Here is a list of all the postings The Merry Miller has made in our forums. Click on a thread name to jump to the thread.
Thread: THE MERRY MILLER AKA LEN.P |
01/04/2017 14:37:09 |
Hi All, Just a line to let you all know that my Father-in-Law, The Merry Miller AKA Len P. sadly passed away, very unexpectedly this January. I know he was an avid follower of these forums, and loved to chat with many. Tod Len's Son-in-Law |
Thread: Issue date for MEW |
02/09/2016 14:37:49 |
Afternoon Neil, Is there any chance that the issue dates for MEW can be shown on the Forum front page. For the first time I can remember the issue date for MEW 246 does not appear inside the latest MEW (245) . Regards, Len. P |
Thread: A Lathe Bible Book |
03/01/2016 11:41:04 |
DjVU is a reader only that you can download from the net. I use it for looking at files, mainly family tree census files that have been downloaded and can only be read using DjVU. Happy New Year to all. Len. P.
Thread: Myford rear toolpost |
14/12/2015 16:25:15 |
Hello Grotto !!! Below you will see some pics of the rear toolpost that fits on to the extended cross slide of my Myford ML7-R It uses the standard Myford boat tool that you can adjust to the centre height without much/any trouble. If you can get hold of one of these all power to your elbow. Len. |
Thread: Speed Control of Single Phase Motors |
25/11/2015 15:17:05 |
I have a variable speed pulley fitted to my Axminster wood turning lathe. I think the lathe is the old M950. Very effective it is too, the variable speed that is. Len. P.
Edited By The Merry Miller on 25/11/2015 15:18:49 |
Thread: Unusual but useful workshop tools |
18/11/2015 15:18:45 |
Ady 1 Just received four Cree head torches from CPC The grandchildren will use them when they take the dogs out in the evening, Incredible value at £1.50 each. (Including VAT) Len. P.
Thread: RPM Counter connections |
16/11/2015 11:57:42 |
This the one I have just ordered..
Len.P
16/11/2015 11:23:38 |
I now have had a response from the Ebay supplier of my Tacho display. They cannot send a replacement as they are having trouble with their supplier. They have offered to refund me the purchase price of £6.99 and I have accepted. Now to search for another one. Len.P.
Thread: Looking for a book from the 40s/50s |
14/11/2015 17:11:51 |
James, There's one for sale on Ebay right now. Len. P. |
14/11/2015 10:06:48 |
Not a glimmer from the display when just hooked up to the PSU Trying to contact the original seller in China through Ebay is a mammoth task so I've given up on that one. What I'm going to do is make a calibrated dial using a laser tacho/rev counter and attach that to the mill control unit. Len. P.S. I haven't really given up on the display. I'll try again later to see if he will replace it without me posting the duff one back to him, it's just making contact is the problem. Len. P. |
13/11/2015 15:40:49 |
Gordon, Mine was connected as John's. just went out to double check and confirmed it. Still no display, I now assume that the display is duff. It's too much bother to send it back. Thanks all. Len.P. |
13/11/2015 14:23:40 |
Gordon and John, I too purchased one of these Tacho's and it came with no wiring info. After pressing the vendor eventually received this comprehensive diagram. Thinking that this was less than useless I pressed them again and received the next bit of info as under. I thought now this is much better and decided to take up a course as a Chinese interpreter before pressing them again. I subsequently received the diagram as under together with a pleading request from the vendor to leave them "positive feedback"
Well this enabled me to wire up in a fashion after interpreting what I thought they meant and guess what, it didn't work. Any helpful suggestions would be appreciated apart from dumping it !!! Len. P.
Thread: rev counter for lathe |
30/10/2015 14:17:38 |
Bandersnatch, I have sent you a P.M. Len.P. |
Thread: Weight and transportability of a Myford lathe |
27/08/2015 20:08:35 |
Roger, Another word of advice. Before you or any helper with you attempt any manual lifting or manipulation make sure that you clean off any oil that may be lurking on the surfaces in the zone of lifting. I did not and when my son-in-law and I went to lift my Myford into the garage/workshop, my son-in-law (who could lift the side of a house) nearly lost it holding the headstock end because I hadn't cleaned the oil from it. Just beware!! Len. P.
Thread: Hand cleaner |
21/06/2015 14:38:47 |
I've been using Manista for many years. My son-in-law on a recent visit said to me "what are you using that stuff for" Here's what I use at home, Squirt some washing up liquid on the palm of your hand, add a little salt from the salt hopoer in the kitchen and rub. It worked briliantly. Len.P.
Thread: Best vice |
21/06/2015 14:32:21 |
I brought home my 4" engineers vice on the back of my motorbike ( for the enthusiasts, a Francis Barnett 225cc Cruiser) back in 1962 when I was working at Ozalid in Loughton, Essex. It was and still is a Woden 190/TA with quick release. It say's on the side "Steel" as opposed to I suppose to "Cast iron" I recently dumped the magnetic protective jaw protectors and fitted the version that you have missed i.e fibre and bent tin plate (or bent zinc plated steel) As you are now aware are readily available from the E-something or other website. I recently removed that from my bench and fitted an Eclipse 4" swivel vice, beautiful vice but I think I will try to refit the Woden because I miss it !!! and I will have room once I remove the Arbour Press. Len.P.
Thread: Making a weird connector |
07/05/2015 17:04:27 |
Roger, Have a look at the range of 62GB connectors from Amphenol. I used to use this series on military equipment in the '70s '80s and '90s. Farnell do some of the range but there are also others who may do!
Len.P |
Thread: Pounds/foot (and other nonsense) MEW 226 |
02/03/2015 16:29:05 |
I would always taught to remember "torque" as a "pound" at one "foot" as if using a force of one pound at the end of a lever one foot long. not a "foot at one pound" or ft-lb. thus "pound-feet" is lb-ft is "Torque" Len.
Thread: Height adjustable Workshop seat |
26/02/2015 17:41:50 |
Geoff, Just a word of warning for you and all others who use a swivel chair with castors in the workshop, just keep it as a chair for the desk. I had one in my workshop for a while until one day I went to sit on it whilst carrying a heavy load in both hands, and it just shot away from under me, not having a free hand to grab it. It put the fear of -------- into me and I resolved not to have one in my workshop again, I could have caused myself a serious injury if it hadn't been for my lightning reactions I now have a stool with a height adjustable seat and three sturdy legs, no castors! Beware!!!!
Len.
Thread: Lathe Accuracy |
01/02/2015 16:48:45 |
I've just spotted, Andrew, that I can only access it through Yahoo groups as you say. I don't do Yahoo groups, thanks anyway. Len. P.
