a perennial problem most of us suffer from. I have a detached garage which I use as a workshop (brick cavity wall and insulated ceiling) and used to get lots of condensation. I couldn't afford to run a large enough dehumidifier. However itthe grage has had to be rebuilt after a fire and I am taking the opportunity to have a couple of large radiators linked to the household heating system which hopefully will help. Of course the long term solution is prevention by modification of your building with insulation, heating, double lining, draught proofing etc etc but this gets expensive and it depends how far you wish to go and how much you can afford to spend.. However that is a rather drastic solution, in the interim there are a few simple things to try including using dessicant products and protective waxes and oils. for a relatively small layout of a few pounds you can provide a good level of protection. I have seen the Superdry products but they seem rather expensive as they are 'one-shot' disposable products which cannot be regenerated. As an interim solution I use impermeable plastic covers for my machines, I use heavy duty polythene, some folks advocate cotton, but as that is a good absorber of moisture personally I think not. After all if such plastic (PVC) covers are good enough for Myford, they should be good enough for me. I then keep a 100gm silica gel pack with each machine. This creates a dry micro environment around each machine, the plastic cover preventing more moisture entering. Silica gel dessicant can be regenerated in the microwave in a couple of minutes and lasts for a long time. It is available in 100 gm bags on eBay for for as little as £6.00 for 5 (in. postage). You can even get some small colour change bags to keep in as well which tell you when to regeneration is necessary. Tools can be kept in drawers and cupboards, again with these bags of SG. There are products with which you can protect your equipment by coating barriers, such as waxes and oils. Some examples are shown here at Arc Eurotrade. Best regards Terry Edited By Terryd on 30/01/2011 12:38:19 |
GoCreate | 30/01/2011 16:55:55 |
![]() 387 forum posts 119 photos | My first workshop was a concrete sectional construction garage.
I lined it out, including covering over the up and over door, with a sheet of polythene, then 1" thick polystyrene and 3/8" ply. The ply was screwed to a vertical wood battens secured to the wall panel clamp plates. I made a false ceiling with I think 2 x 2 timber frame and 1/8 ply insulated with loft insulation. Because I covered the up and over door, which improved security as this opened onto a street, I made and fitted a side door by removing one set of wall panels.
The concrete floor was painted, coverd with lanimate flooring underlay and then a layer of loft floor boards. The boards did tend to waer a bit so later I glued on some vinyl tiles.
I heated it with a 2kw convection heater, I had no problems with condensation and did not use dehumidifiers. I allowed the heater to heat slowly, turning it on a hour before I went in, I think this helps reduce condensation tendancies. after a bout 3 hours it was as warm as toast even on the coldest day.
It's alot of work and expence but I expect cheaper that running a dehumidifier over a period of time.
Apart from the floor I have done the same with my current workshop though this is block built and rendered, again I have no problems with condensation
My first workshop was in NE england by the sea, my current workshop is in the Grampians Scotland, both locations prone to cold damp weather at times.
My experiance is that it's well worth the effort and expence, it can be tricky and frustrating to do when the workshop is full of your gear.
