David Brown 9 | 26/09/2023 21:01:27 |
81 forum posts 4 photos | I am trying to cut a round 25 mm diameter hole in some 25 mm thick aluminium disks. I am using a Sieg mini mill. Using an ordinary holesaw is not working. Probably because I have already cut smaller diameter holes in the discs so the holesaw drill has nothing to drill through to guide the holesaw. I bought a Armeg carbide tipped holesaw, which was not cheap. This successfully cut through one aluminium disc but no longer works to cut through the other 3 discs I have. I am using plenty of cutting fluid. Would a diamond hole saw work any better? I have a boring bar, but do not want to use this as I know from previous experience this will take a very long time if I use it. As on the mini mill I can only take very smal cuts each time. Perhaps my mini mill is simply not powerfull enough? I should soon have access to a large lathe, but I will still need to know what to use to cut the holes. |
not done it yet | 26/09/2023 21:30:16 |
7517 forum posts 20 photos | Fill the current hole and start again with the hole saw? They are nog that accurate/precise and the finish imay be somewhat agricultural. No lathe? Simple enough (if it will swing the disc) to drill and bore? With only a mill, you could invest in a boring head? Is it 20mm (as in the thread title) or 25mm as in the text of the thread? What’s wrong with drilling it? May need to step-drill, if your drilling capacity is less, but doable. |
Adam Mara | 26/09/2023 22:14:58 |
198 forum posts 1 photos | Have a look at blacksmiths drill bits and work your way up. |
peak4 | 26/09/2023 23:23:45 |
![]() 2207 forum posts 210 photos | I wonder if your carbide tipped saw has chipped due to chattering. p.s. a diamond saw would likely clog, just use the HSS one, lube with WD40 , paraffin, or similar, and keep clearing the chips out. Edited By peak4 on 26/09/2023 23:25:45 |
Mark Davison 1 | 27/09/2023 07:02:25 |
134 forum posts 38 photos | 25mm thick with a hole saw (carbide or hss) sounds like a recipe for disaster, it will just clog. You will have move success with a rotabroach style cutter. The chip evacuation is far better. Make your own arbor from a soft ended blank. |
David George 1 | 27/09/2023 07:40:56 |
![]() 2110 forum posts 565 photos | Drill through with a drill the same size as the pilot drill in the hole saw firstly. remove the drill from the holesaw and replace it with a plain piece of bar. Next drill halfway through, making sure it is clamped or held in a vice. Use paraffin as a cutting lubricant. turn over and drill from other side. This should work. David |
JasonB | 27/09/2023 07:42:06 |
![]() 25215 forum posts 3105 photos 1 articles | Given that the mini-mill does not have a great deal of power and may struggle to drive the larger blacksmiths drills even if working up in a range of sizes or the thicker kerf of a rotabroach. I would suggest stitch drilling out most of the waste with a 7mm drill bit which will allow the motor to run at a comfortable speed and not overload it or the plastic gears. Then take it out to final size with your boring bar(head? ) This is a fairly easy layout, I would drill the holes 6mm and then open out to 7mm to reduce the risk of the holes wandering as they break into the adjacent hole. Holes at 90deg are spaced 8.5mm from ctr, the ones on the 45angles are 6mm x 6mm from ctr which keeps it simple if using hand dials |
Oldiron | 27/09/2023 10:00:09 |
1193 forum posts 59 photos | Posted by Mark Davison 1 on 27/09/2023 07:02:25:
25mm thick with a hole saw (carbide or hss) sounds like a recipe for disaster, it will just clog. You will have move success with a rotabroach style cutter. The chip evacuation is far better. Make your own arbor from a soft ended blank. I agree. A rotabroach is a much better method. Plenty of lube ie wd40 or parrafin. regards |
noel shelley | 27/09/2023 10:12:07 |
2308 forum posts 33 photos | Rotabroach ! When buying get a centre for it - it will make positioning easy. but allow for it to move up as you cut. Noel. |
SillyOldDuffer | 27/09/2023 10:14:05 |
10668 forum posts 2415 photos | Good question. I think this is a case of asking too much of the mill and cutters. Maybe also the Aluminium is soft and gummy, tearing rather than cutting, causing the motor to work extra hard. Hole-saws are best for thinnish sheet metal rather than going deep, because swarf builds up in the slot, and having to drive lots of teeth puts a heavy demand on the motor.
Taking the cut slowly (lowish feed-rate) with plenty of paraffin or WD-40 and frequently stopping to clear swarf might help. About 500 rpm by my rule of thumb, but experiment with faster and slower. The mill's motor probably delivers more power and torque at higher rpm, but what suits the motor may not suit the saw. So I'd change technique. Instead of trying to saw a large hole in one go, I'd twist-drill as big as I can - 13mm because I'm too mean to buy a Blacksmith's Drill.
