Can't find this spanner size
Mark Rand | 12/03/2022 20:25:05 |
1505 forum posts 56 photos | Yesterday I decided to try and get the Taylor & Hobson Model C engraver going that's been sitting in the shed for 10-15 years. I made new drive belts from round PU belting and tried it out. There is slack in some of the pantograph linkages, although it looks like vertical play rather than radial play is the major culprit. As it happens the linkages involved are adjustable, But:- They seem to have nuts that are 15/32" AF. This isn't a size that I've come across before and doesn't seem to match any series that I can find reference to. I can use my smallest adjustable spanner and could mill a pair of fitting spanners out of gauge plate, then harden them, but I'm curious as to if anyone has ever come across this size? |
JasonB | 12/03/2022 20:34:43 |
![]() 25215 forum posts 3105 photos 1 articles | would 12mm be too loose? |
David-Clark 1 | 12/03/2022 20:42:05 |
![]() 271 forum posts 5 photos | Here’s one on eBay. About £5.
bernard towers | 12/03/2022 20:42:32 |
1221 forum posts 161 photos | My AF spanner set from the late 60s went up in 32nds and I still have them, Britool of course and the chrome is still on them!!! |
noel shelley | 12/03/2022 21:53:14 |
2308 forum posts 33 photos | Take a 7/16" or 11mm AF open end and file or use a grinding disc to increase it to 15/32" ! Done it with a 50mm to convert to 2" Good luck. Noel |
Mark Rand | 12/03/2022 22:18:12 |
Posted by JasonB on 12/03/2022 20:34:43:
would 12mm be too loose? 12mm is a very sloppy fit, even though it's the closest that I had.
Posted by noel shelley on 12/03/2022 21:53:14:
Take a 7/16" or 11mm AF open end and file or use a grinding disc to increase it to 15/32" ! Done it with a 50mm to convert to 2" Good luck. Noel My mind had been working along those lines as an option. Possibly with the surface grinder or an endmill. Hey, after I get the engraver working I gan grind off the original markings and engrave some new ones. |
Nick Wheeler | 12/03/2022 23:41:56 |
1227 forum posts 101 photos | Posted by Mark Rand on 12/03/2022 22:18:12:
would 12mm be too loose? 12mm is a very sloppy fit, even though it's the closest that I had. How about supergluing a shim in the jaws to tighten the sloppy fit? That's ought to be good enough for a few uses. A cheap set of feeler gauges is worth having for such jobs.
Or you could machine some new nuts to match other fittings on the machine. Which is a permanent fix. Edited By Nicholas Wheeler 1 on 12/03/2022 23:43:19 |
Hopper | 13/03/2022 05:01:27 |
![]() 7881 forum posts 397 photos | Posted by Mark Rand on 12/03/2022 22:18:12:
15/32 is .469". And 12mm is .472". How tight a fit do you want? Less than 3 thou?? Spanners are normally made five to ten thou bigger than the nominal hex size for easy use. |
Michael Gilligan | 13/03/2022 10:14:03 |
![]() 23121 forum posts 1360 photos | If a sloppy-fitting spanner risks rounding the ‘corners’ of the hexagon … try flank drive MichaelG. |
Split Pin | 13/03/2022 10:29:56 |
13 forum posts 1 photos | Given that it is an old English manufactured machine, the fastners are probably all whithworth, in whick case it will be 1/4" whit which requires a 3/16" whit spanner. Hexagon size is 0.454" and the spanner size is 0.445" Steven Edited By Split Pin on 13/03/2022 10:30:29 |
Anthony Kendall | 13/03/2022 10:39:45 |
178 forum posts | Posted by Michael Gilligan on 13/03/2022 10:14:03:
If a sloppy-fitting spanner risks rounding the ‘corners’ of the hexagon … try flank drive MichaelG. Agree - I use a metrinch set for most things. |
Pete Rimmer | 13/03/2022 10:44:40 |
1486 forum posts 105 photos | I'll have a look when I get home it's possible I might have one. |
Mark Rand | 13/03/2022 12:57:07 |
1505 forum posts 56 photos | It isn't a Whitworth size, or a 12mm metric size, or a BA size. Mr Micrometer says its 0.467" AF.
Tony Pratt 1 | 13/03/2022 13:06:18 |
2319 forum posts 13 photos | From a Taylor Hobson engraver it is likely to be a 15/32" but I'm sure a 12 mm A/F will suffice. Tony |
Michael Gilligan | 13/03/2022 13:36:01 |
![]() 23121 forum posts 1360 photos | Mark In case you fancy making a pair of thin spanners … the basic geometry is here: **LINK** https://worldwide.espacenet.com/patent/search?q=pn%3DGB1138546A … and yes, it’s adaptable to open-enders MichaelG. |
Nicholas Farr | 13/03/2022 14:42:03 |
![]() 3988 forum posts 1799 photos | Hi Mark, I don't think 15/32" A/F is a standard size in the UK, however 1/4" BSF / 3/16" Whit is supposed to be 0.445". I've just measured three 1/4 BSF / 3/16 Whit open ended spanners of mine, one is 0.452", one is 0.453" and the other is 0.459", so I would say one of those should fit your nut, which is a lot closer than a 12mm spanner that I have measuring 0.480". Regards Nick. |
Mark Rand | 14/03/2022 14:20:22 |
1505 forum posts 56 photos | Right:- update time.
I discovered that my only 12mm open ended spanner has got slightly sprung jaws. Doesn't normally affect it, since my normal reaction to a 12mm AF nut is to replace it with something else. A 12mm hex (not bi-hex) socket fitted the outer, accessible nuts quite well. A Bahco 4" adjustable spanner was thin enough to get to the inner, less accessible nuts. The engraver produces far straighter lines once the play in the two joints is taken up. It isn't prefect yet, but it's better than it was. |
oldvelo | 14/03/2022 19:43:12 |
297 forum posts 56 photos | Grip Master 12 mm spanner as used by ICI Instrument Artificers 60 + years ago will do the job as they grip the flats on the nut back from the corners on four places. |
John Reese | 21/03/2022 03:39:38 |
![]() 1071 forum posts | About 65 years ago I purchased a set of open end wrenches from Sears Roebuck. I contained a couple of wrenches with odd 1/32 openings. I never found anything they fit. |
mark costello 1 | 21/03/2022 18:03:19 |
![]() 800 forum posts 16 photos | Old American cars used some of those sizes. |