Hope this helps
Nigel Edited By tractionengine42 on 30/01/2011 17:02:11 |
corbrae | 06/02/2011 18:36:09 |
3 forum posts | Many thanks to all who have read and replied going to re roof when weather gets better
and get rid of the Steel corragated
will advise later
Bob |
Gordon A | 06/02/2011 21:17:10 |
157 forum posts 4 photos | Greetings Corbrae, It is interesting that you are getting rid of your steel roof when the weather gets better. I will be replacing my rotting wooden shed/workshop roof with profiled steel sheeting when the weather gets better! I don't know what you intend to use as a replacement for your roof, but maybe you could retain the existing if it is in good condition and invest in better insulation instead. I will be using "ThermaWrap" as a vapour barrier and additional insulation (similar products are available). I was surprised to discover that despite being 4mm thick, the manufacturer claims insulation properties equivalent to 65mm of polystyrene! Another insulation product I have used is Celotex ( Kingspan is a similar product). This is a dense rigid foam sheet with aluminium foil either side that has very good insulating properties and available in a range of thicknesses. Apologies if you have already looked at these products, they are not cheap, but this is the route I am taking to help keeping precious tools and equipment as free as possible of the dreaded metal mould . Does anyone out there remember a magazine article some years ago on making a lathe bed heater to prevent condensation? Basically as I recall, it was a small number of high wattage resistors bolted to a sheet of aluminium which was bolted to the machine bed. This arrangement was powered by a low voltage source with the intention of maintaining the lathe (or miller, or shaper etc.) at slightly above ambient temperature when the workshop was "resting". Regards, Gordon A |
Peter G. Shaw | 06/02/2011 21:34:30 |
![]() 1531 forum posts 44 photos | Gordon, Not so much make, as buy. I have fitted, and reported via MEW, using a pair of self-regulating 10W heaters available from RS Components. Although these devices are rated at 10W, they actually are taking 18W each, or they were when I checked. Anyway, since then the lathe has never had that bone-chillingly cold feel in cold weather, and has not had any condensation whatsover. I also chuck an old table cloth folded double over it and at one time used to also use a sheet of plastic as well. I don't use the plastic now. There are alternatives. Dave Fenner, the previous editor of MEW was going to try something else: I think it was the self-heating tape and then report back. I don't recall seeing it, but can't see why it shouldn't work. Someone else used a 10 or 15W incandescent bulb under his bed. In short, the idea is to keep the lathe just slightly above the lowest air temperature thus stopping condensation. It certainly works for me and my garage does have a nasty tendency to leak - usually when it rains heavily if it's going to do! And anyway, it's more or less permanently damp - rain gets under the front door, a rear wall often shows signs of damp especially when the wind and rain combine to blow from the SW. Regards, Peter G. Shaw |
Terryd | 06/02/2011 23:08:44 |
![]() 1946 forum posts 179 photos | Hi Peter, Just a few thoughts, sorry it is so long, I won't mind if you fall asleep from time to time. Another common and cheap heater can be made from a couple of 240V, 15 Watt incandescent bulbs in batten bulb holders connected in series, together with a suitable light switch on a wooden base with a flying lead to a 13A outlet. As the lamps are connected in series they are each receiving 120V so their life can be measured in 10s of years probably (i have incandescents working that I replaced when I moved into this property 18 years ago still going strong - so much for the so called 'energy saving bulbs'). It is still a good idea to cover your machine with a waterproof cover a lá Myford and keep a desiccant silica gel pack(50 or 100gm) enclosed to reduce humidity. I'm afraid I can't agree with you tablecloth, as cotton is an extremely good absorber of moisture, hence it's use in our more intimate garments and summer and sports clothes. (Notice how damp tee shirts remain in hot summer as they absorb body moisture and the ambient humidity of the air does not evaporate that moisture as it's dew point is higher) It will simply absorb moisture and keep it in contact with your metalwork. A moisture proof cover and dessicant will provide a micro environment with air having a lower humidity in that micro environment, hence higher dew point and less condensation. Plastic above cotton is just about the worst combination - no evaporation. Also it is not enough to keep the temperature of the equipment "just slightly above the lowest air temperature thus stopping condensation." The temperature must be kept above the Dew point of the atmosphere. The dew point will vary according to temperature and humidity of the air. The dew point is crucial in this process. Hoar frost in winter is formed on trees and bushes when the temperature of the surface of the plants which may be the same as the atmosphere, but it is below the dew point so moisture condenses from the air as it meets the plant and then freezes according to the air temperature. It is the same process when dew form in spring and summer mornings and tropical forests. Insulation and vapour barriers etc are only a part of the solution to condensation. There must also be heat to retain, after all, all that insulation does is retain heat. It does not create heat. My own bungalow has solid insulated floors, cavity wall insulation, 18" of loft insulation and deep double glazing. We also have sophisticated draught exclusion systems on most doors and windows, not all, to allow air exchange. However if I leave it for a week in freezing temperatures without a heat source I can guarantee that I will