Then bore the 15mm hole out to whatever size is needed with a boring bar. For this a boring head is needed: Though they cost a few bob, boring heads are a valuable accessory. Boring does both deep and wide holes. As there's only one cutter, which can be adjusted to take very find cuts, it doesn't overload the motor. The holes are also considerably more accurate and straighter than anything done with drill or hole-saw. Main disadvantage is the time taken. If you want to make big holes quickly, a large powerful machine is needed to drive the cutter. Otherwise we have to slow down! Jason's method is a good compromise: chain drilling lots of small holes removes metal quickly and then the boring bar only has to tidy up, which doesn't take long. The mill works inside it's comfort zone throughout, and swarf collecting and mincing in the slot isn't a problem. Dave
David Brown 9 | 28/09/2023 09:08:32 |
81 forum posts 4 photos | I will give a 24 mm rotabroach a try. I have a R8 mini mill. What adapter would I need so that the Rotaborach would fit it? The one I have found on Amzon says that it needs a pilot pin, SRA50 ejector pin. What is this used for? I have a boring head and will use this if necessary. But I lack the patience to use a boring head on 3 holes because of the time it takes, unless there is no alternative. Plus, I have had problems making the holes too big with a boring head.
Mike Hurley | 28/09/2023 09:39:24 |
530 forum posts 89 photos | How come you get oversized holes with a boring head? These are very accurate normally, so might suggest you have another issue (wobble due to poor location / seating or even a small spindle issue ?) or you are trying to take too heavy a cut each time and you get springing of the cutter? I admit they can be tedious to use manually having to keep stopping - adjusting - restarting, but the trick is to allow as little material as possible to finish the hole. As you already have one, thats no additional expense, if you haven't got blacksmiths drills then I personally would follow Jason's suggestion of drilling out a ring and even tidying up the remaining 'peaks' with a much smaller dia drill or even manually with a coping saw - it's only aluminium!. Finish with the boring head I've recently completed something similar (25mm dia) in Mild steel using this method and it was straightforward (I used a coarse file rather than a coping saw though as it was steel!) Mike
Edited By Mike Hurley on 28/09/2023 09:40:46 |
noel shelley | 28/09/2023 09:43:54 |
2308 forum posts 33 photos | The rotabroach has a 3/4" parallel shank with 2 flats at 90* apart.. The pin A) enables the cutter to be easily centred and also pushes out the core on breakthrough. Run it as slow as you can and lub. Noel. |
JasonB | 28/09/2023 09:48:37 |
![]() 25215 forum posts 3105 photos 1 articles | You are never going to do it quickly on a small mini mill due to the size of cut it can comfortably take. Using a large cutter that puts a lot of load on the slow running motor won't be quick in the long run when you have to spend time repairing the machine but I can see Ketan and the boys rubbing their hands now at the prospect of more sales of spare parts If you can't size the hole then you have problems somewhere either rushing with big cuts that deflect things or tool geometry is rubbing somewhere. Boring head is more accurate and will give a better finish than any holesaw, rorabroach, blacksmiths drill, etc You should be able to use the quill lever to feed the boring head fairly quickly, for best results use the fine feed for the finish pass Edited By JasonB on 28/09/2023 09:55:25 |
donkey | 28/09/2023 10:56:19 |
![]() 85 forum posts 5 photos | why not clamp down on a thick piece of ply then the drill will keep the saw true bri |
Pete White | 28/09/2023 11:07:54 |
223 forum posts 16 photos | Posted by David Brown 9 on 28/09/2023 09:08:32:
Thats good David, you can ask for advice but you don't have to take it, good luck. Pete I don't want to know, but do you know? is it 20 or25 mm dia holes that you want to produce. Edited By Pete White on 28/09/2023 11:21:51 |
Paul Mills 4 | 28/09/2023 11:19:55 |
15 forum posts | The thread on the arbor of my holesaw can just accommodate two hole saws, front one only has a a couple of threads, if for any reason I have to enlarge a hole using made a hole saw I simply screw the smaller holesaw on the front and use this as a guide, rather like the pilot drill , but as the smaller holesaw is not actually cutting there is no problem with it either being difficult to remove or stripping the threads. Have to admit that I have only ever done this in thin materials |
Ady1 | 28/09/2023 18:04:56 |
![]() 6137 forum posts 893 photos | Once you get close with aluminium you can do a high speed single tooth whirry job for finishing, I've done up to 45mm in steel Thing is a hobby lathe is much better for boring bigger holes, a hobby mill will struggle unless you get it just right |
MadMike | 28/09/2023 18:43:52 |
265 forum posts 4 photos | Do you have, or have access to a lathe? That would make he (w)hole operation very simple. F you are close to he East Midlands the I could do it for you. There are possibly others on here who would help. |
noel shelley | 28/09/2023 21:13:15 |
2308 forum posts 33 photos | If your near N Norfolk I will soon put a 24 or 25mm rotabroach through it for you. Noel. |
