Here is a list of all the postings mark costello 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: Learning Curve |
04/10/2023 18:19:22 |
A learning curve is usually as steep as falling off a very high cliff. One step and You are off to the races.
Thread: Bolt or screw? |
26/09/2023 21:46:17 |
I was taught a bolt is 1/4" od. or bigger. A screw is anything smaller. |
Thread: Making aPolishing Mop "Tail" |
26/09/2023 21:43:41 |
Here is a hint for Someone Who does not have a taper attachment. This pipe chaser is put on square against the tool post, |
Thread: WHERE ARE THE SHAPER USERS ? |
12/09/2023 19:36:14 |
Here I am cutting a set of splines. Edited By mark costello 1 on 12/09/2023 19:37:03 |
Thread: Scams |
11/09/2023 21:38:52 |
for the first time in My life I had an Irish Traveler (no disrespect to the Irish) stop in. He wanted to tarmac My drive. His truck had a badge on the side that had "road crew" on it. No other company or county name on it. Thank the internet as that was the only way I knew what it was. FIL had His barn roof painted and it washed off the first rain. He supplied the paint and carefully watched but some how things got switched. |
Thread: This made me smile |
01/09/2023 17:39:44 |
A college jab............ One School bragged, Tower of Learning. Neighbors called it The Heights of Ignorance. |
Thread: When boredom overtakes, make something, anything! |
30/08/2023 21:07:08 |
I don't have time to invent a wheel that has been well traveled by some of the giants before Me. Listen, learn, then adapt and over come. |
Thread: 12 x 2 lead screw |
24/08/2023 02:27:06 |
I have seen a drum arrangement used in the USA to make a tapered shaft for the WW2 effort. |
Thread: I need custard. |
17/08/2023 21:16:47 |
I cannot understand how rock dust explodes, but it must. Starting fluid detonates also. Here's how I know. Taken about 1 minute after the event. Whipped the starter cord violently back and hit My hand in the process. |
Thread: Fuse Rating for VFD |
16/08/2023 21:49:30 |
They wanted to encourage fast showers, with minimal water use. |
Thread: oops voyager |
04/08/2023 16:34:29 |
It's bad enough when a part is reworked or scrapped, it's a whole nother thing when the mistake is broadcast around the world. |
Thread: Coventry Diehead |
02/08/2023 17:48:58 |
Working in a screw machine using Geometric chasers once in a while putting the chasers in sequence would not work. Boss showed Us to take and put the chasers out of sequence, instead of 1-2-3-4, He would change it to 1-3-2-4. Or moving the chaser blocks around 1 hole for the start position. Some times they were fidilly but eventually He got them to work. Did not think it would work but it did. |
Thread: Damaged Screws & QCTP help!!! |
02/08/2023 17:23:50 |
HSS tool bits do not have to come out to be resharpened. |
01/08/2023 21:10:44 |
We seem to have raw talent for that. |
Thread: Why do modern car engines have different types of bolt type heads like Torx etc? |
26/07/2023 23:42:40 |
How about Metric bolt heads on Imperial threads? |
26/07/2023 23:41:11 |
Thread: MK Metals |
22/07/2023 14:31:21 |
Silver Solder. |
Thread: Gluten Intolerance |
21/07/2023 19:45:23 |
Sour dough bread? Thought it was the breakfast of champions. |
Thread: Vintage Austin Brake Adjuster - The Denouement |
16/07/2023 23:14:16 |
Rain activated? Sort of like the bobbing birds that drink out of a cup. |
Thread: a machinist making a knife |
15/07/2023 20:55:57 |
It is not what the weapon does, it the user. |
