Paul Lousick | 12/01/2020 22:09:16 |
2276 forum posts 801 photos | I saw this video about building a home made metal lathe and was a bit sceptical at first as to whether it would actually work. I was impressed though by the skills of the fabricator even though his marking-out and building techniques were a bit hit and miss. Not what you would use for making a precision tool. Paul Edited By Neil Wyatt on 13/01/2020 18:08:50 |
Michael Gilligan | 12/01/2020 22:16:30 |
![]() 23121 forum posts 1360 photos | Great job Very sensible use of commercial rails and bearing assemblies. MichaelG. |
Steviegtr | 12/01/2020 22:23:35 |
![]() 2668 forum posts 352 photos | Ha ha awesome. I wondered where all the quick change tool posts were being made. India at it's best maybe. Wonder how much it cost him to build it. |
Hopper | 13/01/2020 03:17:07 |
![]() 7881 forum posts 397 photos | I had wondered about using those linear rails for such things before and always assumed swarf would mess them up. but looks like they have seals on the edges so all good. Well done that man. I wonder how well they will stand up to wear under the kind of cutting forces in a lathe? And do they have any facility to adjust for wear if the balls become a loose fit on the rail? The equivalent of gib strips. Edited By Hopper on 13/01/2020 03:41:02 |
Hopper | 13/01/2020 03:19:09 |
![]() 7881 forum posts 397 photos | Double post. doh! Edited By Hopper on 13/01/2020 03:39:18 |
Michael Gilligan | 13/01/2020 08:30:28 |
![]() 23121 forum posts 1360 photos | Posted by Hopper on 13/01/2020 03:17:07:
[…] I wonder how well they will stand up to wear under the kind of cutting forces in a lathe? And do they have any facility to adjust for wear if the balls become a loose fit on the rail? The equivalent of gib strips. . To the best of my limited knowledge, the are not adjustable for wear Some good [upmarket] info here: **LINK** https://www.automotioncomponents.co.uk/en/catalog/linear-components/linear-bearings-shafts/linear-shaft-supports/shaft-support-rails/l1780.12/g+m+c+s+a MichaelG. |
BW | 13/01/2020 08:49:37 |
249 forum posts 40 photos | Thanks - Enjoyed that video, wish I had similar skills. Bill |
larry phelan 1 | 13/01/2020 14:06:42 |
1346 forum posts 15 photos | I seem to remember the late L,C Mason writing about something like that in his book "Using the small lathe". , and he was no duff ! Am I perhaps mistaken ?
That machine might be no worse than many others on sale, if this Frum is any thing to go by. How long did it take to build ? How long does it take to build a model engine, which may be only a showpiece anyway. I thought it was a fine piece of work, but then, I,m easy pleased. |
Oldiron | 13/01/2020 15:13:33 |
1193 forum posts 59 photos | What was the purpose of pouring swarf on the shaft ?? We know its going to get in there anyway. But at least he made something in the shop. |
martin perman | 13/01/2020 15:35:44 |
![]() 2095 forum posts 75 photos | The ball recycling bearing assemblies and rods are excellent in automation situations particularly in one off robot assemblies especially in clean enviroments but after time the balls will slowly wear several straight grooves in to the guide rods and as good as the seals are will attract muck and accelerate the wear,
Martin P |
fizzy | 13/01/2020 16:18:06 |
![]() 1860 forum posts 121 photos | A couple of steppers and its CNC ready. Those big cnc ball screws arent cheap though.
ega | 13/01/2020 16:27:30 |
2805 forum posts 219 photos | Posted by Oldiron on 13/01/2020 15:13:33:
What was the purpose of pouring swarf on the shaft ?? We know its going to get in there anyway. But at least he made something in the shop. I thought it might be graphite. |
ega | 13/01/2020 16:28:03 |
ega | 13/01/2020 16:29:02 |
2805 forum posts 219 photos | My first double post - sorry! What am I doing wrong?
Edited By ega on 13/01/2020 16:29:57 |
Oldiron | 13/01/2020 16:44:33 |
1193 forum posts 59 photos | Posted by ega on 13/01/2020 16:29:02:
Edited By ega on 13/01/2020 16:29:57 Yes possibly graphite but it looks a bit chunky for that. re double posts. I have had that when I was a little impatient and did not allow time for the post to load on the forum. regards |
Robert Atkinson 2 | 13/01/2020 17:18:51 |
![]() 1891 forum posts 37 photos | It's a bit concerning that the "bed" did not sit flat on this bench after he welded the two U sections together......... |
Iain Downs | 13/01/2020 17:22:27 |
976 forum posts 805 photos | It wouldn't have worked that well if I'd made it...
Iain Edited By Iain Downs on 13/01/2020 17:22:39 |
Vic | 13/01/2020 18:12:48 |
3453 forum posts 23 photos | I’ve seen a couple of small CNC milling machines fitted with linear rails rather than dovetails so assumed this was the current way of doing things? They also used ballscrews. |
Oldiron | 13/01/2020 18:14:17 |
1193 forum posts 59 photos | Posted by Iain Downs on 13/01/2020 17:22:27:
Iain Edited By Iain Downs on 13/01/2020 17:22:39 Oh ye of little faith. regards |
mechman48 | 14/01/2020 10:50:13 |
![]() 2947 forum posts 468 photos | Posted by ega on 13/01/2020 16:27:30:
What was the purpose of pouring swarf on the shaft ?? We know its going to get in there anyway. But at least he made something in the shop. I thought it might be graphite. My guess it is graphite flakes or shredded graphite yarn from valve packing... George. |
