Member postings for Gordon A
Here is a list of all the postings Gordon A has made in our forums. Click on a thread name to jump to the thread.
Thread: Removing Fluxite paste flux residue
22/02/2021 11:53:06
Using the dishwasher for non-domestic items is a hanging offence in our house...or worse!
Thread: Facebook's Portal & Privacy
15/02/2021 10:11:12
These devices sound a bit like the "telescreens" featured in Orwells 1984.
Thread: Problems setting up myford ml7
12/02/2021 12:42:32
Search for "Rollie's Dad's Method" on the internet. I've used this several times and it appears to work, gets the initial alignment of the lathe bed "within the ball park" even with a worn chuck. Can then be confirmed by turning a test piece (hopefully) just once.
Gordon.
Thread: That very light, brown rust / discolouration
26/01/2021 11:27:14
Boiled linseed oil takes a while to dry, but leaves a nice protective coating. I was told by an old gardener many years ago in order to protect garden tools over winter storage in a damp unheated shed, coat the metal bits in boiled linseed oil and the wooden bits in raw linseed oil. It appears to work.
Gordon.
Thread: Flooding
22/01/2021 12:33:52
As someone who has found it difficult and expensive to obtain insurance cover for flooding, I can only comment on my local area where the trend appears to be that of paving over front gardens in contravention of the SUDS regulations introduced 1st October 2008.
Thread: Myford ML7 4 way tool holder
19/01/2021 15:24:41
The problem of an ML7 top slide being no longer flat on the upper surface is probably due to the long-time use of the original "elephants foot and boat tool holder. This can be easily rectified using the lathe itself if you have an angle plate or vertical slide and a fly cutter or large endmill. If you look up Steve Jordan's channel on Youtube where he reduces the height of his topslide, his method can be used just to skim the upper surface flat.
It will save you the cost of grinding unless you know a man who will do it free of course.
Gordon
Thread: IDEAS PLEASE ?
17/01/2021 21:30:26
Resistance soldering unit for etched brass loco kits etc or a demagnetiser perhaps?
Gordon.
Thread: DTI Stand - Single Lock Type?
06/01/2021 14:44:14
Having bought a cheapie version of the type above to fit to an existing magnetic base, a quick strip down of the device revealed the method of locking the stand. I cannot however understand the principle of operation of the hydraulic type. Is there anyone out there who could enlighten me please?
Gordon.
Thread: Rotagrip bore gauge?
01/01/2021 11:00:19
Happy New Year everybody. (we live in hope!)
Rotagrip are in Hockley, Birmingham. I've visited their premises a couple of times in the past. Can't fault their service or the items purchased.
Gordon.
Thread: Speed limiters for cars from 2022?
04/12/2020 10:35:37
5G network perhaps?
Thread: BANG!
24/11/2020 21:45:57
During a previous life as an x-ray service engineer I was tasked with changing a high voltage "tank" in a hospital x-ray room that had developed an internal switching fault. (This was basically a large steel tank filled with oil and containing a high voltage transformer and switch gear.) The installation was ancient (valves and relays etc) and consequently the company had to source from somewhere in the Balkans.
I followed the standard procedures for setting the correct waveforms for the tube output and had set the oscilloscope to trigger on the final test at maximum current and voltage. As I pressed the exposure switch there was an incredible bang and a blinding flash from the control console that I was kneeling behind. The full output of 30kW @125kV had shorted inside what turned out to be a faulty tank with the result that part of the control cabinet was damaged.
My eyesight returned to normal quite quickly and the ringing in my ears subsided, but my bowel problems persisted for some time!
Gordon
Thread: Ball ended handle - how to
22/11/2020 18:10:34
A simple cheating method for the small end ball is to seek out an old style computer mouse (with the ball that picks up fluff and stops the device working until you remove the ball to blow out the detritus).
If the mouse is no longer needed, carefully peel away the rubbery plastic coating from the ball to reveal a metal ball of about 2cm diameter inside. Hold the metal ball in a chuck and face off to the diameter of the small end of the handle and drill and tap a blind hole to suit a thread on the lever. The ball may be slightly rough but this can be cleaned up with a fine file/abrasive whilst being turned on a piece of appropriately threaded rod in the lathe. Then just screw onto the handle and the joint is barely visible.
Alternatively for a quicker job drill a blind hole in the ball and push onto a matching short parallel turned spigot on the tapered handle with a dab of adhesive if required.
Both ways work as I've tried them.
Thread: For the latest in PC fashion! (Anyone here with a Master's Degree?)
28/10/2020 23:07:45
My brain hurts!! The downward spiral continues.
Gordon.
Thread: Four Jaw chuck
25/02/2020 20:44:06
Search for Joe Pieczynski onYoutube. He has a clever way of setting rectangular stock in a 4 jaw chuck.
Gordon.
Thread: magic 127 TOOTH ?
12/01/2020 18:51:21
I use a combination of a 127T and 50T gear on a Myford ML7 to cut metric threads as this gives a ratio of 2.54 to 1.
The setup has to be run without the gear guard though!
Gordon.
Thread: electric paint sprayers
10/08/2019 23:06:43
My experience of this type of spray gun is that they are adequate, bordering on suitable for coating sheds and fences with preservative, but you will be very very lucky to get even a reasonable paint finish. Some years ago a friend of mine attempted to spray a white car with a gun of this type. The result was a car that looked like it had been coated in rice pudding !!
Gordon.
Thread: Is it bad practice to lock my Myford lathe using the slow speed lever
25/06/2019 21:30:26
The advice from an original Myford manual is as follows:
"When removing a chuck (or faceplate), do not 'yank' the chuck off with the headstock locked with the back-gear,, but set the headstock for normal back-gear drive, and after placing a piece of hardwood on the lathe bed, pull the spindle round by means of the belt so that one jaw of the chuck or slot in the faceplate strikes the wood sharply. The most obstinate chuck is released in this way, and a great deal of the load is taken from the back-gear teeth".
Myford ML7 Notes on Operation, Installation and Maintenance (No 720G , M. 3M /11/64)
A method I do not recommend is that if you have a 3 phase inverter drive that is to set a short braking time and run a 9" faceplate (anything else heavy for that matter). The spindle stops very quickly but the faceplate doesn't which necessitates some nifty footwork!! Needless to say the inverter is now set to coast to a stop. Minor damage and no injury but lesson learnt.
Thread: Belt sander recommendations
16/06/2019 20:46:01
Have a look on Youtube for DIY belt sanders. There are some very resourceful people out there.
Thread: water supply
16/06/2019 20:34:58
If I remember correctly, during the water shortage of 1976 the UK government issued the advice to "Save water and shower with a friend" !
Thread: Electricity Supply
12/06/2019 17:14:55
The government has announced that all homes in the UK will not be heated by natural gas by the middle of the century. Is the alternative electricity? . Where will it all come from?
To quote Private Fraser, "We're all doomed".
Gordon.