have burst pipes and a substantial bill when I return, Keeping condensation away involves a combination of strategies including insulation, providing sufficient heat and creating the correct environment, if this can not be done for the whole space then create micro environments around valuable equipment. I have just had my detached garage workshop rebuilt following a fire and am lucky that the previous owner had the walls built as cavity type. The ceiling is plaster boarded with 180mm of insulation above, it has double glazed windows and a sealed and insulated electric retracting door. This is heaven but I still have to heat the place or all of the insulation etc will be of nothing otherwise. at the moment it has condensation every evening as the temperature falls, I intend to extend the house central heating (underground pipes are installed) into the garage with froststat control. I'll also create micro environments for each machine and critical area using some of the techniques I have discussed using quite inexpensive methods. I will report on it's long term efficiency at some future date. Best regards Terry |
Chris Crosskey | 08/02/2011 15:03:12 |
15 forum posts | Thanks for this thread, I'm in pretty much a similar boat and was going to ask pretty much the same question.... having measured mine I think I'll be going for polystyrene 50mm in the walls, 25mm in the floor and loft insulation in the roof with DPM and plasterboard for the walls and dpm and hardboard on frames for the roof... Floor will go DPM-screed-insualtion-floorboards but under the two main machines it'll go DP-screed-brick-built plinth with absolutley levelled surface. I'll look at putting some sort of very low level heating in on or near the machines. Looking forward to this, going from my old 11x7 shed to a 17x9 with additional storage.... if nothing elseI'll have the space to rebuild the mill at last.... chrisc |
NJH | 08/02/2011 17:54:12 |
![]() 2314 forum posts 139 photos | Terry you right here - I find that the dew point is critical to avoiding condensation. My workshop is 10ft.x17ft x 7ft and I took a great deal of trouble in insulating it. I have been collecting data over the last year and you may be pleasantly surprised at how little you will need to do to keep the dreaded condensation at bay! I have been monitoring the temperature and humidity (max and min) and calculating the dew point each day. I have a small oil filled radiator as background heat in the workshop - the attached garage is unheated and I also monitor the temperature there to provide a simulated "unheated workshop" I don't cover the machines, provide local heat or spray wd etc. A major advantage of good insulation is that changes in temperature are damped - when rapid changes of temperature occur it is easy to encounter the dew point and experience the dreaded condensation- the damping helps to avoid these swings. Since Jan 2010 the workshop temperature range has been 3.3 min 22.8 max The unheated section has been -2.7min 21.9 max At all times the workshop temperature has been above the dew point - no condensation - no rust! The cost of running the heater for the year was £65. Yes I'd rather spend it on tools or materials but it seems to me a small price to pay to keep a lot of expensive kit in good order. All the data is logged on a big excel sheet with lots of pretty graphs - I am happy to supply further details if anyone is interested. Regards Norman Edited By NJH on 08/02/2011 18:00:11 Edited By NJH on 08/02/2011 18:03:39 |
Terryd | 09/02/2011 06:44:55 |
![]() 1946 forum posts 179 photos | Hi Norman,
I agree with you. The temperature of the equipment to be protected only needs to be kept just above that of the dew point of the air. I have connected my detached garage to the domestic heating system and am experimenting with the size of radiators at the moment and have quite a small one which seems to be doing the job. i have bought a double sensor (cheap from China of course) thermometer to use as a humidistat in order to keep the same sort of records as yourself.
Some folks though see insulation as the solution, when in fact heat is the solution, insulation merely slows down the heat loss for economic reasons. The reason i use plastic machine covers is that the provide an impenetrable barrier for moisture and if you dry the enclosed air you create a dry micro environment meaning that less heat is required. Polythene and silica gel are cheap and effective, and silica gel can be reactivated in a few minutes in a microwave.
I also recommend providing a barrier on vulnerable surfaces such as slideways by using chemical barriers such as those provided by Arc Eurotrade. These are my double insurance. My reasoning for the extra protection is that if you raise the temperature of the workshop, the dew point of the air is raised as the air can hold more moisture, so condensation can still occur in certain conditions. It's a catch 22.
Best regards
Terry |
Nicholas Farr | 09/02/2011 11:19:17 |
![]() 3988 forum posts 1799 photos | Hi, humidity is the real problem. As far as rusting is cncerned, a cold dry room is better than a warm humid room, but of course a cold room is not comfortable to work in. One other solution to reduce the humidity, but keep the heating costs down when not in use, may be to fit a small extracter fan like those you find in your loo/bathroom, you can get them with a humiditystat fitted, and they will cut in and out automatically, and I have heard that they are very effective.
I once saw a programme on TV about an airplane which had to be ditched in the artic during WW2 for some reason. The programme was about some presivation scheme to recover and restore the airplane. Althuogh the airplane had been standing there for 40 odd years or so, there was no rust or coorosion on it because the air was so cold all of the time. This ment that there was no humidity in the atmosphere, no humidity no rust.
I've found in my unheated garage that things seem to get a little rust on them in damp weather, but not so much when it is cold and frosty. But like Terry I keep my machines covered over with a plastic sheet (piece of damproof membrain bulders use) but as yet don't have any method of low heating or silica gel, but they do have a smear of oil on them.
May be a bit of useless information for you.
Regards Nick |
Peter G. Shaw | 09/02/2011 13:02:49 |
![]() 1531 forum posts 44 photos | Hi Terry, I don't know what the old tablecloth is made from. All I know is that it is green, torn, and got a raised pattern on it. Actually, come to think of it, I don't even know if it was a tablecloth, it's been there so long. I suspect it's actually a manmade fibre. Don't know anything about dew points, hygrostatics or whatever. What I do know is that my system has worked well now for a few years in that rusting does not appear even in the cold weather we've experienced recently, so something must be right. Ok, extreme cold means that the air cannot hold as much water so maybe that's nothing to go by for me. I think that from my point of view, strictly as an amateur, if something works, then that's good enough and in this sort of situation, where I simply am not interested, deep technical discussions simply glaze the eyes. Don't misunderstand me - the fact that you do know about it and can advise as such is a bonus not to be sniffed at, and I thank you for your comments. Maybe I'll resurrect the old piece of plastic as well. Interestingly, I use the same principle on the miller - small heater, miller covered by the plastic bag it originally came in, and on top of that a cloth thingy which came from my parents some years ago. Again I don't know what the cloth is, suspect something manmade, and probably a seat cover or something similar. (Mother was into making things like that.) Anyway, it does seem to keep it slightly warm, possibly not quite enough as I only use one heater. And considering that the garage has sprung yet another leak recently..... ![]() Perhaps I should take up knitting! Regards, Peter G. Shaw |
The Merry Miller | 09/02/2011 15:22:38 |
![]() 484 forum posts 97 photos | Now Peter, as regards taking up knitting and condensation getting into your balls of wool and onto your metallic knitting needles !!!! Edited By The Merry Miller on 09/02/2011 15:23:02 |
John Harding | 09/02/2011 16:04:32 |
33 forum posts | Hi, the best route to preventing or removing condensation is good ventilation. As those of you fortunate to still have a bathroom with a window opening onto the outdoors will know that opening the window soon clears the condensation. The standard 4" fan is pretty ineffective; if using a fan, install a 6" or 9" fan and provide a matching size inlet on the opposite end of the workshop. If the workshop is heated only while working in it, then before quitting, it might be worth leaving the door open for a few minutes to flush out the warm humid air. Past experience taught me that insulating a suspended floor makes a really difference. On this occassion I had lined the roof and walls first with polythene to draught proof and then with polystyrene, followed by hardboard. It was only by covering the floor with polystyrene that the shed would hold the required temperature. For several years I stored woodworking tools in all plywood cupboard standing in a garage. Tte cupboard size 4ft high x 3ft x2ft required just one night light bulb of 8 or10watts, which would last all winter. The bulb stood on the floor of the cupboard. I started with 40 watt and then 25 watt bulbs which quickly burnt out. Regards, John Harding |
Nicholas Farr | 09/02/2011 16:25:19 |
Posted by John Harding on 09/02/2011 16:04:32:
At my old company where I used to be, we had steel cubboards for storing MMA welding electrodes which had a 110v 100w bulb. That kept them dry a treat.
Regards Nick |
Ian S C | 10/02/2011 11:32:21 |
![]() 7468 forum posts 230 photos | One thing I have used is a solar powered fan to ventilate a shipping container that was being used for storage, it had a battery charged by a solar cell, very handy as the container was out in a paddock away from mains power. Ian S C |
Roderick Jenkins | 10/02/2011 13:21:03 |
![]() 2376 forum posts 800 photos | I don't think ventillation helps much unless you are actually generating moisture in the room, like in a bathroom.. I used to work in a laboratory that had 20 changes of air per hour. It was in a substantial building with radiator heating. Eveything rusted like crazy because there was a constant stream of moist air being introduced form outside.
In the past I used an oil filled radiator, on a timer, behind the lathe which was on a Myford stand. The timer came on from a couple of hours before dawn and this warmed the lathe so that it was not colder than the air. The really bad days were after a cold snap, when evrything got cold, and then a warm westerly blew in from the Atlantic. Fortunately my current workshop is in the garage adjacent to the house and contains the balanced flue central heating boiler. Not always warm, but always rust free. |
